Whiteline Watts Link Rear Suspension - Mustang Evolution
Old 12-20-2013, 11:22 PM   #1
NewMtang's Avatar
B]V6s or V8s[/B]
Any of you guys/girls out there using the Whiteline Watts Link Rear Suspension (American Muscle, part# 54111)?
Old 12-22-2013, 07:54 PM   #2
jayman33's Avatar
I've been running this, great setup and drastically improves cornering in uneven roads.
A boss.....
jayman33 is offline   Reply With Quote
Old 12-23-2013, 09:44 AM   #3
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Originally Posted by NewMtang View Post
B]V6s or V8s[/B]
Whiteline makes a great product! I run their Lower Control arms on my 2011 GT and have full intentions of getting the Watts Link set up. The Whiteline Watts Link Rear Suspension allows the axle to move up and down in a true vertical plane keeping it centered under the car, so that your roll center behaves exactly the same in a left hand turn as it does in a right hand turn. This allows for predictable and tune-able handling, perfect for street and track cars.
These are also ride height adjustable. So it doesn't matter if you're Stock, Lowered on Springs, Coil overs etc.. you can still use the Watt links set up!
I hope this helps. It sounds like you have some really big plans for your Suspension. That's really cool to see! Keep up the great work with your build and let me know if you ever have any questions.
-Dan
Old 12-24-2013, 11:31 AM   #4
Benzopyrene's Avatar
Looks really pretty but have read a lot that Fays2 is just as good, and is a couple hundy cheaper.
Benzopyrene is offline   Reply With Quote
Old 01-02-2014, 05:37 PM   #5
Just ordered one so ill report back after I get t installed when I redo my rear end in a couple weeks!
Old 01-08-2014, 01:04 PM   #6
blu
blu's Avatar
In terms of labor costs, does it make sense to wait to install a Whiteline Watts until after you've done the shocks/struts/coils upgrade, or better to plug in the Watts for the Panhard before all that?
Alot more repair shops than performance installers in my neck, so I try to not ask them to bite off more than they should chew in one sitting.
blu is offline   Reply With Quote
05:20 PM
