Which Drag Radials for strip? - Mustang Evolution
Old 02-24-2014, 03:30 PM   #1
After the upgrades on my 2012 GT Automatic: 3.73 gears, Boss 302 Intake, JLT CAI and BAMA Race tune, I am ready for the Drag Radials. Was debating on the MTs in 325/50-15s or 275/60-15. With street tires (PZero 235s) absolutely NO traction in 1st - 3rd. Which tire for my setup at the Track, strictly track use only. Thanks
Paladin6591 is offline   Reply With Quote
Old 02-24-2014, 03:35 PM   #2
Site Sponsor
Sponsor
AMWill's Avatar
Paladin6591,
Go with the 275/60/15's for sure. With some practice driving, that's all the tire you'll need to hook a go! The 325/50/15's look really sweet mounted on the car, but in reality they're just extra weight. You'll be able to run a faster time with a lighter wheel/tire setup. No reason to go overkill with the DR's, IMO.
What's your current suspension setup?
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 02-24-2014, 03:38 PM   #3
Stock on the suspension, I have a set of control arms to install when I get the tires
Old 02-24-2014, 03:42 PM   #4
Shane, I've spent my money at AM on the parts listed, sure could have used a $200 savings, lol
Old 02-24-2014, 03:49 PM   #5
One other question, the rim: Either the Race Star 15x8 or the 15x10 for the 275s? AM has shown either, but with the 15x10, I would need the relocation bracket for the rear sway bar.
Old 02-25-2014, 11:03 AM   #6
Site Sponsor
Sponsor
AMWill's Avatar
I'm assuming you have lower control arms? They'll definitely help keep your Mustang launching straighter off the line. As the factory control arms tend to twist/flex.
I would run the 15x8's. Same reason as running the skinnier tire- there's no need for anything wider. You'll save weight using an 8" wheel over a 10", plus you won't have to buy the sway bar relocation brackets.
Did you get a chance to check out the link to the $200 off your next purchase info within my signature? It's worth a look for sure. We'll provide up to a $200 store credit if you submit a customer install guide for a part in which doesn't already have one. The final credit amount depends on the length of the install and how well the guide is written.
Let me know if you have other questions!
Shane
Old 02-25-2014, 11:08 AM   #7
I did buy the control arms, will install them when I buy the tires and wheels, thanks.
Old 02-25-2014, 01:04 PM   #8
Site Sponsor
Sponsor
AMWill's Avatar
Not a problem! Glad I could help help out and point you in the right direction. You'll have to let me know how you do at the track come Spring. Your ET's should drastically go down with the new wheels/tires!
Shane
Old 02-25-2014, 03:24 PM   #9
I will, hoping for high 11s (11.8 or 11.9) but if I achieve 12.0 or 12.1, I'll still be most happy, thanks to you and your AM team.
Old 05-05-2014, 02:47 PM   #10
Month ago, I took my car to the 1/4 mile track, best time of 12.48. Was little disappointed but not too bad. Found out I needed a different tune:
So, I got a new tune from AM on my BAMA Tuner. Now shifting at 7300-7500 rpms. And installed the JM LCAs I had. With my Nitto 275-60-15s, I cut .3735 off my 1/8th time. Looking forward to going back to the 1/4 track. Should be at 12.0 or 12.1. Still need work on my 60ft time (2.0). I am trying to shave .2 off that. If I can, I believe I can break below 12.0. Now here is the good news. Of course I drive conservative (daily driver), 33 miles one way to work every day. I am at 22.7 mpg. For my 2012 GT to be pushing close to 420 rwhp, not bad. And FYI to you folks at AM, TCI will have a Torque Converter for the 2011 -2014 GT this summer. Think that may be my next up grade (a street-strip torque converter). Thanks AM!
Old 05-05-2014, 03:27 PM   #11
Grabber Blue5.0's Avatar
I just ran a 11.4 last Friday @ 121 mph still working on my suspension. Stock 3.15's. It's about choosing the right parts.
Old 05-05-2014, 03:30 PM   #12
See, that's awesome and what I like to hear. I see you have the circle D 4c. How is it for street use. I have been told I can drop almost a full second with the right converter. That would put me in the mid 11s in the quarter.
What size are your MTs on the rear?
Old 05-05-2014, 04:14 PM   #13
A converter will net you about a half a second. No more. I went 11.79 before the converter swap and once I get my suspension dialed in itbshould get me an 11.2x. A converter is totally street-able. I run a 295/55-15 M/T rear.
Old 05-05-2014, 04:57 PM   #14
1lowGT's Avatar
I don't see you breaking 11s but who knows..
