Rear tires and speedo adjustment - Mustang Evolution
Old 03-13-2014, 07:27 AM   #1
captain78's Avatar
I'm thinking of up grading my 2014 Gt rims and tires. The stock silver 18x8s just don't look good. I want 19x9s in the front 19x10s in the rear. My car is not lowered and will not be lowered but I want a taller tire in back does anybody know what's the tallest widest tire I can fit under the back without issues of suspension travel and how do you correct the speedometer from goin with a taller tire
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
captain78 is offline   Reply With Quote
Old 03-13-2014, 07:46 AM   #2
LuisBlackGT's Avatar
I don't know what the tallest tire is, but you might want to have some taller gears if you go too tall, correcting the speedo is done with a tune
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 03-13-2014, 10:18 AM   #3
captain78's Avatar
Ah just a inch or two taller than what I have so not extremely tall.im not gonna change my gears or anything. Just a little taller for stance.
Old 03-13-2014, 10:30 AM   #4
GrabberMeBlue's Avatar
You would actually wanted shorter / lower gears, not taller / higher.
Higher numbers = shorter gears
Lower numbers = taller gears
2.73 is taller / higher than 3.73
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 03-13-2014, 11:22 AM   #5
scc2014gt's Avatar
I have been trying to get my wheel setup figured out lately as well. After much research and debate I have decided to go with 275 square setup with the sve drifts. This is fine with me as this is my daily driver and just a fun car for me. I'm not regularly going to the track or doing any competitions. My reasons for not going staggered were avoiding going through tires as well as possible issues with abs and traction control. Since my diameters will still be different from stock I will also have to recalibrate the speedo. I called a couple of local ford dealerships and talked to one that said they would do it, however for them do it the diameter as to be within the range of the computer.
2014 Black Mustang GT. Roush Axleback Exhaust, Airaid Intake, JLT Oil Separator, Black Billet Grille, Fog Light Relocation, 19" sve drifts with 275/40's, D2 Coilovers, BMR Panhard Bar, BRM LCA's and UCA, KOI and Oracle Orange Dip
scc2014gt is offline   Reply With Quote
Old 03-13-2014, 01:21 PM   #6
captain78's Avatar
Thanks scc2014gt mine isn't for racing more for show so I'm going after looks
Old 03-13-2014, 09:56 PM   #7
Thanks for the correction I definitely worded that wrong lol
Old 03-17-2014, 10:04 AM   #8
captain78's Avatar
Do yall know if 19x10s would fit in front if not why not. What would be the problem
Old 03-17-2014, 11:46 AM   #9
Deerslayer's Avatar
They would fit. We are running Michelin Pilot Super Sports 275/40/19 front and 285/40/19 rear and we are lowered. No rubs and these tires run true to size.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 03-17-2014, 12:08 PM   #10
captain78's Avatar
What's your back spacing on the wheels I like the look
Old 03-17-2014, 12:36 PM   #11
Deerslayer's Avatar
9.5 wheels
+35mm offset
6.63in Backspacing
You can go with a 35 profile tire and it looks great, they are just a lot rougher daily driving. The 40s fill the wheel wells completely and are awesome daily and still great track tires.
Old 03-17-2014, 12:41 PM   #12
captain78's Avatar
Wonderful
Old 03-17-2014, 03:40 PM   #13
scc2014gt's Avatar
Any issues with the 285's on the 9.5 wheels? I was think 275 was cutting it fairly close on the 9.5's
Originally Posted by Deerslayer View Post
9.5 wheels
+35mm offset
6.63in Backspacing
Old 03-17-2014, 04:05 PM   #14
Deerslayer's Avatar
Not at all. We could'a gone 295 but that would have been cutting it close, especially in the PSS
Old 03-17-2014, 04:22 PM   #15
captain78's Avatar
Why would the circumference of the tire have to do with the width
Old 03-17-2014, 08:26 PM   #16
Deerslayer's Avatar
285 compared to the 295 both with the aspect ratio of 40 would have added a total of 4mm to the top of wheel well and 8mm to the front & back. With 10mm more in width, we would probably rub in the rear lowered like we are. It would be really close.
2011 Rims + Tires on my 2002? kgbearsfan Pre-2005 V6 Mustang 5 02-13-2012 02:47 PM
larger rims and tires help! austinknoll Mustang Wheels & Tires 8 02-11-2012 04:40 PM
12:37 PM
