Koni Orange Shock Noise - Mustang Evolution
Old 02-25-2014, 11:17 AM   #1
2013fiveO's Avatar
I installed the Koni orange shocks and struts last week. I'm getting a popping noise in the rear when going over small bumps or rough road (not speed bumps). I checked the sway bar and all other suspension components and everything is tight.
The noise sounds like a plastic popping noise so I checked the black plastic shock covers and the left one much looser than the right with suspension loaded. The problem is that I have tightened the top shock nuts and tight as I can.
These shocks reuse the factory shock bushings and nut.
Any ideas?
Maybe its a bad shock (according to a few friends) and AM can send me another but I want to cover all bases before I call them.
2013 GT 6MT, 3.31s, Brembo Pckg, Sync
Mods: AED Tune,Boss 302 IM, BBK 85mm TB,Kooks SS Shorty Headers,HF Cats,Alum 1pc DS,Hotchkis Subframe Connectors,Steeda CAI,Roush Axlebacks,Barton Shifter,SR Clutch Line,Boss Oil/Trans Coolers,SVT Fan,Steeda Sport Springs/LCAs/UCA/Shifter Bracket/HD Motor Mounts,BMR LCA Relo Brackets,Koni Shocks/Struts,GT500 Strut Mounts,JLT Oil Sep,Hood Struts,GT500 Spoiler,MMD Taillight Trim,OEM Leather Seats,MT Street Comps on black AMRs,MT ET Street Radial IIs on black Bullits(track duty).
2013fiveO is offline   Reply With Quote
Old 02-25-2014, 11:52 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Could be the soft oem shock bushings. Is your rear sway bar stock? The stock sway bar bushings are notorious for having a pop/clunk sound over bumps and rough road, especially if you're lowered. So that could be it too.
Sent from my HTC One X using Mustang Evolution mobile app
2012 Kona Blue 3.7L V6:
Old 02-26-2014, 11:22 AM   #3
I had issues with koni struts. The strut shaft was squeaking and the info I got was that the tolerance on some of the struts are really tight could cause squeaking. I had to silicone spray them every other day to stop the squeak. I was not very impressed with the koni orange. I ended getting some steeda shocks and struts and I haven't had any issues.
Mikeyt03 is offline   Reply With Quote
Old 02-26-2014, 12:30 PM   #4
smittybat's Avatar
Did you check the panhard bar? On mine it seemed tight but after I took it off and tightened the adjustment nut on the passenger side the sound went away. I'd check the torque on everything; shock bolts, panhard bar bolts, panhard adjustment nuts, and sway bar bolts. I've got the Koni oranges as well and those weren't my issue.
smittybat is offline   Reply With Quote
Old 02-27-2014, 02:29 AM   #5
TommyV's Avatar
I agree, check the nut on the panhard bar.
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 02-27-2014, 09:14 AM   #6
KARgt13's Avatar
Don't tighten the shock nut all the way, or so I have been told on this forum. It's meant to have some give.
Also, did you tighten the nut with the wheels in the air or the wheels on the ground?
KARgt13 is offline   Reply With Quote
Old 02-27-2014, 11:49 AM   #7
2013fiveO's Avatar
Thanks for all the replies everyone. Yes my panhard bar nuts are super tight with Loctite and so is everything else. I didn't have this problem until I installed the shocks. And I always load the suspension when torqueing the fasteners.
I called am and they want me to take it to a shop and send them a diagnosis. Which is somewhat understandable but it would cost me more to have that done than replace the shock out of pocket. Here in Germany everything is so expensive and paid in Euros. Not USD. Even if I could find a place to get a free estimate I don't have the time. So I told am no thanks I'm gona consider this a loss and buy elsewhere. Kind of blows I've bought over $10,000 in parts from them and they give me **** over a $75 shock.
Old 03-02-2014, 07:28 PM   #8
11socal50's Avatar
i may be wrong but i thought i read somewhere that compression noises from koni oranges was normal, part of the reason i decided to go with yellows
11socal50 is offline   Reply With Quote
Hissing Noise JetLife 01GT 1996-2004 Mustang GT 14 12-03-2013 12:03 PM
Car still makes loud noise when going over bumps Coltonhess 1996-2004 Mustang GT 8 07-23-2013 09:35 PM
High pitched engine noise whine cjd_1986 2005-2010 V6 Mustang 4 01-16-2012 11:34 AM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 08:14 AM
07:43 AM
