Suspension - Mustang Evolution
Old 01-07-2014, 03:25 PM   #1
Te172r's Avatar
Region: Arkansas
Suspension
I am thinking of upgrading my suspension. Right now I'm thinking Steeda springs and Koni shocks/struts. What else do I really need? Panhard, bumpsteer kit, sway, lca?
Te172r is offline   Reply With Quote
Old 01-07-2014, 06:27 PM   #2
HPFury's Avatar
Adjustable Panhard to re-center rear, camber bolts or cc plates, lca and relocation brackets. Good luck.
HPFury is offline   Reply With Quote
Old 01-07-2014, 06:47 PM   #3
Redonblackpony's Avatar
Lowering, stiffer springs are a good choice. LCA's and adjustable UCA as well as a pan hard bar to align the rear from the lowering springs. The factory sway bars need not be replaced as they are pretty good for most applications. CC plates are only required if you lower more than an inch and a half. I'm lowered on Ibach Pro line and I still have the stock camber bolts with no CC plates. Hope this helps.
Redonblackpony is offline   Reply With Quote
Old 01-07-2014, 07:39 PM   #4
Te172r's Avatar
Region: Arkansas
The Steeda are 1in front and 1.5 rear. Would I be just as well with the bolts?
Old 01-07-2014, 07:42 PM   #5
HPFury's Avatar
Cheaper alternative than cc plates.
Old 01-21-2014, 07:41 AM   #6
Deffinitly a panhard bar, i did similar set up and my axel shifted. I would get cc plates or gt500 strut mounts because the stock ones fell apart on me. I didnt do the uca or lcas right away and it wasnt a big deal, but its easier to do it all in one shot.
2012 GT Premium, manual trans, FR axel back sport mufflers, eibach lower springs/shock/struts, eibach front & rear swat bars, BMR panhard bar, BMR UCA and mount, BMR LCA and relocation brackets, MGW short shifter, boss 302 steering wheel, JDM oil seperator, TSW nurbergring 19's.
Jesse C is offline   Reply With Quote
Old 01-21-2014, 07:47 PM   #7
HPFury's Avatar
+1 gt500 strut mounts. It is shameful what ford puts into the 14 GTs. I accidentally cracked one open and was shocked at how cheaply made they were.
01:29 AM
