Help with popping noise - Mustang Evolution
Old 01-20-2014, 10:44 PM   #1
11stangGT's Avatar
Region: Arkansas
2011 5.0 with k-springs.. When I back up and have the wheel turned (not while I'm turning) I get a pretty hard loud popping sound coming from the front end. The wheel has to be turned at least half way from what it seems. Doesn't do it every time but does it pretty often. Seems worse if I'm on an incline.. Any ideas?
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 01-21-2014, 12:46 PM   #2
bellski's Avatar
sounds like your strut mounts are shot.
2011 GT M6 Premium- Mechanical upgrades include: Boss 302 Intake, JLT CAI, JPC LT Headers, Off Road X Pipe, and mufflers, 410 Gears, Granatelli Hot Street Coil Packs, 93 Octane Ghost Cam Tune by Jon Lund,Eibach ProKit Springs,shocks, struts and sway bars, BMR LCA's, Strut Tower Brace, and adjustable Panhard Bar, Maximum Motorsports Camber/Caster Plates, Barton Shortshifter and bracket, Wilwood Superlight Brakes w/6 and 4 piston calipers, Steeda Spyders- 9-1/2X20 with 275/35 and 11X20 with 315/35 Nitto Invos.
bellski is offline   Reply With Quote
Old 01-21-2014, 12:48 PM   #3
11stangGT's Avatar
Region: Arkansas
Like I said not WHILE turning.. Already replaced the mounts. This is way louder and harder
Old 01-22-2014, 09:11 AM   #4
Maybe something isn't tightened properly. Could be a possibility that when you turn the strut is moving in and out of the bottom knuckle.
1ststang is offline   Reply With Quote
Old 01-26-2014, 05:12 PM   #5
scott_0's Avatar
a lot of the time, this noise is the sway bar end links, they aren't tight enough most likely
Sent from S4 using tapatalk
Old 01-26-2014, 11:51 PM   #6
ksnapp's Avatar
Region: Oregon
^ What they said, I would just re check everything =)
Kyle
ksnapp is offline   Reply With Quote
Old 01-28-2014, 12:55 PM   #7
Droidman86's Avatar
I'm having this same issue, already ordered I'm just waiting for it to arrive and see if that gets rid of the popping noise.
Droidman86 is offline   Reply With Quote
Old 01-28-2014, 02:31 PM   #8
11stangGT's Avatar
Region: Arkansas
Does yours do it while turning the wheel?
Old 01-28-2014, 02:34 PM   #9
Droidman86's Avatar
Yes, only does it while turning the wheel at very low speeds.
2012 Mustang 5.0
Steeda CAI, Boss Manifold, 3.73 Gears, E85, NX Wet 150 Shot, AED Tuned, LT Headers, Aluminum Driveshaft, Mcleod Twin Disc Clutch, KB Bap, N2MB wot box w/ window switch.
Old 01-28-2014, 02:45 PM   #10
11stangGT's Avatar
Region: Arkansas
Not what mine does.. Like I said in the opening post NOT WHILE turning but with the wheel turned. Ur issue is definitely strut mounts though.
Old 01-29-2014, 01:44 AM   #11
Red Stallion 11's Avatar
I had a similar problem in my old 11 3.7. I ended up being the power steering rack. Ford replaced it under the warranty. There are issues with the electronic racks.
Before you go to that extreme I would get underneath and start smacking things around with a rubber mallot, see if there is anything else going wrong under there.
Red Stallion 11 is offline   Reply With Quote
Old 01-29-2014, 10:55 PM   #12
11stangGT's Avatar
Region: Arkansas
When did yours do it exactly? Mine does it with the wheel turned about 3/4 and then start to back up, with the wheel stationary. It sounds like I have a 4wd and my cv axles are getting in a bind.
Old 01-29-2014, 11:31 PM   #13
mark_ash0426's Avatar
I started a thread about a somewhat similar problem but nobody was able to help me
My problem is that every time im driving and i go through like little road bumps my rear squeaks
My thoughts is it would be the panhard bar ?
Any thoughts guys ?
mark_ash0426 is offline   Reply With Quote
Old 02-06-2014, 07:11 AM   #14
42NATO's Avatar
I think it's your sway bar end links. I'm lowered with k springs as well and get an occasional loud pop when turning. I bought new end links off of AM just haven't put them on yet. They say on there that it's normal problem when lowering your car.
42NATO is offline   Reply With Quote
Old 03-23-2014, 12:43 PM   #15
I have a 96 cobra and am having a popping sound coming front the left rear end. Can feel it with your feet if sitting behind the driver. It seems to be worst when I am in first or second and am getting into it getting on the highway. Any ideas of what can be causing it?
missouri96cobra is offline   Reply With Quote
Hissing Noise JetLife 01GT 1996-2004 Mustang GT 14 12-03-2013 12:03 PM
Car still makes loud noise when going over bumps Coltonhess 1996-2004 Mustang GT 8 07-23-2013 09:35 PM
High pitched engine noise whine cjd_1986 2005-2010 V6 Mustang 4 01-16-2012 11:34 AM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 08:14 AM
06:01 AM
