12v Power source Location Escort Radar Detector - Mustang Evolution
Old 12-09-2013, 04:41 PM   #1
Deerslayer's Avatar
Is there a 12v power source near the rear view mirror on a '13 Base model interior? Looking at a RM mount for an escort and want to power without running the jumper to the 12v power outlet.
Any suggestions for mount beyond the stock suction cups.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 12-09-2013, 05:07 PM   #2
there is, I have mine setup that way. I'll pm you tomorrow how once I look at it. I tapped in to one of the wires that comes down to the mirror and I tapped into its ground also. comes on with startup. shuts off with your radio when u get out
menace21 is offline   Reply With Quote
Old 12-09-2013, 05:14 PM   #3
Deerslayer's Avatar
Are you a base model or premium?
I know there is power on the passenger side pillar. I tapped into there for the lighted door sills. I could run to there, but didn't know if the base model has any power to the mirror.
Old 12-09-2013, 05:23 PM   #4
base, and the mount I have I got on amazon for like $35. mirror mount. it works well, I didn't want to spend the money for a blend mount
Old 12-09-2013, 05:27 PM   #5
thejohncarlson's Avatar
Escort makes a direct wire kit that I bought. I put mine right below the rear view mirror, ran the wire up the mirror to the headliner and then over and down to the fuse box.
thejohncarlson is offline   Reply With Quote
Old 12-09-2013, 05:47 PM   #6
Deerslayer's Avatar
NICE!
Yeah, the BlendMount looks really good, but they are proud of it.
I know there is 12v at the passenger pillar, so at worst, I will install a 2amp fuse inline and wire it to there. What mount did you use? Thinking of trying this for under $10, if it is crap, will get the BlendMount.
This one uses 3M tape, maybe center it though.
Old 12-09-2013, 07:06 PM   #7
If you go to escorts website and lookup the supercup windshield mount. That is the one I have. I like how it move the detector forward so it is basically in line with the rear view mirror.
Old 12-10-2013, 04:41 PM   #8
i tapped into the solid blue wire to the mirror
Old 12-10-2013, 04:50 PM   #9
Bryanw92's Avatar
Where's the power on the passenger pillar? Is it under the A-pillar cover?
Bryanw92 is offline   Reply With Quote
Old 12-10-2013, 05:40 PM   #10
WJBertrand's Avatar
Couldn't pull power from the hot side of the dome lamp?
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 12-10-2013, 06:14 PM   #11
Deerslayer's Avatar
I am thinking his does not have power to the mirror. He finishes his last final on Friday so we will do the install Saturday. He sent me a pic that looks like no power to the mirror??
Yes, it is easy to get too and under the pillar. Instructions for lighted door sills have you wire into the 12v on the passenger pillar.
Yeah, prob will do that, but I would like power that only comes on when the ignition is on. I think the dome light maybe hot constantly.
Old 12-15-2013, 09:28 PM   #12
Deerslayer's Avatar
Ended up going with the BlendMount and direct wired to the passenger pillar. Ground taps into the black/yellow wire and the Key On Power is the White/Blue wire in the pillar. Super easy and the inline fuse is easy to get too if it were to blow. 15m install and it looks clean.
Old 12-16-2013, 06:23 AM   #13
bucko's Avatar
Do you have an overhead mini console? If so, grab the power from the lights in it. I did that for my radar detector power lead. I also bought a lead that had a fuse incorporated into it.
Old 12-16-2013, 04:01 PM   #14
Deerslayer's Avatar
Only the map lights & housing. I was already familiar with some of the harness in the passenger pillar due to wiring the door sills there. Easily accessible with no tools.
Turned out pretty clean
Old 12-16-2013, 09:01 PM   #15
Looks great!
Old 12-17-2013, 07:35 AM   #16
bellski's Avatar
I also have a Blendmount in my '11GT, they are pricey, but they are awesome as well. I tapped into my fusebox and ran a power wire up my passenger piller and under the headliner- very clean.
I did buy a Supercup mount for my company car as well as my Pickup and that is a much better option than the suction cup mounts that come with Escorts, for sure.
2011 GT M6 Premium- Mechanical upgrades include: Boss 302 Intake, JLT CAI, JPC LT Headers, Off Road X Pipe, and mufflers, 410 Gears, Granatelli Hot Street Coil Packs, 93 Octane Ghost Cam Tune by Jon Lund,Eibach ProKit Springs,shocks, struts and sway bars, BMR LCA's, Strut Tower Brace, and adjustable Panhard Bar, Maximum Motorsports Camber/Caster Plates, Barton Shortshifter and bracket, Wilwood Superlight Brakes w/6 and 4 piston calipers, Steeda Spyders- 9-1/2X20 with 275/35 and 11X20 with 315/35 Nitto Invos.
bellski is offline   Reply With Quote
06:19 AM
