Advice on painting strut tower brace - Mustang Evolution
Old 12-17-2013, 12:21 PM   #1
Benzopyrene's Avatar
Wanted to paint this bad boy, but was curious how you all went about painting this piece since its not plastic like the other pieces. Maybe its the same, but thought I would ask before I made an attempt. Any and all help is appreciated. Cheers!
Benzopyrene is offline   Reply With Quote
Old 12-17-2013, 01:11 PM   #2
redbeast0712's Avatar
Region: Nevada
I painted mine. Use a high temp engine paint to withstand temperatures. Make sure to sand it down so the paint will stick better and also don't use the paint in the cold weather. After I painted my I used a high temp clear coat on my as well.Click image for larger version
Name:	ImageUploadedByMustang Evolution1387311093.778092.jpg
redbeast0712 is offline   Reply With Quote
Old 12-17-2013, 03:22 PM   #3
bdrec64's Avatar
Looks good redbeast0712
bdrec64 is offline   Reply With Quote
Old 12-17-2013, 03:39 PM   #4
Region: Nevada
Thanks man !
Old 12-17-2013, 05:03 PM   #5
Deerslayer's Avatar
You could wrap it in 3M carbon fiber wrap like we did my sons.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 12-17-2013, 06:51 PM   #6
Very nice guys! When you are sanding the aluminum do you use a lower grit like 320 to start or do you just go with a 600 grit...then prime, sand, paint, clear, sand, polish? Cheers!
Old 12-18-2013, 06:19 AM   #7
Region: Nevada
It doesn't matter just need to scratch it enough so the paint will stick better.
Old 12-18-2013, 07:41 AM   #8
Skulls98GT's Avatar
The better your prep work is, the better your paint will turn out.
As far as scuffing goes, I like to use the red scotch brite pads.
Name:	ImageUploadedByMustang Evolution1387377144.385314.jpg
If your brace has been under your hood at all, I would suggest using a wax and grease remover after scuffing.
Name:	ImageUploadedByMustang Evolution1387377439.433528.jpg
As far as painting, many light to to medium coats as recommended on the can is always better than one or two heavy coats.
Good luck.
Skulls98GT is offline   Reply With Quote
Old 01-03-2014, 12:23 AM   #9
Bodyman's Avatar
The red scotch brite would be the best route. That way you don't have to worry about covering up sand scratches.
Bodyman is offline   Reply With Quote
Old 01-03-2014, 02:20 PM   #10
Foxone's Avatar
Red pads are great. If its bare aluminum, I would use some Bulldog adhesion promoter to help it stick.
2015 GT Premium....
Foxone is offline   Reply With Quote
Old 01-03-2014, 07:10 PM   #11
Been working on other projects so haven't started this yet. Strut bar is just sitting on my workbench surrounded by crap. Need to get motivated.....next week!
08:56 PM
