Is anybody running this set up in a 2010 GT? - Mustang Evolution
Old 02-14-2014, 04:50 PM   #1
Devildogstang's Avatar
62mm throttle body
Ford Racing intake manifold
Ford Racing cams
Headers
Xpipe
Axle back exhaust
Dyno'd
I'm curious on the HP output y'all got. Thanks.
Devildogstang is offline   Reply With Quote
Old 02-16-2014, 11:34 AM   #2
dudley279's Avatar
I had an 05 GT 3V, CAI, CMCV deletes, ford racing cams, LT headers w/ o/r x pipe, and a dyno tune, with clutch, flywheel, aluminum DS 4.10s blah blah. All motor on 93. Made 348/340 peak power at 6600rpm peak tq at 4300
dudley279 is offline   Reply With Quote
Old 02-16-2014, 11:54 AM   #3
2 Stangz's Avatar
Region: Nevada
Wow, not bad at all. Welcome to Mustang Evolution.
Old 02-16-2014, 12:45 PM   #4
dudley279's Avatar
Thank you sir! It was my baby until I got a wild hair up my *** and sold it for a '13 5.0. Miss it a lot but love my coyote now!
Old 02-17-2014, 09:15 AM   #5
Thanks. Yeah I've seen lotsa numbers on 05's but I haven't seen any on 10's.
Old 02-17-2014, 09:35 AM   #6
dudley279's Avatar
I would imagine it'd be fairly similar. Possibly even a little more since the 2010s had a little more to begin with. Motor in mine only had 12k on it which likely helped (swapped in a motor from a totalled 07). Original was toast. 3V lash adjusters don't seem very reliable.
Old 02-17-2014, 09:40 AM   #7
Essentially you'll see the same gains from a 2010, as he did from his 2005. I believe the only performance differences in the 2005-2009 cars and a 2010, is the 2010 has the Bullitt tune, and a different Intake Manifold. So if you end up changing both the tune, and the IM, you'll see the same end HP.
2014 Mustang GT Premium - Flowmaster Outlaw Axle-Backs, 125 Shot NX Plate. - Totaled (not my fault)
2014 Mustang GT Premium w/Track Pack - Stock... for now.
cstone94 is offline   Reply With Quote
Old 02-17-2014, 11:09 AM   #8
2 Stangz's Avatar
Region: Nevada
+1
Old 03-02-2014, 02:51 PM   #9
Just bought my 2010 with pretty much everything you have listed, dyno print out that came with the car reads 341rwhp just passed 6K rpm, torque peak was a little disappointing at only 315 around 4800rpm but the curve isn't terrible. Was done around 68 degrees and under 30% humidity and just a hair under 1K' elevation.
2010 Sterling Grey Premium GT 3.73 axle 5spd
FRPP Cams, intake, TB and CAI
BBK LT headers, fuel rail and UD pullies
Hurst Shifter
Lowered with upgraded rear suspension
Galaxie64 is offline   Reply With Quote
Old 03-02-2014, 02:56 PM   #10
dudley279's Avatar
I'm sure a lot of your TQ has to do with the tune on it. I picked up 20rwtq just by changing from the BAMA tune to a custom dyno tune(by no means dogging BAMA, great tunes, just can't beat real world dyno tuning IMHO). Still great #s though! Almost identical to my old 3V. I was tuned on a 35° day at nearly 300ft elevation. That may play a factor as well. To the OP, think you've got some pretty consistent results here bud. Enjoy your ride!
Old 03-04-2014, 12:09 AM   #11
saleenfanning's Avatar
Well there u have it, Galaxy64 just gave u EVERYTHING u needed! Nice detail brotha, temp, humidity, etc are BIG factors when assessing a dyno sheet!
saleenfanning is offline   Reply With Quote
Old 03-22-2014, 01:02 PM   #12
TheBlackPearl's Avatar
Same mods should get you close to the same power numbers.
TheBlackPearl is offline   Reply With Quote
07 gt running lean both banks? mattthegreat 2005-2010 Mustang GT 12 03-01-2014 11:41 AM
2010 Mustang GT - need mod suggestions kwa94 2011-2014 Mustang GT 29 10-07-2012 09:26 PM
Battery dead in 2010 GT IHBA 2011-2014 Mustang GT 3 01-30-2012 10:10 PM
02:43 PM
