Sr performance - Mustang Evolution
Old 03-28-2014, 07:04 PM   #1
yotefox21's Avatar
Sr performance
I'm about to spend some money on the following and before I do was wanting some insight on SR Performance.
I was planning on going with SR Performance lowering springs, adjustable rear upper control arms and fixed lower control arms as well as a lightened drive shaft. Vs spending for the Steeda.
Is this a pay for what you get for kinda brand or bang for buck are they comparable to the more expensive brands..?
Sent from my SCH-R530U using Tapatalk
yotefox21 is offline   Reply With Quote
Old 03-28-2014, 07:26 PM   #2
BigCiv's Avatar
I have the SR lowering springs, no issues. I also have the lca's and had to remove them yesterday due to one of the bushings being deformed. It was causing my rear end to slide under acceleration which is not as fun as it sounds. Maybe I just got a defective set, but if I had to do it again I'd go with the steeda lca's.
Sent from my Nexus 7 using Mustang Evolution mobile app
BigCiv is offline   Reply With Quote
Old 03-28-2014, 11:38 PM   #3
Compstall's Avatar
I have these springs also just not installed yet. Are camber bolts required or can I get away without them?
Sent from my iPad using Tapatalk HD
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 03-29-2014, 12:09 AM   #4
BigCiv's Avatar
I didn't need them. I waited a while after install and took it to an alignment shop. Everything was within spec, no adjustments needed.
Old 03-29-2014, 12:45 AM   #5
Compstall's Avatar
Thanks for the info.
- Brent
Old 03-30-2014, 05:23 PM   #6
Compstall's Avatar
By the way, did you flip the upper mounts 180 degrees when you installed the springs? Was reading about this on another forum.
- Brent
Old 03-30-2014, 07:15 PM   #7
BigCiv's Avatar
I don't think so but not sure; I paid a shop to install them.
Sent from my Nexus 5 using Mustang Evolution mobile app
Old 03-30-2014, 07:29 PM   #8
Compstall's Avatar
Saw BMR tech talking about it, said the mounts can be flipped 180 and no need for camber bolts.
- Brent
Performance Upgrade Flex Pre-2005 V6 Mustang 0 07-18-2003 11:00 AM
04:41 AM
