GT Track Key Available - Mustang Evolution
Old 04-04-2014, 06:11 AM   #1
I've been checking the site every now and then, and it looks like the key is finally up for sale (plus the software to go with it). Has anyone pulled the trigger on this yet?
2014 MUSTANG GT TRACK KEY -- M-14204-MGTTKA
Nole is offline   Reply With Quote
Old 04-04-2014, 08:32 AM   #2
KARgt13's Avatar
I do see that if you have a '13 they have a Procal tuner that does the same thing as the track key and is not the same as the old Procal tune. It makes it sound like you can use the display on the instrument cluster to select the track key mode or something.
KARgt13 is offline   Reply With Quote
Old 04-04-2014, 09:05 AM   #3
Deerslayer's Avatar
We will be doing some experimenting with this one......
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 04-04-2014, 09:07 AM   #4
ArtU's Avatar
Awesome ! So Glad I got a manual, and that they offer it as a ProCal upgrade since I don't have a dual path ECM. This is the part I must have as I have a 7/100K bumper to bumper.
[INSTALLATION AND USAGE SPECIFICALLY DOES NOT VOID THE ORIGINAL WARRANTY}
Old 04-04-2014, 09:10 AM   #5
Deerslayer's Avatar
LOL, that would be what I hear if we went in for warranty work
Old 04-04-2014, 01:07 PM   #6
KARgt13's Avatar
Only if Ford installs it.
Old 04-04-2014, 01:38 PM   #7
ArtU's Avatar
yes, but that's no big deal.
Edit: But it does have a deal killer for me. I have a 7/100K B-to-B warranty. Use of this product replaces the original factory warranty for engine, drive-train, and suspension for a warranty of only 3/36K from the original date of purchase of the car. So this kisses goodbye any engine failure coverages triggered by use of a track product that have been due to the "causal" part past 36K or 3 years of car purchase date.
Cams and fingers ticking at 39K? Well you probably were racing on a track being you got track key installed...I can hear it know....
I'm Sorta bummed ;(
Old 04-04-2014, 05:35 PM   #8
I have an early 14 so the procal is my only option too, but reading more it looks like there is no way to have both (which kind of defeats the purpose). You have to basically tune your car with the procal and have the "track key" tune permanently installed until you have it flashed back or man-up and go for an aftermarket tune.
Old 04-04-2014, 05:45 PM   #9
2013 Green GT's Avatar
Can't wait to see some real results regardless the key or tune. Let's see some numbers or slips. Great idea by ford... Want to see the results. Please share!
2013 Green GT is offline   Reply With Quote
Old 04-04-2014, 06:00 PM   #10
ArtU's Avatar
Originally Posted by Nole View Post
...Snip>> You have to basically tune your car with the procal and have the "track key" tune permanently installed until you have it flashed back or man-up and go for an aftermarket tune.
No need to MAN UP, I have had other mustangs I have tuned. But this last Purchase has to last for 10 years. If you have a trust fund, U go Man UP.
I will keep my 7/100k Be-To-Be warranty until then...As I don't want to have to eat Soylent green or mac n' cheese based on my Car's Tunes...
Old 04-04-2014, 06:21 PM   #11
No offense meant, I like my warranty as well. I was just getting at I don't have the key option so basically its just another "safer" tune until you get to the next level
Old 04-04-2014, 09:15 PM   #12
Deerslayer's Avatar
What if you could have two separate aftermarket tunes.....key activated..........
Old 04-05-2014, 11:48 PM   #13
ksnapp's Avatar
Region: Oregon
Anyone read this?
Black Key vs. TracKey: A Dyno Comparison. - The Mustang Source - Ford Mustang Forums
ksnapp is offline   Reply With Quote
Old 04-06-2014, 10:09 AM   #14
Deerslayer's Avatar
Yes, Drew is legit. He is on BMO as well. That thread has been around for a while.
Precisely why we are gong to try to flash the PCM to a dual path with the software and then see if we can override the RedKey tune with an aftermarket tune. Idea would be to have a 91 performance tune on the black key and a 93 race tune on the red. (what Ford should have done in the first place)
Old 06-13-2014, 12:57 PM   #15
track key
http://youtu.be/KFfPE59Wja0
disc0monkey is offline   Reply With Quote
Old 06-14-2014, 03:19 PM   #16
got my track key.
pretty pumped.
