Interior panel removal help - Mustang Evolution
Old 02-26-2014, 08:07 AM   #1
11stangGT's Avatar
Region: Arkansas
Does anyone know how to remove the brushed stainless cover over the passenger air bag? I've reed prying it in a few spots with no luck.. Already got the one off around the instrument cluster.
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 02-26-2014, 09:47 AM   #2
Ntbruncie's Avatar
If I remember correctly you have to drop the glove box down and there will be 2 bolts holding the air bag module in. Don't forget to unhook the battery before doing this. Once you get the air bag module loose then slide it out far enough to in plug the harness. Then you are done pull the module out.
Ntbruncie is offline   Reply With Quote
Old 02-26-2014, 10:03 AM   #3
11stangGT's Avatar
Region: Arkansas
Do the panels separate from the bag?
Old 02-26-2014, 10:04 AM   #4
Ntbruncie's Avatar
That I don't remember, there is clips on the back side
Old 02-26-2014, 10:06 AM   #5
11stangGT's Avatar
Region: Arkansas
K.. Having the panels done in carbon fiber so I guess I'll just have to give it a shot.
Old 02-26-2014, 10:07 AM   #6
Ntbruncie's Avatar
Vinyl wrap? Or hydro dipped?
Old 02-26-2014, 10:12 AM   #7
Deerslayer's Avatar
Here is a .PDF file of how to do it. It is the same with new Mustangs. Once you get it out, pry it off the "hooks" with a flat head screw driver.
Passenger Air Bag Module.pdf
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 02-26-2014, 10:14 AM   #8
11stangGT's Avatar
Region: Arkansas
Hydro.. Cool thanks
Old 02-26-2014, 10:17 AM   #9
Deerslayer's Avatar
BTW.....MAKE SURE YOU UNHOOK one of your BATTERY TERMINALS! just to be safe. There is some jakwad on youtube that removes the panels by PRYING the sides up. Please dont be retarded. You will or can ruin the panels. That guys video has probably caused more damage to peoples dash than can be believed. It is so easy to do it right, there is absolutely no reason to bend and ruin anything
Old 02-26-2014, 10:41 AM   #10
11stangGT's Avatar
Region: Arkansas
From my experience you don't have to unhook the battery(although I will). As long as you don't turn the key on. I've done prolly 125-150 leather kits a lot of which have airbags
Old 02-26-2014, 10:45 AM   #11
Deerslayer's Avatar
I hear ya. Just the thought of that bag blowing while you would be working on it makes the couple of mins worth of unhooking the terminal. Better safe than sorry.
Here is the old base dash I removed before installing a Boss dash. I wrapped it in 3M carbon fiber. Just sold the dash in a Mustang parts Facebook site yesterday.
Name:	ImageUploadedByMustang Evolution1393436732.123914.jpg
ID:	149069Click image for larger version
Name:	ImageUploadedByMustang Evolution1393436744.016433.jpg
Old 02-26-2014, 12:37 PM   #12
11stangGT's Avatar
Region: Arkansas
Next question black carbon fiber or the standard carbon fiber? Can't decide
Old 02-26-2014, 12:38 PM   #13
11stangGT's Avatar
Region: Arkansas
Going to paint all the chrome rings flat or matte black also
Old 02-26-2014, 01:21 PM   #14
Ntbruncie's Avatar
Do you have a sample of both? I'd leave the chrome rings
Old 02-26-2014, 10:55 PM   #15
11stangGT's Avatar
Region: Arkansas
Nah sure don't. Btw the airbag does separate from the panel.. You gotta cut some plastic tabs off and I'll have to glue them back
Old 02-26-2014, 11:19 PM   #16
Ntbruncie's Avatar
I vinyl wrapped my last mustangs dash with carbon fiber looking vinyl. I thought it turned out pretty good Click image for larger version
Name:	ImageUploadedByMustang Evolution1393481945.464420.jpg
Old 02-27-2014, 07:01 AM   #17
Deerslayer's Avatar
You dont cut those tabs to seperate the air bag unit from the panel. Like I stated in the earlier post, use a flat head screw driver to remove those tabs by lifting them over the hooks. Those tabs play a significant role when your air bag is deployed. They are designed as "hinges" to hold the top and bottom of the panel together on the dash allowing them to open like doors in the center when the air bag deploys. If you glue them and they glue doesn't hold, the whole panel will become a projectile in front of your airbag when it deploys. Good luck getting it glued back together properly.
Old 02-27-2014, 07:20 AM   #18
11stangGT's Avatar
Region: Arkansas
I do interior work for a living. I can handle it. And I attempted to lift them over the hooks with no luck.. They were tearing and would have broke anyway. I'll use a special kind of hot glue that actually bonds to the plastic. And I only cut them off one side
Old 02-27-2014, 07:21 AM   #19
11stangGT's Avatar
Region: Arkansas
Hey I'm not gonna be sitting over there anyway right? Lol
Old 02-27-2014, 07:24 AM   #20
Deerslayer's Avatar
LOL , you do interior work on cars for a living and you cut those tabs?
Old 02-27-2014, 07:37 AM   #21
11stangGT's Avatar
Region: Arkansas
Yup.. Never messed with a air bag in the dash but done 100+ leather kits, which includes covering consoles, door panels and all sorts of stuff. And as I said THEY DID NOT PRY over the hooks.. I tried that and that woulda been much simpler had it worked..
Wanted: Metco (MPT0001) Pulley Removal & Installation Tool GT500 Fan Mustang Parts for Sale and Wanted 1 03-14-2014 03:48 PM
Decklid removal on 2013 GT Sterlingbeast5.0 Mustang Paint, Appearance & Detailing 3 02-20-2014 12:39 PM
emergency brake cable removal, also.... Harper 1996-2004 Mustang GT 2 02-09-2014 10:26 PM
Gear Shift Knob Removal dellito 2011-2014 Mustang GT 9 12-28-2011 08:54 PM
Pedal removal 90mustangLX 1979-1995 Mustang GT 3 11-26-2011 07:45 PM
04:19 PM
