Full Suspension Upgrade/Modification Research - Mustang Evolution
Old 01-22-2014, 07:06 PM   #1
JasnTX's Avatar
I'm calling on all for opinions please!
2014 5.0 Premium, Sterling Gray
MT/Track Pack/Brembo/3.73
Borla axle backs
For my first mods, I want to go with suspension. I want to get the stance down right. However, I prefer function over form. Meaning I require performance. I would like a balance or easy adjustability for street, strip and road course.
I'm on several groups and forums. I've read some information about springs (strut/shock or coilover), pan hard bar, camber/caster plates, UCA, LCA, relocation brackets, etc...
I'm requesting opinions. I'm torn between Maximum Motorsports "Grip in a Box" complete package vs. piecing together an assortment of different manufacturer parts.
Is this a pipe dream or a possibility??
Please tell me your opinions on any parts or packages with which you have knowledge or experience.
JasnTX is offline   Reply With Quote
Old 01-22-2014, 07:15 PM   #2
Meowmix's Avatar
Send a message via Skype™ to Meowmix
I have no idea but I'm intrigued, could you link the Maximum Motorsports kit?
Meowmix is offline   Reply With Quote
Old 01-22-2014, 07:36 PM   #3
blu
blu's Avatar
From a guy who just did full suspension, whether you go with a holistic kit (eibach, FRPP) or pieces/parts, you'll really want to get your wheels under 20 lbs each, or else the firmer suspension and the heavy wheels (e.g. Stock) will yield a 'lead sled' feel.
2011 GT Prem Kna Blu
"Quick like a Snake, light like a Fox. This remains the goal."
blu is offline   Reply With Quote
Old 01-22-2014, 07:42 PM   #4
JasnTX's Avatar
Wheels will also be on the lineup. I'm thinking TSW.
Old 01-22-2014, 07:51 PM   #5
JasnTX's Avatar
http://www.maximummotorsports.com/20...Box-P1443.aspx
Old 01-22-2014, 08:18 PM   #6
Meowmix's Avatar
Originally Posted by JasnTX View Post
Thank you for the link. That definitely looks nice. The drop is way more than I would want to go.
Been in the middle of the same discussion with myself tonight, I'm going Steeda 2011-14 Mustang Pro-Action & Sport Springs Suspension Package - Made in USA 555-8409 - Free Shipping! , then see what I want to do after that. I don't know if the koni's are better or worse, I know they're popular though.
Will let you know how it goes
Old 01-23-2014, 06:00 AM   #7
ThinBlueLine's Avatar
I'm getting full BMR suspension put on this AM and the entire following setup was recommended to me by the ford tech at BMR. All listed are BMR products unless noted.
LCA boxed non adjustable
Relo brackets
Adjustable UCA
UCA Mount
Adjustable panhard bar
Lowering springs
Gt500 strut mounts
Viking performance double adjustable shocks
Strange performance single adjustable struts
BAMA TUNED
LETHAL O/R H, GEN2 OVER AXLE PIPES & GT500's
DRIVESHAFT SHOP ALUMINUM DS W/ BMR LOOP
MGW SHORT SHIFTER
CDC CHIN SPOILER W/ BLACK BILLET GRILLS
BLACK JLT OIL SEPARATOR
ThinBlueLine is offline   Reply With Quote
Old 01-23-2014, 06:01 AM   #8
Meant to add he steered me away from spending money upgrading the sway bars. Said they're pretty substantial stock and unless you going hardcore autox you won't notice the difference.
BAMA TUNED
MGW SHORT SHIFTER
Old 01-23-2014, 07:06 AM   #9
JasnTX's Avatar
Thanks for the update. I'll be making calls to several suspension parts providers. I'm sure they're all going to pushe towards their products.
Old 01-23-2014, 08:41 AM   #10
Yea, BMR is who I was planning on using anyways so it was no big deal to me.
BAMA TUNED
MGW SHORT SHIFTER
Old 01-23-2014, 12:46 PM   #11
I'm currently running a full Roush kit, struts, springs, and sway bars, with bmr rear LCAs and adjustable panhard bar and I love the setup. It lowers the car about an inch which sounds small but it makes a big difference. The car is stiffer than stock but it is still comfortible as a daily driver. I really do like this set up. I didn't want too much of a drop because I'm in the Chicago area and the roads are horrible and really any lower would be awful.
vans5oh is offline   Reply With Quote
Old 01-24-2014, 09:09 PM   #12
HPFury's Avatar
I replaced my whole suspension but if I had to do it over I would get good coil overs, rims, tires first... Then replace other pieces as needed. Good luck.
HPFury is offline   Reply With Quote
Old 01-25-2014, 09:26 PM   #13
JasnTX's Avatar
I believe I've narrowed down a nice package...
Hotchkis springs
Koni adjustable shocks yellows
Ground control caster/camber plates
BMR PHB
BMR adj UCA
BMR LCA and relo brackets
Old 01-25-2014, 09:42 PM   #14
HPFury's Avatar
Consider getting a prothane lower control arm to finish out your setup. Congrats on your new suspension.
Old 01-26-2014, 07:19 AM   #15
TooSlow4U's Avatar
If you're looking at ground control cc plates, contact jay at hypermotive. Best customer service period!
TooSlow4U is offline   Reply With Quote
Suspension Write Ups ! Slow4V 1996-2004 Mustang GT 8 04-15-2013 08:51 PM
NMRA "Super 'Stang" rules and regulations rebeltx At the Track 4 03-06-2013 11:02 AM
Ways to reduce body roll and stiffen suspension geepoons 2011-2014 V6 Mustang 10 02-03-2013 09:36 AM
Lowering springs or full suspension kit? 08SteedaQ350 Mustang Wheels & Tires 7 10-16-2012 08:15 PM
full compound buff mystang50 1979-1995 Mustang GT 17 02-05-2012 04:16 PM
09:45 PM
