Noob suspension question - Mustang Evolution
Old 02-22-2014, 11:36 AM   #1
JD2STACKS's Avatar
Okay, so I'm trying to learn my 2013 gt and its stock parts. I bought it used and as far as I can tell it has only been lowered and fitted with flowmaster axle backs by the previous owner. I've noticed the car has a lot of wheel hop and the rear seems very loose so I was browsing control arms and panhard bars. My only issue is that I've heard when you lower you are pretty much required to upgrade suspension. I'm not sure if the control arms and panhard bar is stock or not as i'm not really sure what I'm looking at. Can someone help me out.
ID:	148541   Click image for larger version
ID:	148543   Click image for larger version
JD2STACKS is offline   Reply With Quote
Old 02-22-2014, 12:24 PM   #2
Region: Oregon
the lower control arms look like they have been replaced with bmr control arms. Not sure about the panhard bar though.
Instafire is offline   Reply With Quote
Old 02-22-2014, 12:50 PM   #3
LCAs are BMR, PH is stock. The stock shocks aren't helping much if lowered. You probably need relo brackets to get the lowers back in alignment. An adjustable PH bar wouldn't hurt either. You may need an adjustable upper control arm if it's dropped more than an inch.
Old 02-22-2014, 12:52 PM   #4
JD2STACKS's Avatar
Thanks so much @instafire and @5LHO
Old 02-23-2014, 04:40 PM   #5
PMDMustang13's Avatar
Region: Nebraska
I am in agreement with 5LHO. And Grease those LCA's with what BMR recommends which I believe is Mobil One Synthetic.
Get adjustable panhard bar because your chassis is likely not centered with the body now.
Get some BMR Relocation Brackets and use 2nd notch down if 1" to 1.5" drop.
Take photo of the upper control arm that is attached to the top of the differential. Hopefully it is adjustable and your pinion angle is properly adjusted since it is lowered.
2013 Mustang GT Premium, Deep Impact Blue, GT Track Package, Recaros, Ext. Acc. package 1, All Weather Mats, GT500 Axle backs, Airaid CAI, BMR Rear LCAs, BMR Relocation Brackets, JLT Oil Separator(s), Barton 2 Post Shifter Bracket, Steeda Motor Mounts, Barton Short Throw Shifter, JHR Clutch line, BMR adj. UCA and Mount, Kooks 1 3/4 headers with catted H, DSS Al Shaft with BMR Loop
PMDMustang13 is offline   Reply With Quote
Suspension upgrade question Red140 2011-2014 Mustang GT 20 10-21-2012 06:51 PM
Suspension question Raf63 2011-2014 Mustang GT 5 09-14-2012 04:04 AM
Suspension Poppavoltron 1979-1995 Mustang GT 3 03-12-2012 03:32 PM
suspension question Nashgizam 1996-2004 Mustang GT 9 02-18-2012 07:09 PM
Complicated suspension question Hm3grant 1996-2004 Mustang GT 3 07-26-2011 01:08 PM
05:47 AM
