New Upgrades - Mustang Evolution
Old 03-30-2014, 06:31 PM   #1
New Upgrades
Had a busy weekend the past three days. Take note I'm really not that mechanically inclined when dealing with cars. To start off I took off all of the stock exhaust piping from the headers to the axle backs. Had to cut the OTA pipes cause i didn't have enough clearance with just ramps and jack stands. I installed JEGS cat deletes and their high flow pipes which also gets rid of the resonators and is an H pipe. This took several hours.
I then installed Steedas CAI which only took 15 minutes.
Finally, I uploaded the tune from Steeda and started it up with no problems.
Holy loud. Haha. I went for a drive and already had people looking, but there was clunking and extra bouncing coming from the rear when going over bumps. I went back home and found the source. Moved the OTA pipes around a little which significantly removed the clunking. Only happens now over large bumps.
The tune seemed to stutter the engine on the first drive when stepping on the throttle, but on the second drive seemed fine.
I will be checking it all on Wednesday to make sure everything is tight and in place.
Name:	ImageUploadedByMustang Evolution1396225795.901906.jpg
Name:	ImageUploadedByMustang Evolution1396225773.727485.jpg
Name:	ImageUploadedByMustang Evolution1396225831.627131.jpg
ID:	152373Click image for larger version
Name:	ImageUploadedByMustang Evolution1396225839.840087.jpg
ID:	152374Click image for larger version
Name:	ImageUploadedByMustang Evolution1396225845.991687.jpg
ID:	152375Click image for larger version
Name:	ImageUploadedByMustang Evolution1396225854.342892.jpg
2013 Mustang GT Borla S Types JEGS cat deletes and hi flo exhaust h pipe - YouTube
Old 03-30-2014, 06:39 PM   #2
Low_50's Avatar
Sounds good man nice job!
Low_50 is offline   Reply With Quote
Old 03-30-2014, 06:46 PM   #3
Deerslayer's Avatar
Nice work Travis!
It was doing a idle relearn on your first drive. After you load a tune, you should do this to get it to learn the new setup.
Whether you are switching tunes for your 2011 2012 2013 Ford Mustang GT or just have idle issues you can try the suggestion that is right in your owners manual (this works great on our stangu.com mustang) – below is the exact wording from the manual on the 2011 2012 2013 Ford Mustang GT Idle re-learn instructions:
1. With the vehicle at a compete stop, set the parking brake.
2 Put the gearshift in P (Park) (automatic transmission) or the neutral position (manual transmission), turn off all accessories and start the engine.
3. Run the engine until it reaches normal operating temperature.
4. All the engine to idle for at least one minute.
5. Turn the A/C on and allow the engine to idle for at least one minute.
6. Drive your Ford Mustang gt to complete the relearning process.
The vehicle may need to be driven 10 miles or more to relearn the idle and fuel trim strategy.
If you do not allow the engine to relearn its idle trim, the idle quality of your vehicle may be adversely affected until the idle trim is eventually relearned.
Sometimes we will need to do this when we disconnect the battery as well such as if you store your car for the winter this might be a thing to put on the check list.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 03-30-2014, 07:02 PM   #4
Ah good to know. I'll be driving it tomorrow morning to work which is exactly 10 miles. Should be good by them. My only fear is the exhaust falling apart. Haha. I torqued all the brackets to factory specs. Still makes me nervous though.
Old 03-30-2014, 11:29 PM   #5
2013_DIB_GTCS's Avatar
For those of us newer to tuning, deerslayers post would make a great sticky. Hopefully an admin sees this and makes it so.
2013_DIB_GTCS is offline   Reply With Quote
Old 03-31-2014, 03:54 AM   #6
Grabber Blue5.0's Avatar
I've never had to do an idle relearn with my car.
Old 03-31-2014, 06:00 AM   #7
Mastertz7's Avatar
Sounds great.
Mastertz7 is offline   Reply With Quote
New upgrades put on Kamman 2005-2010 Mustang GT 23 03-12-2013 09:10 AM
Blackedout new upgrades Blackedout Pre-2005 V6 Mustang 5 02-04-2013 07:10 PM
New upgrades. Jdunx98GT 1996-2004 Mustang GT 19 05-03-2012 10:20 PM
Exterior upgrades and maybe performance upgrades RedToplessPony 2011-2014 V6 Mustang 34 12-26-2011 04:09 PM
New Upgrades Topxshelfxtre Pre-2005 V6 Mustang 43 04-22-2010 07:54 PM
11:45 AM
