Steeda Adjustable UCA/Mount HELP!!! - Mustang Evolution
Old 02-08-2014, 08:12 AM   #1
2013fiveO's Avatar
For those that installed the Steeda adjustable UCA WITH the Steeda chassis mount did you use the stepped spacers with the new UCA and mount? What about the small stepped spacers?
There is debate on this throughout the forums so i'm trying to see who here has installed with or without the spacers. Steeda is closed for the weekend.
I am going to install this setup tomorrow. I greased and preinstalled the arm in the mount today with the spacers. It doesn't make sense not to use them otherwise there will be a gap on each side of the poly bushings in the mount.
Any help is greatly appreciated.
2013 GT 6MT, 3.31s, Brembo Pckg, Sync
Mods: AED Tune,Boss 302 IM, BBK 85mm TB,Kooks SS Shorty Headers,HF Cats,Alum 1pc DS,Hotchkis Subframe Connectors,Steeda CAI,Roush Axlebacks,Barton Shifter,SR Clutch Line,Boss Oil/Trans Coolers,SVT Fan,Steeda Sport Springs/LCAs/UCA/Shifter Bracket/HD Motor Mounts,BMR LCA Relo Brackets,Koni Shocks/Struts,GT500 Strut Mounts,JLT Oil Sep,Hood Struts,GT500 Spoiler,MMD Taillight Trim,OEM Leather Seats,MT Street Comps on black AMRs,MT ET Street Radial IIs on black Bullits(track duty).
2013fiveO is offline   Reply With Quote
Old 02-08-2014, 08:46 AM   #2
I believe the spacers are for 11-14 vehicles for the purpose you mentioned. 05-10 vehicles don't need the spacers. I would use them.
Mikeyt03 is offline   Reply With Quote
Old 02-09-2014, 01:26 PM   #3
2013fiveO's Avatar
Thanks, yeah I used the spacers. The instructions for the mount say to. Installed today no issues. There are guys out there that didn't use them because they claim Steeda said not to. I went with what made sense.
Old 02-09-2014, 01:47 PM   #4
I think it depends on whether your using the stock mount or if you got the their mount. Do you have any added nvh now?
Old 02-09-2014, 01:53 PM   #5
2013fiveO's Avatar
the spacers are definitely for the stock mount but also for the Steeda mount. I switched from a Steeda nonadjustable uca and stock mount to this new setup. absolutely no added nvh. it is actually less noisey. less clunking and I was able to get my pinion angle just right.
Old 02-09-2014, 07:21 PM   #6
tj@steeda's Avatar
I haven't had much experience with the install of this part. I have an email into our installation dept. and I will have an answer for you soon.
If we indicated it in the instructions ... good chance you should have used them.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Steeda tune dugemac General Mustang Discussion 6 02-26-2014 09:41 PM
For Sale: Steeda Tri-Ax, Shifter Bracket & Bump Steer Kit, GT500 Spoiler, GT Trunk Panel larrimus Mustang Parts for Sale and Wanted 7 01-16-2014 04:44 AM
2014 Steeda GT500 Wide-Body Conversion ... Own it today tj@steeda 2011-2014 Mustang GT 25 11-22-2013 10:53 AM
Coyote Build Lists Napoleon85 2011-2014 Mustang GT 104 03-27-2013 07:31 PM
07:20 AM
