AEROFORCE GAUGE A/F Ratio? - Mustang Evolution
Old 02-17-2014, 10:02 AM   #1
2013fiveO's Avatar
I'm going to install an Aeroforce Interceptor gauge and I'm wondering what my A/F ratio should be with a Bama 93 race tune, boss im, bbk 85mm TB, and stock air box.
I know there is a safe # range. If someone could explain please do. Thanks!
2013 GT 6MT, 3.31s, Brembo Pckg, Sync
Mods: AED Tune,Boss 302 IM, BBK 85mm TB,Kooks SS Shorty Headers,HF Cats,Alum 1pc DS,Hotchkis Subframe Connectors,Steeda CAI,Roush Axlebacks,Barton Shifter,SR Clutch Line,Boss Oil/Trans Coolers,SVT Fan,Steeda Sport Springs/LCAs/UCA/Shifter Bracket/HD Motor Mounts,BMR LCA Relo Brackets,Koni Shocks/Struts,GT500 Strut Mounts,JLT Oil Sep,Hood Struts,GT500 Spoiler,MMD Taillight Trim,OEM Leather Seats,MT Street Comps on black AMRs,MT ET Street Radial IIs on black Bullits(track duty).
2013fiveO is offline   Reply With Quote
Old 02-17-2014, 11:00 AM   #2
On an N/A Application, at WOT, I believe lower 13's is where you want to be.
2014 Mustang GT Premium - Flowmaster Outlaw Axle-Backs, 125 Shot NX Plate. - Totaled (not my fault)
2014 Mustang GT Premium w/Track Pack - Stock... for now.
cstone94 is offline   Reply With Quote
Old 02-17-2014, 11:05 AM   #3
2013fiveO's Avatar
Thanks for the reply. Yeah I have read different opinions ranging from 12.5 at WOT to 14 at cruising. Just trying to see what everyone has to say. I have had my Bama tune updated once already for running too rich and just want to be sure it is safe. I mainly bought it for the shift light feature even though reviews say it isn't that bright. But it's a good looking gauge and has good features.
Old 02-17-2014, 11:19 AM   #4
bucko's Avatar
Air fuel ratios are measured using "stoich". In a perfect world of fuel/air mixture, you'd want to see a 15:1 ratio. Anything higher that this is considered to be towards lean, and lower is considered towards rich. It would be best to fall into the rich side rather than lean. Most A/F guages I've had (using a ScanGuage II plugged into the OBD 2 port) has shown me readings of 13.8 to 14.2 on my Ford f150 equipped with a 4.2 V6.
If your bored, and looking for some reading material, head here:
Air–fuel ratio - Wikipedia, the free encyclopedia
Old 02-17-2014, 11:50 AM   #5
2013fiveO's Avatar
Awesome thanks for the info and link. The wife is watching a show so I've got some time to read!
Old 02-17-2014, 01:05 PM   #6
Good info. Also remember that the leaner, the more power you'll make. Too lean, and you'll detonate and break something. It's essentially safer to run too rich as opposed to running too lean.
Old 02-18-2014, 09:53 AM   #7
Site Sponsor
Sponsor
AMWill's Avatar
If you're using the Aeroforce interceptor gauge, it's a lot easier to read your Air/Fuel ratio in lambda. You can setup the gauge to read lambda from your factory wideband sensors, as this what they normally measure Air/Fuel in anyways.
When you're idling or cruising, you should see Lambda honing in on 1. When at WOT, you should see between .82-.84 Lambda.
Lambda is easy because you don't have to worry about what stoich point your fuel requires when calculating acceptable air/fuel ratios. Weather your gasoline has 10% ethanol, or 15%, or even 0% ethanol, you should still be looking for those same Lambda points.
Hope this helps!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 02-18-2014, 10:00 AM   #8
2013fiveO's Avatar
Hope this helps!
Shane
Shane, thanks for the reply. Great info, I'll look into it.
Old 03-04-2014, 03:24 AM   #9
2013fiveO's Avatar
OK I got the gauge installed. I am monitoring CMD AF Ratio. At idle it fluctuates between 13.8 and 14.2. At WOT it's at a constant 11.8. Is this ok?
Also, I can't get the gauge to display lambda. When I select it, it will scan lambda for a second, not display a number, and then reboot. Am I missing something? Does anyone know how to set this guage to read lambda? Thanks.
Old 03-04-2014, 04:53 AM   #10
put it in frat mode
El Fufi is offline   Reply With Quote
Old 03-04-2014, 09:18 AM   #11
2013fiveO's Avatar
Ok I think I found the answer. Another forum mentioned scanning Equiv Ratio B1/B2. I tried that and I guess it is reading lambda. As AMShaneLesky mentioned in a previous post, at idle it is honing around 1, and at WOT I'm getting .83
So I'm assuming everything is good. .83 x 14.64 = 12.15 at WOT.
2005 gt cluster gauge repair... jmpark527 2005-2010 Mustang GT 29 11-25-2015 09:05 AM
The truth about gears.. Ish416 General Mustang Discussion 121 09-17-2015 11:33 PM
calibrate wideband gauge dreamstang 1979-1995 Mustang GT 15 08-11-2012 08:37 PM
aeroforce gauge. king 5.0 2011-2014 Mustang GT 25 01-25-2012 04:35 PM
04:51 AM