Old 06-14-2014, 03:54 PM   #17
GrabberBlue13GT's Avatar
Probably going to sound stupid. But I have a 13 with remaining warranty and just wandering what this is?
Sent from my VS980 4G using Mustang Evolution mobile app
GrabberBlue13GT is offline   Reply With Quote
Old 06-14-2014, 09:40 PM   #18
Will other companies, such as bama, be able to possibly reverse engineer this and take some good qualities like the launch control, and add it to their tunes?
Kjdjr18 is offline   Reply With Quote
Old 06-15-2014, 08:44 AM   #19
I am wondering this also. After reading more on it, and not being tuned yet I am leaning more to the track cal.
Old 06-16-2014, 05:34 AM   #20
Paradone's Avatar
track key
My 2014 build date is 10/13 just not sure I will try it yet seems like a Ford "ghost cam" tune with a small increase in HP/TQ. I think I will wait to see some opinions from folks who do it.
Paradone is offline   Reply With Quote
Old 06-16-2014, 01:25 PM   #21
gt5.0nc's Avatar
Just got the track key installed on my car. I love it. The idle alone is worth it. I had it installed this afternoon. Ill have some more updates once I've driven it for a little while.
gt5.0nc is offline   Reply With Quote
Old 06-16-2014, 02:15 PM   #22
Definitely give me some updates because I am really leaning this way!
Old 06-16-2014, 04:02 PM   #23
gt5.0nc's Avatar
Here a link to the idle
2014 Mustang GT with track key: http://youtu.be/0bTzK_yFVR8
Sent from my SPH-L900 using Tapatalk
2014 Base GT, M6, Brembo Brake Package, Solo Performance Mufflers, resonator delete, JLT Catch Can, Steeda Sport Springs, TrackKey
Old 06-16-2014, 04:54 PM   #24
Sounds nice! I'm getting mine installed on Wednesday. How long did it take the dealer to do the install?
Current Mustang: '14 GT/Track Pack/6spd-sold
Previous Mustangs: '68 Coupe, '73 Mach 1, '89 GT,
Hoss is offline   Reply With Quote
Old 06-16-2014, 04:58 PM   #25
gt5.0nc's Avatar
I had an oil change done and track key installed and it took about three hours. I wasn't waiting on it so there was no hurry to get it done.
Old 06-16-2014, 05:11 PM   #26
Sounds wonderful!! Can you feel any extra power?
Old 06-16-2014, 05:14 PM   #27
gt5.0nc's Avatar
Yeah I can. And the throttle response is better, no more delay.
Old 06-16-2014, 05:22 PM   #28
Thanks a lot for the quick response! I think you just helped me spend some money lol
Old 06-16-2014, 05:38 PM   #29
gt5.0nc's Avatar
You definitely won't regret it. When you are sitting at a light and the car is rocking back and forth like crazy because of the lopey idle. It will put a smile on your face!
Old 06-16-2014, 09:02 PM   #30
JPrider's Avatar
What mods do you have?
2014 Mustang GT Premium, Grabber Blue, GT Track Pkg, Navigation System w/rear sensor
JPrider is offline   Reply With Quote
Old 06-16-2014, 09:05 PM   #31
gt5.0nc's Avatar
Just GT500 mufflers and resonators deleted.
Old 06-16-2014, 10:37 PM   #32
How much for the track key install ?
dentman43 is offline   Reply With Quote
Old 06-16-2014, 10:39 PM   #33
I want that installed on my 14 gt will it work with my base model gt
Old 06-17-2014, 06:09 AM   #34
gt5.0nc's Avatar
The shop will most likely charge you an hour labor rate to do it. That's what Ford recommends for time in the instructions. My car is a base GT. The only requirements are that it has to be built after 7/1/2013, 5.0, and a manual.
Old 06-17-2014, 07:25 AM   #35
Awesome my GT was built after that date , will this void my warrantee ??
Bolt-ons with track key? mrsneakyz28 Boss Mustang 6 12-23-2015 10:06 AM
Track key coming soon Whiteboss302 Boss Mustang 4 09-14-2014 10:07 AM
track key corey herron 2005-2010 Mustang GT 1 07-31-2013 07:00 AM
track key Mord Fustang Boss Mustang 10 04-03-2012 10:12 AM
Track Key is coming wnt2gofst Boss Mustang 0 10-07-2011 05:55 PM
08:21 AM
