Suspension warranty question. - Mustang Evolution
Old 01-13-2014, 04:22 PM   #1
How long is the suspension warranty? Is it under the B2B warranty, powertrain, or a separate warranty. I don't have my actual owners manual(dealer is still screwing around with that), and did a brief check on the online manual, but didn't see anything.
Old 01-13-2014, 07:09 PM   #2
fastJ's Avatar
Google it it's a simple search
fastJ is offline   Reply With Quote
Old 01-13-2014, 07:24 PM   #3
Didn't come up with anything suspension related. Would it be under the b2b warranty, or powertrain? I think suspension would be under the b2b warranty, and not the powertrain, but I'm not sure.
Old 01-13-2014, 08:10 PM   #4
nhcowboy's Avatar
You do know you can pull PDF versions of your user manual from the ford owners website right?
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 01-13-2014, 08:12 PM   #5
I already tried that. I didn't look through it thoroughly, but I didn't see anything about suspension, I did see something about axle bearings,I think, which was under powertrain.
Old 01-13-2014, 08:19 PM   #6
nhcowboy's Avatar
Ok. Let's think this through.
POWER train...
Sooooo
Engine = yes
Trans = yes
Driveshaft = yes
Diff = yes
Rear axles = likely.
Suspension = not that I've ever heard of.
So that sir would be part of the B2B.
And may I ask why you are concerned at this point? Your car is a 13 soooooooooooooooo.....
12.538 ET @112.33
Old 01-13-2014, 08:21 PM   #7
I figured that it would be the b2b, the axle thing kinda threw me off, well, know I know I only need to wait 2 years 6 months, or 30K more miles.
Old 01-13-2014, 08:24 PM   #8
I'm not sure when the warranty started, because it may have been put into service before I bought it(had 300 already on it.) I just want it to have better handling, and also get some drag springs...
Old 01-13-2014, 10:58 PM   #9
xxPIKExx's Avatar
Just do your suspension. If you do it right the first time, all at once, you should be ok. I've never had warranty work done to my suspension on anything I've owned, and even if something needed work there isn't anything overly expensive in there anyway
xxPIKExx is offline   Reply With Quote
Old 01-13-2014, 11:43 PM   #10
jayman33's Avatar
Depends on what part of the suspension. Parts that should last a good amount of time, (a arms, bushings, cv joints) Ford will replace, if they've been tampered with it will depend on that specific dealer on whether they want to honor some sort of warranty.
A boss.....
jayman33 is offline   Reply With Quote
Old 01-14-2014, 07:33 PM   #11
Compstall's Avatar
I didn't look through it thoroughly, .
Here's yer sign..
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 01-15-2014, 09:15 AM   #12
DallasStang77's Avatar
Warranty is coverage plus the mileage that's on the odometer at signing. Even if you bought the car with a 1,000 miles.
Old 01-16-2014, 10:01 PM   #13
Red Stallion 11's Avatar
All parts of the suspension are covered under the warranty. If you lowered the parts of the suspension that are affected may not be covered. Most of the stock suspension is junk that you want to replace anyways. The only thing under there that you should be concerned with not breaking is the electronic power steering rack, due to cost. BTW those are junk too. Ford replaced mine at 25k miles in a 2011 V6 that I traded in.
If you broke something then now you have to upgrade to stronger after market parts due to necessity. Having Ford fix it will be a waste of time because it will just break again in the future (explain it like that to the woman).
My thought process on that subject.
Red Stallion 11 is offline   Reply With Quote
Suspension question Raf63 2011-2014 Mustang GT 5 09-14-2012 04:04 AM
Suspension Poppavoltron 1979-1995 Mustang GT 3 03-12-2012 03:32 PM
suspension question Nashgizam 1996-2004 Mustang GT 9 02-18-2012 07:09 PM
aftermarket warranty. S197Miller 2005-2010 Mustang GT 5 07-28-2011 10:43 AM
Complicated suspension question Hm3grant 1996-2004 Mustang GT 3 07-26-2011 01:08 PM
10:01 PM
