BBR Reaper H/K Nitrous System - Mustang Evolution
Old 02-21-2014, 08:25 PM   #1
Oh2freshstang's Avatar
What do u guys think about this nitrous kit for the coyote? Pros & cons?
http://www.blowbyracing.com/20mubbrrehkn.html
Old 02-21-2014, 08:36 PM   #2
GrayGoose's Avatar
I was thinking the same, alittle spray, and you can always upgrade the bottle and noidZ...
GrayGoose is offline   Reply With Quote
Old 02-21-2014, 08:43 PM   #3
Yea it seems like a legit kit but I don't know too much about nitrous! I haven't seen a thread about it so I thought id make one to discuss it!
Old 02-22-2014, 10:47 AM   #4
HPFury's Avatar
How safe is it? Seen pics of blown tubes and the carnage they do on a car.
HPFury is offline   Reply With Quote
Old 02-22-2014, 12:11 PM   #5
Nothing wrong with this kit. It absolutely must have a tune for it but, it's barbaric simple, dry shot, on or off, either through a mometary switch or a wot switch. You are paying a fair bit for one solenoid, some plastic line and a bottle, though, especially if you don't have a tune for the shot, because any shot on a Coyote needs a tune.
Old 02-22-2014, 02:02 PM   #6
Yea a tune is a MUST of course!! So would it be a better investment to just go with a bigger kit? Even if u don't plan on running more than a 100 shot?
Old 02-22-2014, 05:49 PM   #7
NOTHING wrong with dry but, like most things, you outgrow it. You start wanting the progressive controller, bottle heater, gauges, multiple stages, etc. and pretty soon you are into it for the price of a more complete kit.
This thing is really a sneaky pete kind of setup.
Old 02-22-2014, 08:47 PM   #8
NOTHING wrong with dry but, like most things, you outgrow it. You start wanting the progressive controller, bottle heater, gauges, multiple stages, etc. and pretty soon you are into it for the price of a more complete kit. This thing is really a sneaky pete kind of setup.
Ah ok I see!
Old 02-23-2014, 07:32 AM   #9
The problem I have with nitrous on these cars is because there is no map switchability on the fly, you're stuck running around on a flat nitrous tune off the jug too. This makes it useless on the road.
Old 02-23-2014, 12:02 PM   #10
5lho. Ive read all you need to do is pull a few degrees of timing. Someone somewhere said the HP loss is low, like 5-10hp, something most people wont notice
JayblesStang is offline   Reply With Quote
Old 02-23-2014, 12:20 PM   #11
Depends on the shot size. You'll need to pull more than a few degrees on anything over 75 and this engine becomes real doggy if you don't keep the timing up in the low to mid 20s all in, n/a.
Plus, it's dry so, fuel needs to be accommodated through the tune. Older dry kits just deadhead the pressure up for shots under 125and this worked fine but, there is no compensation like that with this kit so, you need to dump fuel in through the tune, all the time, which won't help driveability and power off the jug.
Probably be ok up to the 100-125 shot level. Beyond that, the tune would start to really move away from what would work N/A.
Old 04-09-2014, 01:57 PM   #12
Konawin's Avatar
Here is a possible solution to the problem of running a non-nitrous tune and then switching to a nitrous tune, without having to stop, plug in a tuner, and 5 minutes later you are ready to spray. The AIW Mycal split personality tuner is switch operated.
I'm considering either a blower or nitrous but if I spray the Mustang, being a manual and street driven, I want to be able to activate and spray at a moments notice if I want to as well as prevent notrous backfire when shifting, with a window switch...
Let me know what you thing of this guys:
AIW MyCal Split Personality Tuner - Livernois Motorsports
Konawin is offline   Reply With Quote
Old 04-09-2014, 02:06 PM   #13
Rapinator126's Avatar
I run around on my nitrous tune all the time. Lays down 440 on motor and e85. A dry kit is fine just make sure you have the fuel to back it up.
Thinking about NOS. Concerns/Questions.. tgmeyer 2011-2014 V6 Mustang 39 10-23-2013 07:20 AM
Nitrous System on a V6? Ramon2013 2011-2014 V6 Mustang 3 10-14-2013 06:23 PM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
I WANT THE TRUTH! TopgearGT 1996-2004 Mustang GT 13 11-15-2012 07:59 PM
Nitrous Question OmegaRedGT 2007 2005-2010 Mustang GT 12 01-02-2012 09:13 PM
10:43 AM