Old 05-05-2014, 05:07 PM   #15
Rapinator126's Avatar
He will be able to with slicks and proper suspension easily. With no more power mods.
Old 05-05-2014, 05:15 PM   #16
But being an auto a drag radial is the better choice for him.
Old 05-06-2014, 06:57 AM   #17
With the new tune I cut .3735 off my 1/8th time. That should place me at 12.1 at the 1/4 mile, will know for sure in the next couple weeks. If the right converter will shave off .5, I should go into the high 11s, am I just dreaming or does that make sense? Your thoughts?
I am running Nitto 555R DRs in 275/60/15s, although they are not MTs (which would be better) they do grip pretty good, for my HP range anyway. I've not dyno'd yet but I think I am at least at what AM says it should be with my set up.
Old 05-06-2014, 10:18 AM   #18
With a converter you SHOULD be in the 11's but you have two things working against you. The 3.73 gears and the Bama tune.
Old 05-06-2014, 10:23 AM   #19
Tune is key. They Ronnie from rev autos wife car. Runs 11.3 with 4.10's full exhaust and a tune. And big and littles. Stock converter
Old 05-06-2014, 10:24 AM   #20
That posted all fked up. But you get the point
Old 05-06-2014, 10:40 AM   #21
Send a message via AIM to Borii
There is a low 1.7 of high 1.69X in those 555R
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 05-11-2014, 10:03 PM   #22
Region: North Dakota
Just to throw my 2 cents in there, I run Nitto drag radials the NT05R's and i have not been very happy with them. They have gotten better towards the end of their life but my buddies running MT street ET's get a **** load better traction than me. I also run them in 305/45/18's so that could be an issue as well.
2013 GT Ford Racing Supercharger, Borla Catback, Black
Beni is offline   Reply With Quote
Old 05-11-2014, 10:06 PM   #23
guess i should have thrown my numbers in there too, I'm running 456whp on a load bearing dyno, so i def. yeah the nitto's don't help much.
Old 05-11-2014, 11:06 PM   #24
Need suspension BC I was hooking up perfectly with 650+ on nt05r's. Suspension is key on these cars. If they didn't work for you at your power level its 100% your suspension
Old 05-11-2014, 11:35 PM   #25
What do you have for suspension?
Old 05-11-2014, 11:38 PM   #26
Lake wood 70/30 struts 50/50 shocks. K springs. JPC adjustable UCA. BMR Lca's. BMR relocation brackets. BMR pan hard bar.
Old 05-12-2014, 06:27 AM   #27
Beni, what are your 60' times?
Sold - 2001 Audi S4
Old 05-12-2014, 06:35 AM   #28
Car was previously a roll car/ dig car. Being setup for the track now with new setup
Old 05-12-2014, 10:15 AM   #29
Just FYI, my 60ft times are a constant 2.0 - 2.0 - 2.0. I have had folks with a 1.8 and 1.9 60ft race me and I still beat them at finish line. My best time so far is 12.48 at 113 and is pretty much constant 12.5 @ 112. Circle D has recommended a 2c stall converter. With that, I believe I can run 12.0
Old 05-12-2014, 10:23 AM   #30
What are your mods? You should be faster than that
Old 05-12-2014, 10:24 AM   #31
According to his original post, he is spinning 1-3. His mod list is in the original post as well.
Sold - 2001 Audi S4
Old 05-12-2014, 10:27 AM   #32
We'll bama is your problem. 100% autos have been 11.3 with big and littles and full exhaust / tune. Stock converter also. Lol at everyone who runs bama and is wondering why they are slow as balls of and on the track
Old 05-12-2014, 10:32 AM   #33
302 BOSS Intake, JLT CAI, JM LCAs, 3.73 rear, Nitto 555R in 275/60/15s with Bama 93 Tune on my 2012 GT
Old 05-12-2014, 10:33 AM   #34
Contact rev auto and go with them for your tune for your auto. If you want another email tune. You will notice a huge difference. Your bama tune is your problem
Old 05-12-2014, 10:47 AM   #35
Ok, rev auto, who and where are they? Just googled rev auto, many sites come up. thanks
Street drag radials and rims Notorious_rob Shelby Mustang 5 03-16-2014 12:34 PM
Drag radials Thomas11CS5.0 Mustang Wheels & Tires 8 07-28-2013 09:50 PM
Drag radials and backspacing tea84 2011-2014 Mustang GT 9 09-27-2012 11:17 AM
Slicks or drag radials on 10 holes Stockish302 1979-1995 Mustang GT 19 11-22-2011 08:13 PM
Thinking about drag radials TheJigShow 1996-2004 Mustang GT 18 10-25-2011 11:22 PM
09:25 PM
