Car running really rich - Mustang Evolution
Old 03-16-2014, 12:04 PM   #1
86 muscle's Avatar
I put a turbo on my 13 gt this past weekend, hellion single kit, comp 74mm turbo, 47lb injectors, and a vortech non programable bap. When dataloging the wot portion of the tune, I'll start in 4th gear and get on it the car spits and sputters before trying to go my afr drops to 10.0 if not lower, and I put out a black cloud of soot. Any ideas other than tune? Maybe like the bap is giving to much fuel? I upgraded the plugs gaped all around .025
Sent from my SAMSUNG-SGH-I317 using Mustang Evolution mobile app
86 muscle is offline   Reply With Quote
Old 03-16-2014, 12:14 PM   #2
Rapinator126's Avatar
One- Who had you gap them at 0.25?
Yes you are sucking to much fuel. Does the vortech BAP have a knob on it? Like the kenne bell one. If so what is it set at?
Old 03-16-2014, 12:26 PM   #3
86 muscle's Avatar
The hellion directions, and BBR said that gap. No knob just wire and done
Old 03-16-2014, 12:27 PM   #4
Thats a tight gap. Most run .28 with the coyotes and a turbo
Old 03-16-2014, 12:34 PM   #5
86 muscle's Avatar
I thought it was tight as well. The kit actually said .020 but that is just too small.
Old 03-16-2014, 12:41 PM   #6
How much boost you at? You running a oilless comp? So no scavenger pump
Old 03-16-2014, 12:44 PM   #7
86 muscle's Avatar
Yes sir, so far I'm getting 8 to 9 lbs
Old 03-16-2014, 01:02 PM   #8
Compstall's Avatar
.025 and .25 is a huge gap.
Sent from my iPad using Tapatalk HD
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 03-16-2014, 01:10 PM   #9
Not for 8lbs of boost
Old 03-16-2014, 01:14 PM   #10
Compstall's Avatar
Ok, if I ever need an engine build I'll make sure I don't ask you guys any technical questions.
- Brent
Old 03-16-2014, 01:34 PM   #11
Lol run your car not your mouth. I woukd love to drag our **** box down the track.
Old 03-16-2014, 01:40 PM   #12
*your.
---------- Post added at 02:40 PM ---------- Previous post was at 02:40 PM ----------
People are running a .20-24 on 20lbs of boost.
Old 03-16-2014, 01:54 PM   #13
86 muscle's Avatar
Originally Posted by Rapinator126 View Post
*your.
I get what you're saying but I think what he meant was between .020 and .20 is a really big gap. Gaps are .0xx. I'm sure that's all he was saying.
Old 03-16-2014, 03:48 PM   #14
Coyote_5.0's Avatar
I think he's referring to how you keep leaving out a 0 there bud. It's .025 and you keep saying .25 That's a huge difference and would cause misfire.
2011 GT SG 6M
JLT | Eibach | J&M | Diablosport | Roush | Barton
Coyote_5.0 is offline   Reply With Quote
Old 03-16-2014, 03:49 PM   #15
Thank you mister obvious.
Old 03-16-2014, 03:50 PM   #16
I wish mustang evo would do a big get together and we could all find out who knows what and who can let there car do the talking
Old 03-16-2014, 04:07 PM   #17
Coyote_5.0's Avatar
You mean like how people don't know how spark gap works.
I thought maybe it was just a typo, but you did it 3 more times.
2011 GT SG 6M
Old 03-16-2014, 04:10 PM   #18
Who gives a ***** how it is typed? I know how it works. Been through a few diffrent setups in all my cars. So tell me you fast with your more than likely bama tune
Old 03-16-2014, 04:14 PM   #19
Coyote_5.0's Avatar
17.1 in the 1/8th, with a microsoft tune.
Sent from my Galaxy S3
2011 GT SG 6M
Old 03-16-2014, 04:15 PM   #20
Since the way something is typed means evetything to you, tell me about your car,? Stock motor? Power adder? Suspension? Gears?
Old 03-16-2014, 04:20 PM   #21
Did you get one of the newer kits with the larger downpipe and wastegate? They changed all of that on the newer kits to solve all the backpressure problems.
Old 03-16-2014, 04:29 PM   #22
Coyote_5.0's Avatar
Stock motor, twin superchargers, 1.56 gears, and a nos sticker.
2011 GT SG 6M
Old 03-16-2014, 04:32 PM   #23
Must be stock
Old 03-16-2014, 04:41 PM   #24
86 muscle's Avatar
I'm not really sure if it's newer or not, I disconnected the bap and it runs 1000 times better. My tuner must not have compensated for that. Although its still at 10.0 but I'll be able to data log now
Old 03-16-2014, 05:15 PM   #25
Even if its a older kit you will be more than fine up to 12 psi or so. 14 and thr backpressure gets bad on the old kits. What size is your wastegate?
Old 03-16-2014, 10:13 PM   #26
86 muscle's Avatar
46mm precision unit
Old 03-16-2014, 10:37 PM   #27
Your good to go then.
Old 03-16-2014, 11:11 PM   #28
I have a built motor on a 300 shot but have only tracked it once. And was spinning the whole time
I need to do more roll racing lol
CoyoteEatsBirds is offline   Reply With Quote
Old 03-17-2014, 07:16 AM   #29
86 muscle's Avatar
So far I'm thinking the same thing lol
Old 03-17-2014, 08:46 AM   #30
Where you going with this?
Old 03-17-2014, 08:57 AM   #31
I have had personal exp with the single hellion.
7 psi- 547hp. 67mm- stock motor poped
12 psi- built motor. 610hp 67mm - oil scavenger pump went out. Trashed turbo
14- psi. Another built motor. 78mm comp. 640hp. Lifted head and destroyed block. Due to backpressure.
Old 03-17-2014, 10:22 AM   #32
Nowhere just mentioned it.
Old 03-17-2014, 06:26 PM   #33
Alerotaz's Avatar
Easy check...
Pull a plug and look at it..
I had an 2005 that I thought ran rich. Of course the shop kept telling , aww no its not..
Guess what.. they were foul... of course the plugs were also the poor 3 piece design. They had to take the heads off to get them out. I tired to get them out myself and felt it give on two of them..
Now I know why they didn't want to do it under warrenty.. I raised Holy Heck and showed them the paperwork from before. I only had to pay a third of the bill, that was better than nothing.. I dont go there anymore either.
Guess my point is dont wait to long to make sure your not running rich. It can clog up the Cats too. <--- another long story..
Alerotaz is offline   Reply With Quote
Old 03-17-2014, 06:35 PM   #34
He dosent have cats.
Old 03-17-2014, 06:54 PM   #35
Alerotaz's Avatar
Follow up..
Sorry,
I didnt know. I re-read the above comments and never saw he removed them.
I take it no backflow issues then??
I'm not a turbo expert, just a car guy.. I used to mess with Old muscle,and left the original 4.6's alone when I heard they were tempermental..
Washing the car to much Mastertz7 2011-2014 Mustang GT 13 03-13-2014 10:29 AM
98 GT running rich? XSlashDashX 1996-2004 Mustang GT 0 12-25-2013 06:59 PM
Car running lean, help! Evolution 1979-1995 Mustang GT 22 09-03-2013 06:46 PM
My feelings after 6 weeks of owning my first American car (long) fastfoal General Mustang Discussion 6 07-31-2013 05:21 PM
2012 Mustang Roush Accident, Please Help/Input! GearHead5Point0 2011-2014 Mustang GT 87 03-26-2013 10:19 PM
08:25 AM
