rough idle - Mustang Evolution
Old 03-09-2014, 01:38 PM   #1
Blueoval390's Avatar
rough idle
I've been searching different forums to answers about our rough idle issues. My wife's 2011 GT had the CEL come on with a code of PO174, Lean Condition on Bank 2. I tried to locate a vacuum leak but couldn't find one. I ran a can of Sea Foam through it thinking maybe an injector was plugged up. The car has something over 50K miles on it. I did the Idle Relearn to no avail. Anyone have any ideas? Could it be a faulty IAC? Other than the idle and the CEL, everything seems normal, runs good.
Blueoval390 is offline   Reply With Quote
Old 03-09-2014, 01:51 PM   #2
Grabber Blue5.0's Avatar
These cars don't have IAC valves. Stock? Tuned? Did you address the code?
Old 03-09-2014, 01:53 PM   #3
Thanks, I wondered about that. I replaced the IAC on my '97 and my wife's '01 but was curious whether this one had one or not.
Car is bone stock. Still haven't figured out how to address the "Lean Condition". Like I said, I haven't located a vacuum leak and don't know for sure how to correct the lean condition.
1969 F-100 Shortbed
390 with Edlebrock RPM Performer Heads and Intake
Tremec 6-Speed
4-link Suspension
Old 03-09-2014, 01:59 PM   #4
That's dark age technology, like a tickler valves on a carburettor. Check your intake for leaks. I'll often run a propane torch around the joints (unlit, of course) as, if there is a leak, it'll make the idle jump.
Any work done recently on the car? I'd start pulling some plugs and doing basic engine diagnostics, compression check, plug condition, etc. if I was out of warranty and on the hook for the work. You are still on 5 year PT so, you may wish to let Ford address your issues.
Old 03-09-2014, 02:02 PM   #5
Ha! Some of old timers are pretty familiar with "dark age technology", hence the old Ford truck. If this thing is still under PT warranty, I'm all over that. Thanks for the heads up.
1969 F-100 Shortbed
Tremec 6-Speed
4-link Suspension
Old 03-09-2014, 02:41 PM   #6
Doesn't hurt to ask. The car has a fair bit of miles and that might affect their decision but, try anyway.
This ain't my first rodeo either, I've been at this for over 30 years. These are the good old days, in case nobody noticed.
Old 04-07-2014, 11:19 AM   #7
Marine8d's Avatar
My 14 GT just started doing it. It has just over 2000 mi and sometimes while stopped it gets as low as 100 RPM (almost Stalling) and catches back up. Most of the time is fluctuates between 800 and 500.
Could the weather have anything to do with it?
Marine8d is offline   Reply With Quote
Old 04-07-2014, 11:34 AM   #8
GE3G's Avatar
Check where your intake connects to your tb.. mine was loose and fluctuated my rpms like crazy. While I drove it was fine but at idle it was noticeable
GE3G is offline   Reply With Quote
Old 04-07-2014, 11:46 AM   #9
Marine8d's Avatar
Wow dude, almost right in the money. Checked the intake and the filter element was ever so slightly of place showing a little of the tube. Thanks!!
Old 04-08-2014, 01:40 AM   #10
Compstall's Avatar
Nah that's just the 700 lift cam on a 106 lsa with 18:1 compression you're feeling. Perfectly normal.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
modded 95 gt rough idle SyKoticStang 1979-1995 Mustang GT 7 01-28-2014 06:23 PM
Help: Rough Idle and feels like its sputtering during acceleration. brooksyx Pre-2005 V6 Mustang 9 05-13-2013 02:25 PM
Loss of power and rough idle. eouellette18 2005-2010 Mustang GT 13 04-04-2013 07:01 AM
Rough idle normal? ColeJohnson 1996-2004 Mustang GT 18 02-20-2012 03:12 PM
Rough idle Blackedout Pre-2005 V6 Mustang 0 01-23-2012 04:27 PM
07:01 AM
