3.73? - Mustang Evolution
Old 03-21-2014, 01:42 AM   #1
3.73?
Are the 3.73 gears a part of the brembo package?My 12 GT has the Brembos and track wheels,im curious if having these means that the car has the 3.73's.Ive never driven another 5.0 and dont no anybody that does so i cant drive somebody that doesnt have them to compare versus mine.Basically my question is how do i know if i do or dont have 3.73 gears option?
Thanks guys
BigBlue5.0 is offline   Reply With Quote
Old 03-21-2014, 02:03 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Look at your rear diff. There should be a label on there with what gears you have installed. You can also look at the vehicle info sticker in the driver side door jamb. Towards the bottom is an axle code. Match it up with this list to see what you have. http://stangu.com/2011-2012-2013-mustang-gt-axle-codes/
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 03-21-2014, 02:06 AM   #3
Thanks thats exactly what im looking for,will check first thing in the morning!
Old 03-21-2014, 09:01 AM   #4
ddtmoto's Avatar
Region: Utah
Door/frame sticker shows code for axle ratio as it was from the factory, google the two letter code it from there. 3.73 was a separate option for these cars.?
Brembo50.com this site has some good info...
ddtmoto is offline   Reply With Quote
Old 03-21-2014, 09:12 AM   #5
No requirement for 3.73 with BBP. It was available with any gearset. The 3.73 was a separate option and is on the door tag or on a tag on the rear end itself. If the car is used, you can verify by raising rear and spinning the tire through a revolution, marking the driveshaft with a paint pen and watching the driveshaft turn. Counting the number of DS revs for each tire 360 will tell you the ratio.
Track Pack cars for 13+ have 3.73 standard.
Old 03-21-2014, 07:53 PM   #6
Put your VIN in after the = sign and pull up your build sheet to see everything the car was built with:
services.forddirect.fordvehicles.com/inventory/WindowSticker.pdf?vin=
2010 Sterling Grey Premium GT 3.73 axle 5spd
FRPP Cams, intake, TB and CAI
BBK LT headers, fuel rail and UD pullies
Hurst Shifter
Lowered with upgraded rear suspension
Galaxie64 is offline   Reply With Quote
4.10 over 3.73 Polar Bear 1996-2004 Mustang GT 64 11-10-2013 05:20 PM
Anyone go back from 3.73 gears? lcseds 2011-2014 V6 Mustang 14 10-14-2013 08:21 AM
3.73 Ford Racing gears m_tyler_r 2011-2014 V6 Mustang 42 12-03-2012 10:20 PM
3.73 gears & MPG. Junkyard 2011-2014 Mustang GT 34 07-21-2011 01:40 AM
04:47 AM
