Anti-lag turbo system - Mustang Evolution
Old 03-04-2014, 06:26 PM   #1
Subtle stang14's Avatar
Hey guys, i was looking at a forced induction route for my mustang, once i get the money of course, and im falling in love with the turbo and the sound it produces. I was doing research on what kind of turbo would be best for me and i stumbled across the anti-lag turbo system, this system seems to be pretty good if you plan to rally your car and besides.. It shoots flames because it has a later combustion time in the combustion chamber to keep the turbo spooled up and burns the extra gasoline in the intake manifold and exhaust. Anyways i was wondering if anyone had this system and if they like it? Are there any backdraws or something i should do to my car before putting this system on? Thanks!
Subtle stang14 is offline   Reply With Quote
Old 03-04-2014, 08:02 PM   #2
Rynarok's Avatar
First, so you know where I'm coming from; used to have a heavily modded 04 SRT4 with a 40 trim - dat ***** would roll 25lbs and surprise vettes all the time.
From what i know of the anti-lag turbos is that it is incredibly bad for your cats and mpg. Traditionally, the larger the snail, the slower the spool so the smart thing to do is find that happy medium between spool time and impeller size. Just off the cuff, I'd bet the 5.0 displaces a ****ton more air than my 2.4L did, so a larger impeller would manage fine without the same amount of lag.
I'm not sure what size the Hellion kit is, but I imagine it works just fine if kids are getting +1000hp out of full builds with it. With any big turbo system, I recommend forged internals, upgraded fuel pump/rails, and a good amount of time on a dyno. You might start looking into shoring up your transmission and clutch, too.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 03-04-2014, 08:31 PM   #3
Ish416's Avatar
Anti lag turbo setups basically just dump a ton of fuel through the engine and change the timing to get what's essentially a backfire through the turbo. It is extremely rough on the turbo.
This system was designed for small engines with big turbos to prevent turbo lag off the line. On a V8, this system would be about useless unless your pushing for well over 800rwhp.
Old 03-05-2014, 08:54 AM   #4
BIGHOSS5.0's Avatar
If you want turbos, this is the route you want to go.
On 3 Performance - Turbo Kits for Ford Mustangs
You may also want to consider John Lund Performance, they are in the testing phase of a TT system for 2011+ 5.0's
You can also go Helion but $$$$$
BIGHOSS5.0 is offline   Reply With Quote
Old 03-05-2014, 01:49 PM   #5
Konawin's Avatar
Well, I've run all types of boosted set up and nitrous too but what you are suggesting is not necessarily a good idea for your Mustang. As others said, it'd be hard on parts, inefficient, and possibly dangerous... Twin turbos, if sized right will hardly lag, which gives you time to get rolling w/o spinning your tires. Good luck and be safe
Konawin is offline   Reply With Quote
Old 03-06-2014, 12:57 PM   #6
86 muscle's Avatar
Supercharger, anti lag turbo is called a supercharger
Sent from my SAMSUNG-SGH-I317 using Mustang Evolution mobile app
86 muscle is offline   Reply With Quote
Old 03-06-2014, 03:53 PM   #7
Coyote_5.0's Avatar
If you go turbo, you should build the engine up. Otherwise the stock internals aren't going to last.
2011 GT SG 6M
JLT | Eibach | J&M | Diablosport | Roush | Barton
Coyote_5.0 is offline   Reply With Quote
Old 03-06-2014, 05:04 PM   #8
Site Sponsor
Sponsor
AMWill's Avatar
This anit-lag system sounds more like a two-step? You can ****** the timing to whatever you want in order to hold a certain RPM. The retarded timing would also boost up the turbo if you have one.
Although, my favorite anti-lag turbo system is made by Nitrous Express... It's called a 100shot
^^^Not suggested for stock engines or engines running on 93octane haha!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
stock sound system vs. shaker audio system (2014 Mustang) Charlesph55 Mustang Audio & Video 6 02-15-2017 06:11 AM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Turbo vs supercharger Midknight26 1996-2004 Mustang GT 39 07-12-2013 08:01 AM
Will a turbo kill my gas mileage? thatmustangguy 2005-2010 Mustang GT 18 04-29-2013 09:02 AM
turbo or supercharger sam minnick 1996-2004 Mustang GT 72 10-09-2012 11:27 AM
10:17 PM
