Rear axle - Mustang Evolution
Old 03-18-2014, 07:52 AM   #1
20Mustang13's Avatar
Region: Delaware
Rear axle
Has anyone noticed their left rear axle sticking out a 1/4in? I took mine to the dealer and they didn't see anything wrong. They just said, the new Shelby wheels will stick out further. Which I know that but I don't think one side should stick out further. Am I right?
20Mustang13 is offline   Reply With Quote
Old 03-18-2014, 08:01 AM   #2
nhcowboy's Avatar
You buy it new or used?
Is it lowered?
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 03-18-2014, 08:38 AM   #3
Grabber Blue5.0's Avatar
Even cars from the factory could use an adjustable panhard bar. And if you're lowered you absolutely need one.
Old 03-18-2014, 08:46 AM   #4
Region: Delaware
I have not lowered it and I bought new
Old 03-18-2014, 01:59 PM   #5
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Hey,
As mentioned before, these axles do have a tendency to shift a bit even without lowering the car. If one side is sticking out a bit more than the other, it is usually a tell tale sign that it will need to be adjusted. This can be done with just about any pan hard bar, and is a relatively easy fix.
I hope this helps, and if you have any other questions, feel free to get back in touch. Good luck!
-Dan
Old 03-19-2014, 03:11 AM   #6
Region: Delaware
Thanks Dan. Really eases my concern.
Old 03-19-2014, 08:35 AM   #7
Um...The axles don't "shift" in their mounts, those are fixed on a link rear, unless you bend the axle tube or the chassis. There's just production tolerances and it's irrelevant anyway. If the axles shifted post assembly, the alignment would likely be off.
If the car is tracking straight, then the thrust line of the car at the back is lined up with the front and don't worry about it. If you're OCD and need this to be visually perfect, you can pull it over a bit with a panhard bar, at the cost of inducing a tiny bit of extra binding force on the bushings out back. Really OCD? Loosen up the LCA and UCA bolts, pull the axle over and retorque everything.
...or just drive on....
Old 03-19-2014, 10:04 AM   #8
Region: Delaware
Cool il just get a panhard bar and call it a day thanks
Old 03-20-2014, 09:17 PM   #9
CNFLCTD's Avatar
I had the exact same issue. It became even more apparent with my wide RTRs on. I installed an adjustable panhard bar and am golden now. Perfectly centered.
CNFLCTD is offline   Reply With Quote
Old 03-20-2014, 09:21 PM   #10
gtstyles2's Avatar
Yea that's normal, when u slap wider wheels on it, it's more obvious.
2014 convertible gt - rear spring replacement without sub brace removal?? jzaphiris 2011-2014 Mustang GT 5 01-22-2014 08:21 PM
Rear end Gears fastforddad 2005-2010 Mustang GT 10 08-21-2013 08:40 PM
Mustang 2 motor swap. Curtiswhitehead 2.3 Mustang 2 07-10-2013 08:06 AM
Rear End Swap Sycopath80 2005-2010 V6 Mustang 3 12-30-2011 11:25 AM
Rear end clunk Brad.krieg SVT Mustang 3 12-08-2011 12:05 AM
09:51 PM
