Ford Factory Reflash - Mustang Evolution
Old 03-12-2014, 08:29 AM   #1
striker79's Avatar
Hey guys,
I tried reading some forums before posting this, but couldn't find an exact answer. I have a SCT SX3 tuner for my 2011 mustang gt. I returned my car to stock, drove around for a week, and dropped my car off at the dealer to see why I can't pass emissions readiness. They are reflashing my computer. Will my handheld tuner still work when I get the car back? I imagine the VIN and everything would still be recognized in my tuner...
Thank you for any feedback.
Yellow Blaze 2011 Mustang GT Premium. Kooks 1 7/8 midlength headers, Kooks Boss 302 H-pipe with Kooks sidepipes. Heartthrob mid pipes with flowpacks. RTR axle backs. Vogtland lowering springs. BMR adjustable panhard bar. Boss 302 Brake duct kit. Boss 302 trans scoop. Boss 302 oil cooler. Boss Intake Manifold. BBK 90mm Throttle Body. JLT Cold air intake with bama tune. JLT oil separator. Steeda lower control arms. BMR control arm relocation brackets. Barton two post short shifter. DSS Aluminum drive shaft. ACT HD Twin Disc Clutch
striker79 is offline   Reply With Quote
Old 03-12-2014, 08:32 AM   #2
knight5.0's Avatar
i hope you returned the car to stock before you brought it to the stealership
Black 2011 Mustang GT Premium
Manual transmission, SS clutch line
Brembo brake package
Steeda CAI, Borla axle back & BBK X pipe
And Jon (Godfather tuner) Lund tune
knight5.0 is offline   Reply With Quote
Old 03-12-2014, 08:41 AM   #3
striker79's Avatar
I did return the car back to stock. As long as I did that I should be ok?
Old 03-12-2014, 08:46 AM   #4
knight5.0's Avatar
i would think so because its lock by the VIN of the car its used on. If you returned to stock it should be unlocked.. but if they reprogram i think it changes the number on the side of the ECU for the revision. So i would call the place i get my tunes from and tell them about it and ask if any changes are need to tune before i try to put the tune back on the car.
Old 03-12-2014, 08:47 AM   #5
striker79's Avatar
Ok. That is what I was thinking I would need to do. Thank you for the advice.
Old 03-12-2014, 11:21 AM   #6
Strange Mud's Avatar
Is your real problem the fact you are running a race tune with some emmisions sensors off?
Old 03-12-2014, 11:28 AM   #7
striker79's Avatar
No. I returned to stock and the readiness still would not pass. I drove 500 miles and it still wouldn't work.
Old 03-12-2014, 12:06 PM   #8
nhcowboy's Avatar
Have you physically looked at the o2 sensors? Stranger things have happened. Maybe a plug is loose, wire is nicked, etc.. Maybe the sensor(s) are bad. Maybe you cats are fried from running a rich tune for a long time.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 03-12-2014, 12:09 PM   #9
striker79's Avatar
I have replaced the front O2's and the rear 02s were replaced less than a year ago. All the wires are good with no cuts. I'm not using O2 extensions either.
Old 03-12-2014, 04:44 PM   #10
nhcowboy's Avatar
Question, how are you able to determine the o2s were not ready in the other thread? Does the SCT tuner show you that somewhere? Or only able to tell at an inspection station? Is like to know just for my own info prior to having an inspection known.
Thanks for any info.
12.538 ET @112.33
Old 03-12-2014, 04:50 PM   #11
striker79's Avatar
I actually got tired of going to the emissions place to check readiness so I did some research and found a OBD2 reader that has the readiness tests built into it. I paid $100 for it. Definitely worth the trouble IMPO.
Old 03-12-2014, 08:56 PM   #12
striker79's Avatar
Here is the model I got. It has been working great for me, and makes it easy to see if my emissions is ready. I'll be using it every year before I head to the emissions inspection to make sure I'm good to go.
Equus INNOVA 3100 ABS CAN/OBDII Code Reader
Updated 2013 Fun Ford Weekend Schedule FunFordWeekend ME Site Help & Announcements 0 01-07-2013 12:19 PM
Ford vs Ford Virgo062 The Bar 13 12-20-2012 06:23 AM
FS: SCT Xcalibrator 2 for FORD (96-08 mustang only) rebeltx Mustang Parts for Sale and Wanted 8 12-18-2012 07:17 PM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
10:17 PM
