Boss intake & Steeda CAI dyno results - Mustang Evolution
Old 03-22-2014, 03:44 PM   #1
Compstall's Avatar
Just to share, as I've seen over the years with many parts, it's good for about half of what's advertised.
Notes: Bama race tune, same dyno used as before (Dynojet)
Last run and current run are on the sheet. Last run was with Roush mufflers and just the tuner only (race tune).
+10 hp peak
-22 tq peak
~ 30 hp & 20+ tq gained up high.
Sent from my iPad using Tapatalk HD
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 03-22-2014, 05:03 PM   #2
knight5.0's Avatar
The blue run file the boss intake?
Sent from my SCH-I535 using Mustang Evolution mobile app
Black 2011 Mustang GT Premium
Manual transmission, SS clutch line
Brembo brake package
Steeda CAI, Borla axle back & BBK X pipe
And Jon (Godfather tuner) Lund tune
knight5.0 is offline   Reply With Quote
Old 03-22-2014, 05:08 PM   #3
Charlie_santos's Avatar
Bro u need a real tune, those numbers are low, buddy of mine made more with boss mani
Old 03-22-2014, 05:11 PM   #4
He made 429hp and 379tq
Old 03-22-2014, 05:19 PM   #5
Rapinator126's Avatar
What were his mods to make that?
Rapinator126 is online now   Reply With Quote
Old 03-22-2014, 05:22 PM   #6
knight5.0's Avatar
Yeah. I'm running a Lund tune and got 410 hp and 390 torque. Have steeda intake and borla mufflers with X pipe.
---------- Post added at 11:22 PM ---------- Previous post was at 11:22 PM ----------
And I have stock manifold
Old 03-22-2014, 05:23 PM   #7
Boss mani, BBK O/R mid, muffler deletes and race bullets in place of stock resonators
Old 03-22-2014, 05:29 PM   #8
Happy dyno
Old 03-22-2014, 05:34 PM   #9
Charlie. It was a happy dyno or not corected #'s. If he had longtubes that would be about right.
Old 03-22-2014, 05:36 PM   #10
OP. those #'s are right. Considering you did not post if you had a offroad mid pipe. So im quessing still have stock cats.
Old 03-22-2014, 05:51 PM   #11
Loc: Austin,TX
Exactamundo. Sounds about right for a car with cats.
Old 03-22-2014, 06:21 PM   #12
Compstall's Avatar
Yep, stock cats and h-pipe. X-pipe is going on next, then another dyno. Hoping the X will compensate a bit for the loss of torque in the middle.
- Brent
Old 03-22-2014, 06:22 PM   #13
Happy dyno
Nope, corrected numbers, that's on a AED tune not bama lmao
Old 03-24-2014, 07:58 AM   #14
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
+10 hp peak
-22 tq peak
This graph looks good! Your numbers look pretty good for your Modifications. What transmission do you have? What gear did they do the pull in? This will just help us figure out that the overall numbers are exactly what they're supposed to be.
Either way, the numbers look like they're in the right ball park. The gains you're seeing are spot on from what we've seen with the boss manifold. You'll sacrifice a little bit of low end and mid-range but the car should pull very smooth through the RPM's and you'll gain a ton up top.
I hope this helps. Adding a set of long tubes and/or O/R mid-pipe will push you well into the low 400 RWHP range. Keep up the great work with your car. Let us know when you add an O/R X-Pipe and we'll gladly update your tune for you!
-Dan
Old 03-24-2014, 09:52 AM   #15
Dan,
How does this look great? It makes gains in the most inaccessible part of the rev range on road and loses or is neutral almost everywhere else. Are you seeing something I'm not?
You also aren't making sense. Curve gains are lower than peak typically. Peak is the biggest improvement point over stock, in this case, the 7200 point. Curve gains need inspection of the graph to quantify. It's pushing the whole curve up the graph, which this isn't really doing very much.
Old 03-24-2014, 10:35 AM   #16
Originally Posted by 5LHO View Post
Dan,
Its a bama tune. I have posted abput them 100 times. They the #'s there suposes to. But there tunes suck. Which proves #'s dont mean ****
Old 03-24-2014, 10:46 AM   #17
M_Andrews's Avatar
Name:	ImageUploadedByMustang Evolution1395679322.230958.jpg
Boss intake manifold
L/T headers
Catted X-pipe
Airaid C/A
Muffler delete
NX 100 on about a 800 psi bottle
Still with the bama tune
510 hp
515 tq
M_Andrews is offline   Reply With Quote
Old 03-24-2014, 11:20 AM   #18
AmericanMuscle.com
Sponsor
Dan,
The Boss intake manifold is responsible for the gains and losses and has absolutely nothing to do with the tune. You definitely sacrifice a little low end and mid range but you do gain a ton of top end horsepower and the car pulls very smoothly throughout the RPM range. This is because the intake works better with more modifications. The Boss has an upgraded valvetrain and you'll notice the Boss is rated at low torque numbers than a GT. That is because it makes mid range peak torque.
