Engine knock 2012gt - Mustang Evolution
Old 02-12-2014, 08:19 PM   #1
Flynavy's Avatar
Engine knock 2012gt
I've got a 2012 gt manual with 17000 miles. Just switched to synthetic. No mods whatsoever. I noticed a loud knocking when I accelerate that I've never heard before. It's right around 3000 rmp. I was thinking it might be because I just put 87 in, I don't know what the previous owner ran. Also, the traction control kicked in when I got the tires spinning on a wet road the other day. It shook the rear end pretty good. Maybe something came loose underneath? Any help would be appreciated.
Flynavy is offline   Reply With Quote
Old 02-12-2014, 08:36 PM   #2
Adogg's Avatar
Bring to dealer ASAP!
Don't hate....... appreciate
Old 02-12-2014, 08:56 PM   #3
Flynavy's Avatar
Got an appointment with the dealer tomorrow. Hopefully it's not something terrible.
Old 02-12-2014, 09:24 PM   #4
Adogg's Avatar
Hopefully not where did you get the oil change done?
Old 02-13-2014, 07:11 AM   #5
Flynavy's Avatar
I did it myself. I don't think that's it, I've been changing oil for a while haha
Old 02-13-2014, 08:18 AM   #6
Grabber Blue5.0's Avatar
What oil? Weight? Filter?
Old 02-13-2014, 09:45 AM   #7
Flynavy's Avatar
Synthetic 5w-20. Fram filter. The dealer hooked it up and said everything was fine. The knock is a little softer today. I don't know if that's because I'm getting used to it.
Old 02-13-2014, 09:47 AM   #8
Flynavy's Avatar
I might have to look into a mechanic in the area or take it to another dealer. I bought it used about a month ago. There were no reported issues with it.
Old 02-13-2014, 11:53 AM   #9
PMDMustang13's Avatar
Region: Nebraska
Absolutely without a doubt take it to a dealer assuming you still have the factory warranty. Make sure you have the proper amount of oil in there and put in what the oil cap says to as far as viscosity and that the oil meets the minimum Ford Specification. Too much oil can be harmful too.
I don't know if 87 octane is OK per the manual. I use 91 minimum and try to use 93 whenever possible.
You probably already know but the rear end shake is called wheel hop and is common in wet conditions especially with stock suspension.
Good Luck I hope it is nothing. However an engine knock has to be something.
2013 Mustang GT Premium, Deep Impact Blue, GT Track Package, Recaros, Ext. Acc. package 1, All Weather Mats, GT500 Axle backs, Airaid CAI, BMR Rear LCAs, BMR Relocation Brackets, JLT Oil Separator(s), Barton 2 Post Shifter Bracket, Steeda Motor Mounts, Barton Short Throw Shifter, JHR Clutch line, BMR adj. UCA and Mount, Kooks 1 3/4 headers with catted H, DSS Al Shaft with BMR Loop
PMDMustang13 is offline   Reply With Quote
Old 02-13-2014, 01:59 PM   #10
Flynavy's Avatar
Thanks for the info! I'll do what I can from the garage and definitely take it to another dealer.
Gutting cats BadAssStang07 2005-2010 Mustang GT 8 12-07-2013 09:24 AM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Think i found out whats going on Maddhatter88 1979-1995 Mustang GT 30 06-08-2012 02:04 PM
Service Engine Soon Light???? wilson_j307 Pre-2005 V6 Mustang 2 03-03-2012 12:41 PM
Engine swap question!! Tominkc 1996-2004 Mustang GT 1 02-09-2012 12:15 AM
03:53 AM
