need torque specs for exhaust bolts - Mustang Evolution
Old 02-15-2014, 04:55 PM   #1
KSconvert's Avatar
Like the title says. I got a BBR O/R x-pipe from latemodel and it came with no instructions, which is fine, but I have no idea what to torque the flange bolts to. I have a rented needle torque wrench, so it will probably be off either way but I'd feel better knowing. I'm headed to my girl's house to do this now, so the quicker the better.
2014 GT MT aka: Ruffian-
3.73 gears, Roush AB, BBR O/R x-pipe, JLT intake, BMR panhard bar, BMR lowers and brackets, FRPP 47# injectors, Lund E85 tune, SR springs, MGW shifter, 416rwhp/393rwtq
KSconvert is offline   Reply With Quote
Old 02-15-2014, 05:16 PM   #2
Grabber Blue5.0's Avatar
Good-n-tight
Old 02-15-2014, 05:25 PM   #3
PMDMustang13's Avatar
Region: Nebraska
Let me look and tell you what my Kooks instructions said. Now keep in mind this would be for my 2013 which should not make a difference but I don't want to give you bad advice either.
Good luck using a torque wrench unless you dropped the K frame or have the motor out from what I heard.
So here you go>>>> 18 ft-lbs for the studs in the block. Then 2 stages with stage 1 to 18 ft-lbs and then stage 2 is to 24 ft-lbs but there is a rotation/sequence required for tightening.
Install new gaskets, the LH exhaust manifold and 8 new nuts.
Tighten nuts in the sequence shown in 2 stages.
Stage 1: Tighten to 24 Nm (18 lb-ft).
Stage 2: Tighten to 32 Nm (24 lb-ft).
2013 Mustang GT Premium, Deep Impact Blue, GT Track Package, Recaros, Ext. Acc. package 1, All Weather Mats, GT500 Axle backs, Airaid CAI, BMR Rear LCAs, BMR Relocation Brackets, JLT Oil Separator(s), Barton 2 Post Shifter Bracket, Steeda Motor Mounts, Barton Short Throw Shifter, JHR Clutch line, BMR adj. UCA and Mount, Kooks 1 3/4 headers with catted H, DSS Al Shaft with BMR Loop
PMDMustang13 is offline   Reply With Quote
Old 02-15-2014, 05:35 PM   #4
Region: Nebraska
Here is for the left side. I would think the other would be similar.
I can't upload so here>> top middle rear, bottom middle rear, top middle front, bottom middle front, top rear, bottom front, top front, bottom rear.
Good luck and take your time and try to enjoy it.
Old 02-15-2014, 05:38 PM   #5
KSconvert's Avatar
I'm talking about the flange bolts where the stock manifolds meet the mid-pipe.
Old 02-15-2014, 05:48 PM   #6
Region: Nebraska
per my manual 2013 5.0 the cat pipe to the manifold is 89 in-lb alternating increments at each pipe until 30 ft-lbs
Your about ready to take it for a spin.
Old 02-15-2014, 06:16 PM   #7
Deerslayer's Avatar
In a year or so when you need to take them off, you will think you must have torqued them to 200ft lbs
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 02-15-2014, 06:17 PM   #8
KSconvert's Avatar
Do you know what size socket? I'm trying 15 and 14mm and neither seem to be working.
Old 02-15-2014, 06:27 PM   #9
KSconvert's Avatar
Well damn. It's a 15 and stuck. Also not giving back my socket. Any tips?
Old 02-15-2014, 08:20 PM   #10
Deerslayer's Avatar
Were you putting it back on or taking them off. I replaced ours with hardened nuts & bolts. Removing one, it rounded the nut and I finally got it off using a universal socket. (like a bolt out socket)
Old 02-15-2014, 11:22 PM   #11
Region: Nebraska
Hammer and or prybar
Old 02-16-2014, 04:31 AM   #12
KSconvert's Avatar
I got 3 of the 4 nuts off but the outside passenger bolt is angled towards the body and is impossible to get a grip on from the engine bay. I might be able to get it with a swivel socket and a breaker bar but it will be very tight. I gave up for the night since I have work at 5am. Also the 2-ton jack I bought can't even get one wheel off The ground, so I had to use the scissor jack. Thing takes forever.