We would recommend that you would buy this mod if you had plans to build your motor, add long tubes, Nitrous, Supercharger, Turbo etc..
-Dan
Actually his tune is spot on and his numbers look good. What is his reason for needing a new tune?
-Dan
Old 03-24-2014, 11:20 AM   #19
Why do you have the nitrous hitting under 3k rpms? And i sure hope thats wheelspin
Old 03-24-2014, 11:25 AM   #20
Dan never said his numbers were not spot. On i said bama tunes are junk as you can clearly see by the graph. Not talking about the #'s the #'s are fine.
Old 03-24-2014, 11:28 AM   #21
knight5.0's Avatar
haha, looks like ski slopes
Old 03-24-2014, 12:38 PM   #22
Grabber Blue5.0's Avatar
Originally Posted by M_Andrews View Post
Attachment 151732
L/T headers
Catted X-pipe
Airaid C/A
Muffler delete
510 hp
515 tq
That's one of the worst graphs I've seen. You can't be happy with it?
Old 03-24-2014, 01:00 PM   #23
M_Andrews's Avatar
The shop that's done the work said the peaks and valleys in the power band were due to low bottle pressure.
At the time of the dyno there wasn't a window switch because the switch was faulty and I had to get a different one.
And the low bottle pressure was because the bottle wasn't on heater, that being because the bottle doesn't have a pressure transducer yet.
Does that add up?
I mean the low pressure seems like it might be at fault to me.
What else could be causing that?
---------- Post added at 07:00 PM ---------- Previous post was at 06:59 PM ----------
On a heater*
Old 03-24-2014, 01:03 PM   #24
Wally should have known better then to spray below 3k rpms. Thats asking for trouble on a stock motor. Those dips would not be caused by a 800psi bottle pressure. Alot of it is the tune. Let wally do aactual dyno tune for you bud.
Old 03-24-2014, 01:04 PM   #25
Compstall's Avatar
-Dan
Trans is an M6, I did the pull in 5th gear.
Pipes ORX is already on order Dan. That should compensate a bit for the loss in the middle.
I agree the Boss mani isn't a good "street" mod, but I don't street race and I'm satisfied with the power driving around town. On the dragstrip the car isn't sitting down in the low rpm range so it really isn't a problem there.
- Brent
Old 03-24-2014, 01:27 PM   #26
So, what's it delivering at the dragstrip? That's the next question begged by your response. My bud's full exhaust/tune car runs ~118 trap, through the 5.0 manifold. It's a well optioned Premium car, too. I'm at 115 on Procal 91, alone. How's that compare with what you are seeing?
What I'm seeing here is the Boss mani is not a worthwhile mod unless paired with a bunch of other mods to take advantage of it. I be thinking longtubes and off-road at least, plus an aggressive tune. The mani alone is somewhat pricey and when you add in the seemingly necessary other breathing mods, it's just not delivering much value, imho.
Old 03-24-2014, 01:51 PM   #27
Compstall's Avatar
I haven't been to the track in a couple seasons. Originally I ran the car stock and it was trapping right around 111. I plan on hitting the strip sometime soon and we'll see. Last time I ran, the car would run out of 4th gear less than 100' or so before the finish line; I'm thinking the raise in RPM will carry me through now on street tires. Some ET streets would be nice.
- Brent
Old 03-24-2014, 01:59 PM   #28
Gotcha there. I was just over the limiter in fourth on 26" tires on 3.73. I solved my problem with a 28" slick. Now it's just perfect, right at the stripe.
Old 03-25-2014, 08:27 AM   #29
AmericanMuscle.com
Sponsor
Very cool! 110-111 is a pretty common trap speed for a stock 2011+ Coyote. Running out of gear is tough, the same thing happened to me! I definitely recommend getting a 28" tall tire. This will allow you to finish in 4th.
I have Full Exhaust, Boss Manifold, Intake, Upper/Lower Control Arms and a Bama custom tune. I was able to run a 11.87 @ 119.7 on a 90* day. The car was also on the stock clutch which was very upset with me after the first few passes. I was limited to a 1.74 60FT that day because of the stock clutch. Now that I have a Twin disc and some other goodies, I hope to see some 10-Second passes!
Hope this helps you out.
-Dan
cai
Steeda, MPT, Bama, Dyno results in 2011 Kona Blue General Mustang Discussion 27 10-03-2013 10:52 AM
Boss intake, Steeda cai, SVT Tune GBlueGT 2011-2014 Mustang GT 10 08-29-2013 10:43 AM
AM CAI & Tune Dyno Results CYCLON37 2011-2014 V6 Mustang 13 07-27-2012 12:38 PM
Dyno Results - Bama 93P & 93R Tunes Sl1nk 2011-2014 V6 Mustang 2 06-28-2012 08:01 AM
'08 GT500 Dyno Results ~ Before & After Mods molasses General Mustang Discussion 13 12-03-2008 02:37 PM
07:31 PM
