Popping noise coming from the rear and when breaking - Mustang Evolution
Old 03-27-2014, 08:42 PM   #1
Redonblackpony's Avatar
Has anyone experienced a popping or clunking noise coming from the rear end when breaking hard to a stop or going over bumps slowly? My car just started making this noise a week ago and I can't quite figure out what it is. I thought it might be the rear sway bar binding, but it wasn't. It sounds like it's coming from the shocks in the rear. I might add also that I have a Steeda X brace that connects to the shock tops and the chassis. I've had the x-brace almost a year and the noise just started a week ago. Anybody had this problem?
Redonblackpony is offline   Reply With Quote
Old 03-27-2014, 08:44 PM   #2
That's braking, not breaking. Lol
Old 03-28-2014, 07:37 AM   #3
You sure it ain't the infamous sway bar end links? Did it get cold where you are suddenly? Mine went out during a cold snap recently. Ford replaced them, no questions asked, along with the leaky right rear shock.
I'd already taken the swaybar out to verify the noise and yep, that what it was coming from.
...and thanks for correcting your own grammar; almost nobody cares how stupid they sound anymore.
Old 03-28-2014, 08:26 AM   #4
I'm fairly certain that it's not the swaybar end links. I got the car up and lubricated the bushings pretty well. I moved them back-and-forth, rechecked it still makes the same noise. The noise is most noticeable when driving slow and putting the brakes on hard to a stop then letting off. It's definitely suspension related. Could be the shock but I'm not sure.
Old 03-28-2014, 08:42 AM   #5
I'd just drop the bar and be sure. It's a couple minutes work and will eliminate that as a cause. Make sure those shocks nuts are still tight, since you removed them to put on the X brace.
Old 03-28-2014, 11:10 AM   #6
I'll check it out this weekend. Thanks for the info.
Old 03-29-2014, 07:15 PM   #7
Well it's not the rear sway bar. I Dropped it out of the way, still makes the popping noise.
Has anyone had problems with the rear Brembo shocks? It sounds like the noise is coming from that area. When driving over bumps at any speed, the popping occurs.
Old 03-29-2014, 07:24 PM   #8
It sounds like something is in the trunk bumping around when I hit a bump while driving. And it's not the spare tire cover. I took all that out to trouble shoot. Certainly someone out there has had this problem.
Old 04-23-2014, 08:47 AM   #9
Mattjohnson's Avatar
Just took my car to ford for them to figure it out.
Mattjohnson is offline   Reply With Quote
Loud popping sound coming out of the exausht SlV6power Pre-2005 V6 Mustang 4 05-14-2013 01:37 PM
2nd gear popping popping out Cleancobra22 General Mustang Discussion 4 05-29-2012 08:36 PM
Weird popping noise from rear iwannagofast 1996-2004 Mustang GT 1 05-12-2009 12:10 AM
popping noise??? girlandherstang Pre-2005 V6 Mustang 8 06-28-2008 10:20 AM
Popping Noise 98StangGT 1996-2004 Mustang GT 8 08-04-2006 11:11 PM
08:46 AM
