Solved all the MT82 problems with new Clutch Kit - Mustang Evolution
Old 02-06-2014, 03:59 PM   #1
MT82 Manual transmission owners: Recently replaced the flywheel, clutch, throwout bearing (slave cilinder) and pressure plate. ALL the notchiness and difficult shifting issues are gone forever.
At last I can enjoy shifting my car at high and low RPM's...
In my case I got installed the McLeod RXT Clutch kit with the braided hidraulic cable and exedy throwout bearing. It has a great grip, smoother pedal than the stock one.
It likes more RPM's to shift from a stop, but that is something you can get used to.
An important issue is the unsprung hub, twin disc setup this kit has. It makes a loud growling noise between 1500 and 1800 RPM's when accelerating. It only happens when "lugging" the engine, or going on 3, 4 or 5th gear on low speeds. If you rev our engine above 2000 on all of the gears you wont hear the noise. McLeod says it is normal and a lot of research have shown a lot of people have this problems when going with twin discs and unsprung hubs. This is because the springs (like the one on the stock unit) cushions the vibrations of the crankshaft to the transmission.
My recommendation: If you have a MT82 transmission, get a good SPRUNG aftermarket clutch. It will solve all of your problems and wont have the noise issue.
If you have a high HP car, like to go the strip often, doesn't bother for the noise....go with the RXT, the grip and feel is great.
mustangcito is offline   Reply With Quote
Old 02-06-2014, 04:01 PM   #2
Forgot to mention that also the McLeod steel flywheel was installed. When using this kit is almost required to install a new flywheel, because of the clutch disc different diameter.
Old 02-06-2014, 08:53 PM   #3
Thomas11CS5.0's Avatar
Glad to hear I hate my getrag pos
Thomas11CS5.0 is offline   Reply With Quote
Old 02-06-2014, 09:22 PM   #4
LuisBlackGT's Avatar
The only gear that is notchy/rough for me is second. is it the same for everyone else?
LuisBlackGT is offline   Reply With Quote
Old 02-07-2014, 09:26 AM   #5
KARgt13's Avatar
Most people complain about the 2-3 shift; however, my only issue is the same as your issue. And it's not 100% of the time, more like 60-70%.
KARgt13 is offline   Reply With Quote
Old 02-07-2014, 09:51 AM   #6
KSconvert's Avatar
2nd is a bit clunky for me, and 3rd is every once in a while when I don't line it up perfectly.
2014 GT MT aka: Ruffian-
3.73 gears, Roush AB, BBR O/R x-pipe, JLT intake, BMR panhard bar, BMR lowers and brackets, FRPP 47# injectors, Lund E85 tune, SR springs, MGW shifter, 416rwhp/393rwtq
KSconvert is offline   Reply With Quote
Old 02-08-2014, 08:06 AM   #7
Ravnus's Avatar
Mine improved drastically with a MGW shifter...much cheaper.
Ravnus is offline   Reply With Quote
Old 02-11-2014, 01:37 PM   #8
I had to change it because it came to a point where I almost cannot get the car into any gear. The clutch pedal was also engaging half an inch from the floor. Ford warranty service said this was "wear parts" and that I needed to cover the costs. This is the first time in my life a clutch-pressure plate on a car with 21K miles on it fails. After taking the transmission down, all was OK including the clutch. The pressure plate was indeed "suspicious". I strongly believe this MT82 is not as bad as all of us thought it is. The problem here is the clutch/pressure plate/throwout bearing assembly. I believe the stock pressure plate is not allowing the input shaft to disengage completely, thus making the shifting difficult (and actually making the synchros suffer in the long run).
Old 10-24-2014, 10:00 AM   #9
tacoma96's Avatar
Region: Rhode Island
Ok, So I have read changing the transmission oil helps smooth it out so it that not really true? The article I read didn't say what to change it to either.
tacoma96 is offline   Reply With Quote
Old 10-24-2014, 12:34 PM   #10
Deerslayer's Avatar
We are going to try the Spec Stage 3+ clutch with aluminum flywheel. It is good to 875 tq at the flywheel and is a sprung clutch. Tested a McLeod in another car and just as you have stated. Def takes getting used too taking off in traffic and could hear a bit of noise, but it did feel like a completely different drivetrain with that setup. The OEM clutch is fine in this car right now, but I am sure it wont last long with the setup we are running.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 10-24-2014, 12:35 PM   #11
Rapinator126's Avatar
My stock clutch lasted untill I decided to swap it with 700+
People run 800 on stock clutch with no problems.
Old 10-25-2014, 02:30 AM   #12
The only other thing I changed out was the pilot bearing ,for $35 worth it with the tranny out.also clutch pedal is like 5x lighter,but cured all shifting issues.
chefron50 is offline   Reply With Quote
Transmission fluid for the T5 Combatman 2005-2010 V6 Mustang 18 08-05-2013 04:23 AM
Installed new clutch...new problems Jukens 2011-2014 Mustang GT 11 11-02-2012 10:50 AM
04 cobra shifting problems NickGeezy General Mustang Discussion 7 09-21-2011 10:41 AM
BBP clutch kit... TaylorF25 General Mustang Discussion 1 08-26-2011 03:20 PM
BBP clutch kit zrider07 1996-2004 Mustang GT 0 08-20-2011 06:01 PM
11:40 PM
