Right rear rattles at slow speeds after lowering - Mustang Evolution
Old 02-09-2014, 05:39 PM   #1
20bmr14's Avatar
Guys I lowered my 2014 GT on boss 302 adj shocks and struts with H&R super sports and now the right rear rattles if I go slow over broken pavement. Lemme know if anyone has had the same problem.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 02-09-2014, 06:49 PM   #2
Region: Oregon
its only rattling over bump and cracks at slow speeds? I would make sure everything is tightened down properly.
Instafire is offline   Reply With Quote
Old 02-11-2014, 06:02 PM   #3
20bmr14's Avatar
yeah I went back and put a wrench on every bolt. Tightened RR shock. I did adjust the rear shocks down 1 notch and it seemed to help but not eliminate. It sounds like the trunk mat is rattling (already removed it) when I go over cracked pavement. So annoying!
Old 02-11-2014, 06:59 PM   #4
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Do you still have the stock sway bars endlinks? The oem rubber bushings are notorious for going bad and creating a thunk or rattle type sound over rough road and bumps.
Sent from my HTC One X using Mustang Evolution mobile app
2012 Kona Blue 3.7L V6:
2.3 turbo build BigRed1781 2.3 Mustang 133 04-30-2016 10:46 AM
Right Rear Squeaking After Lowering KARgt13 2011-2014 Mustang GT 42 06-18-2013 11:41 AM
NMRA "Super 'Stang" rules and regulations rebeltx At the Track 4 03-06-2013 11:02 AM
For Sale: BMR Rear Lowering Springs 05-09 MavyMav Mustang Parts for Sale and Wanted 22 12-09-2012 06:42 AM
01:02 AM
