Stock Drive Shaft vibrations - Mustang Evolution
Old 02-08-2014, 10:26 PM   #1
After I had my 3:73 installed i have had issues with the Drive shaft vibrations all the way trough the RPM range. I took it Ford once all they did was an oldschool 2 hose clamp balancing. Well that worked but I developed a bad squeak or rotational chirp when cold that went away as it warmed up. That noise was attributed to the dust shield on the pinion seal that was fixed and now the Drive shaft vibrations are back. Does anybody have issues with the drive shaft needing to be re balanced after being unbolted from the pinion flange?
THUNDERMETAL is offline   Reply With Quote
Old 02-09-2014, 01:54 AM   #2
NoSlo5oH's Avatar
Not rebalanced, but it may need to be rotated 90 degrees.
NoSlo5oH is offline   Reply With Quote
Old 02-09-2014, 10:30 AM   #3
This type of shaft is quite sensitive to knocks and bangs. If it has been dropped, for example, it's supposed to be replaced. Hose clamp balancing, in 2014, really? Make further inquries.
Old 02-09-2014, 03:02 PM   #4
My thoughts exactly. I'm going to Ford tomorrow and starting politely at first to request a new (because it's under warranty) Drive Shaft
Old 02-09-2014, 07:14 PM   #5
bamf70's Avatar
I agree that the "fix" they implemented is far from the best way to correct the issue. IMO, if you changed the gear you should have done an AL drive shaft. The stock 2 piece is heavy and weak by comparison. You end up saving ~ 20 lbs of unsprung weight which is worth close to 2 tenths. I went with a DSS one, but $700 is a bit steep when compared to what I paid for my Ford Racing drive shaft for my 2002. That being said, I'm glad I spent the $, it's totally worth it IMO.
bamf70 is offline   Reply With Quote
Old 02-09-2014, 07:34 PM   #6
The Dynotech. Drive Shaft is in the near future, but until then I want Ford to fix this issue as a mater of principle. Have you had any issues with wheel hop?
Old 02-09-2014, 07:40 PM   #7
bamf70's Avatar
No wheel hop, but I've done the full suspension on my car.
I agree with the principal part, but sometimes, it's just not worth the headache....
Old 02-09-2014, 08:19 PM   #8
The stocker is sometimes noisy but it's still pretty strong. Lots of suprcharged car run stock. It is fuss proof because it doesn't need any measuring for pinion angle and unless bent, it's usually vibe free.
Old 02-09-2014, 08:25 PM   #9
duly noted. I've got a FRPP suspension I installed but still have stock Control arms for quietness.There is a little bit of wheel hop only seen in the Burnout mark.
Old 02-09-2014, 08:37 PM   #10
bamf70's Avatar
I wouldn't worry about NVH by changing the LCAs. I have Steeda billet poly/spherical LCAs and the competition (spherical) upper and I have 0 added NVH....but you do want to drench the spherical side in dry lube before installing them and then go back periodically to make sure they stay lubed.
I also have Steeda Ultralite springs and Koni sports all around too. Unfortunately, I'm still on my stock tires and at an avg temp of high 30s here in NoVA, spinning happens but no wheel hop.
Alabama Baugh Ford Drive Clanton, AL Cruise In Oct 8 SpectorV Regional Mustang Discussion 1 10-04-2011 12:25 PM
Installing a supercharged 3.8 from a thunderbird SC into my 99 mustang skip318 Pre-2005 V6 Mustang 12 10-01-2011 09:03 PM
Fastest stock 5.0 wnt2gofst 2011-2014 Mustang GT 2 09-01-2011 05:23 PM
First Long Drive skyline247 2011-2014 Mustang GT 28 06-28-2011 06:19 PM
03:25 AM