Old 02-16-2014, 07:46 AM   #13
Region: Nebraska
Yes if I remember right that is the hardest one and the one that requires many long extensions and removal of the battery and battery support. The others can be accessed, removed, and re-installed from under the car if I remember correctly.
Good luck.
Old 02-16-2014, 01:08 PM   #14
It's exhaust not an engine lol. Tighten it until it's nice and tight then maybe a 1/4 turn more.
Old 02-16-2014, 02:07 PM   #15
Deerslayer's Avatar
The top passenger one requires about 20" of extensions. You remove it from above your engine. Ours rounded and I even twisted an extension and broke it. I thought it was toast, but got a "bolt out" head on it and got it to break free. I replaced the studs and nuts on the stock mid pipe with some grade 5 bolts/nuts when we installed the Off Road X Pipe.
If you round the head, get a set like this or similar and it will come off.
Old 02-16-2014, 02:59 PM   #16
KSconvert's Avatar
I have about 22" worth of extensions but 19" of them are from a different set and don't fit together well at all. Hopefully I'll be able to give it another go tonight and see if I can't get The battery tray off.
Old 02-16-2014, 04:07 PM   #17
Region: Nebraska
That is piece of cake. Then you will get to the top passenger bolt. Go get some extensions or borrow some and get it done.
Old 02-17-2014, 10:55 AM   #18
KSconvert's Avatar
I already had the extensions, lol. I ended up actually using a 16mm socket for the top passenger nut. Didn't even take 30 seconds, lol. The 15mm I had been using rounded it out quite a bit.
Finally ended up taking me about 5 hours. About an hour of that was just getting the battery tray out and breaking the O2 sensors loose, another hour was because I got ahead of myself and didn't put the x-pipe together, instead I tried installing each piece individually, so I had to take it all out and put them together off the car, and another 30 was me trying to figure out how the mid-pipe clamps went back on lol.
Old 02-17-2014, 01:47 PM   #19
Region: Nebraska
I totally understand how it takes more time than you plan for or what the installation instructions sometimes call for. It always takes me at least 2 to 3 times more than it probably should.
So now that your done how does it sound to you?
Old 02-17-2014, 02:19 PM   #20
KSconvert's Avatar
It's much louder than I anticipated with the Rush AB. It cackles and pops much more, and flat out screams if I get on it a little more than usual city driving. I'll see if I can get a video up soon.
Old 02-17-2014, 02:25 PM   #21
Region: Nebraska
You did get an updated tune for the offroad X pipe right? If not that might be why it is cackling and popping more. Un-burnt gas in the exhaust will do that.
Old 02-17-2014, 03:04 PM   #22
KSconvert's Avatar
Yes I'm running BAMAs 89 street tune that clears the CEL for no cats. I guess it's not more quantity, just more audible now. I've heard a lot of people complain about the smell with no cats, but I love it. I swear I was born at a drag strip.
exhaust
2011 3.7L V6 6R80 to MT-82 swap completed 3.7Cyclone 2011-2014 V6 Mustang 17 12-24-2014 01:00 AM
motor mount bolts squeaking gblegal 2011-2014 Mustang GT 5 11-11-2013 07:44 PM
Strut Tower Brace Bolts Blakhwk Pre-2005 V6 Mustang 21 06-14-2013 09:48 PM
What it takes for forced induction and much more... dreamstang 1979-1995 Mustang GT 2687 10-31-2012 12:50 PM
Need torque specs dhktactical Pre-2005 V6 Mustang 8 05-04-2012 01:13 PM
09:50 AM
