Upgrading Brake Pads and SS lines - Mustang Evolution
Old 12-27-2013, 12:55 PM   #1
Hey guys
Am going to do SS lines and hawk hps on a non brembo car. For street driving and trips to the track, should I change the fluid to another type? Like dot 4? Is there any pros and cons to switcing to an aftermarket fluid? Thanks
JayblesStang is offline   Reply With Quote
Old 12-27-2013, 03:08 PM   #2
foxbox's Avatar
Originally Posted by JayblesStang View Post
Hey guys
Dot 4 wont boil when you are racing which reduces brake fade however dot 4 draws in alot of water and/or moisture because of its chemical properties; its not recommended for daily drivers.
foxbox is offline   Reply With Quote
Old 12-27-2013, 03:13 PM   #3
Thanks i guess ill stick with dot 3 which is oem
Old 12-27-2013, 06:46 PM   #4
Stfmarc's Avatar
Stay whit dot 3 but use the ford motorcraft the boiling point its higher than the most dot 4
Stfmarc is offline   Reply With Quote
Old 01-01-2014, 06:43 PM   #5
kramer's Avatar
Region: New Hampshire
Isnt that whathe GT's come with from the factory?
---------- Post added at 07:43 PM ---------- Previous post was at 07:40 PM ----------
I planned on moving to the Castrol high temp fluid in the spring before hitting the track again but I'm done with losing most of the pedal after 10 laps but now I guess more research is on order...
kramer is offline   Reply With Quote
Old 01-01-2014, 07:14 PM   #6
kramer's Avatar
The Castrol SRF has been recommended by many at the track as it absorbs less water than most. Expensive but losing the pedal at the end of the straight can cost a Hell of a lot more!
07:59 AM
