coil spring compressor needed to install eibach springs? - Mustang Evolution
Old 01-09-2014, 04:27 PM   #1
I am installing eibach pro kit springs on my 2011 gt this weekend, and I was planning on getting a spring compressor, but I watched an install video that showed it being done without it, has anyone here done it without? Im sure once I get into the project it will become clear, but I don't want to get the car apart and find out I do need it, any advice would be helpful, thanks
rwheels is offline   Reply With Quote
Old 01-09-2014, 06:51 PM   #2
TooSlow4U's Avatar
Some use a jack to jack up the strut and remove the strut nut then slowly lowering. I however, have always used spring compressors to remove the springs. I also wear safety glasses and earplugs when using air tools. Im in the safety field so I'm a bit of a safety nut.
TooSlow4U is offline   Reply With Quote
Old 01-10-2014, 01:34 AM   #3
Bodyman's Avatar
Yes all you do is put the car on jack stands then put the jack under a-arm jack the jack up loosen the bolt and let jack down slowly. When installing just reverse steps. But I would place jack where you can operate without standing right in front of strut and spring.
Bodyman is offline   Reply With Quote
Old 01-10-2014, 04:32 PM   #4
Benzopyrene's Avatar
or just rent em at autozone and get your money back when you return them.
Benzopyrene is offline   Reply With Quote
Old 01-11-2014, 10:28 AM   #5
Evil2014GT's Avatar
Make sure you go very slow if you do go that route, as it can be very dangerous if done incorrectly. IMO, especially if this is your first time, get the spring compressor. As mentioned above, you can rent them from autozone for $45 and get 100% of your money back when you return it.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 01-11-2014, 11:57 AM   #6
well I did it today, I bought a compressor from harbor freight for 15.00, and it worked great. I think that if you take the strut/spring off as a unit then you have to use it, I didn't try lowering the control arm with the strut nut already off but I guess that's how you could do it without. My advice having done it, use the compressor, I actually needed to use the compressor to get the lowering springs back on also, so its good I had it. Thanks for the help guys
Old 01-11-2014, 11:59 AM   #7
Xedes's Avatar
Rent the compressor for peace of mind if nothing else. I've seen some major damage done to cars and people when their springs came flying out by mistake.
Xedes is offline   Reply With Quote
Sr performance lowering springs install Eric e 2011-2014 V6 Mustang 35 04-25-2013 11:27 PM
2013 mustang dropped on eibach pro kit (pics of install) BUSHGUTS 2011-2014 Mustang GT 42 02-13-2013 07:25 PM
94 Mustang runs worse after CAI & coil install, Need suggestions Mustang52 1979-1995 Mustang GT 5 09-21-2012 11:22 PM
My Paxton Install Experience Jukens 2011-2014 Mustang GT 30 09-01-2012 04:35 PM
Springs for Brembo 5.0 M3to5.0 2011-2014 Mustang GT 40 10-12-2011 05:31 AM
08:55 AM
