Coolant question - Mustang Evolution
Old 02-05-2014, 07:25 PM   #1
Evil2014GT's Avatar
Coolant question
Hey guys i may be overreacting, but i just wanted to make sure.
So after 2 months I finally got my car back from the body shop yesterday. Today however, i noticed that they put "green" coolant in the reservoir. They did have to drain the entire system to pull and replace the radiator mount, but I'm worried that the green coolant is gonna hurt something. I remember specifically that it came with Ford specialty "orange" from the dealer. Which from what i heard is basically the same thing as dexcool. Can anyone help?
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 02-05-2014, 08:25 PM   #2
As long as all of it was changed you're fine. I wouldn't run dexcool in my enemy's car...
Sent from my massive johnson.
Old 02-05-2014, 09:18 PM   #3
Evil2014GT's Avatar
Good deal. Thanks man. Is the ford orange basically dexcool? Just wondering what I should replace it with in the future. Should i go back to the ford orange, or stick with the green?
Old 02-05-2014, 10:50 PM   #4
gtstyles2's Avatar
I know dexcool is good for 100k and I believe the manual says the factory fluid is good for 100k as well. I don't think the green stuff belongs, plus it sure as hell isn't good for 100k, I would definitely check the manual and bring it to the attention of the body shop
Old 02-05-2014, 11:05 PM   #5
Loc: Austin,TX
This happened to me one time on my Pontiac. I made them switch it out but it wont hurt anything.
Old 02-06-2014, 02:42 AM   #6
ScrewedUp's Avatar
This can cause issues if they didn't drain fill properly. Look at the fluid and see if you see thick gel or anything floating around. I did this years ago when I was learning how to work on cars. I drained and filled but some was still in the block. It turned into gel when I mixed it. I had to drain and flush several times and use a cleaner before adding fluid again. PITA.
ScrewedUp is offline   Reply With Quote
Old 02-06-2014, 05:27 AM   #7
bucko's Avatar
I'd ask what specific coolant was used, as it may not be compatable with the alloys used in the engine block.
Most coolants advertise they are "safe" for all engines, and can be mixed/matched, but I'd ask the shop what they used just to be sure.
Old 02-06-2014, 09:06 AM   #8
Evil2014GT's Avatar
Good deal. I will call them today and find out. It has to go back anyway because the exterior temp sensor isnt working either.
They did a great job on the body though!
Old 02-06-2014, 11:00 AM   #9
gtstyles2's Avatar
I was checking the manual and it never specified on which to use as long as it's a 50/50 mix
Old 02-07-2014, 03:17 AM   #10
sunnytan06's Avatar
Damn. That's very nice. Where do u get the ideas from? Lol and how much it cost you?
sunnytan06 is offline   Reply With Quote
Old 02-07-2014, 04:38 AM   #11
bucko's Avatar
Yep, mine too. Looks like all the new coolants sold today are compatable with each other, and with engine alloy types.
Old 03-06-2014, 06:56 AM   #12
Mok
I'm a bit low on coolant and need to top off. I was going To get the dexcool Just worried it will damage my engine. Anybody here run into any problems by doing so?
Sent from my VS980 4G using Mustang Evolution mobile app
Mok is offline   Reply With Quote
COOLANT LIGHT WTF KraftDinner 1996-2004 Mustang GT 3 01-25-2014 07:09 PM
Coolant through TB needed? Otlaw80 1979-1995 Mustang GT 3 02-01-2012 09:43 PM
Coolant light problem Albo22 1996-2004 Mustang GT 2 01-09-2012 01:04 PM
Coolant Type crkmonzo 1979-1995 Mustang GT 3 09-11-2011 12:18 PM
horrible coolant leak...ideas? shustwit Pre-2005 V6 Mustang 3 06-30-2011 12:48 PM
03:11 AM
