Clink shifting down from 3rd to 2nd. - Mustang Evolution
Old 04-07-2014, 10:39 PM   #1
PISTONS8904's Avatar
I have a 2013 gt. I have an automatic. There is a clunk when during in drive going from 3rd to 2nd and it's loud you can hear it from the outside. When I ride in select shift mode it doesn't want to go to second and what I mean by that when I'm downshifting to a stop it wants to stay in 3rd and go straight to 1st when I stop no clunk. But if I down shift it to second it wants to drag the vehicle hard and clunk depending at what Rpm I'm at the louder it is the lower rpm. It doesn't do this on any other gear up or down. Please any advice is welcome I'm nearing warranty end.
PISTONS8904 is offline   Reply With Quote
Old 04-08-2014, 04:15 AM   #2
Clink's Avatar
Sorry I have nothing to help but I thought this thread was a question for me lol.
Old 04-08-2014, 09:41 AM   #3
Sunnycalibear's Avatar
It must be a synchro going out I'd say stop downshifting it's not going to help and use that warranty before it ends!!
Sunnycalibear is offline   Reply With Quote
Old 04-08-2014, 09:43 AM   #4
A snychro?
Old 04-08-2014, 09:45 AM   #5
Yeah that's what I would think it would be.
Old 04-08-2014, 09:47 AM   #6
I do t even know what that is. I'm taking it to the dealership Thursday to do a ride a round is what they say to figure out what's going on with it. I have a tune on it now. Will they be able to check if I have ever had a tune on it even if I put the stock tune back on?
Old 04-08-2014, 09:55 AM   #7
You should remove the tune and any mods that you think would void warranty. How many miles do you have?
Old 04-08-2014, 09:57 AM   #8
30 k the other mods are not affecting it. Coilovers, tires, and rims...
Old 04-08-2014, 09:58 AM   #9
Have you been driving that thing hard? Downshifting a lot and smashing thru gears?
Old 04-08-2014, 10:06 AM   #10
rockhillgt's Avatar
its an automatic...
rockhillgt is offline   Reply With Quote
Old 04-08-2014, 11:47 AM   #11
ford302ize's Avatar
Take it to the dealer while it is still under warranty. I would think you still have a lot of time though as the power train warranty is 5 years/60,000 miles. Also, I would ride in the car with them to show them the problem so that they can't say nothing is wrong.
My Toys. 2014 GT Base with Manual Trans. Borla S-Type Axle Backs. 2005 Honda VTX 1300C.
ford302ize is offline   Reply With Quote
Old 04-09-2014, 10:04 AM   #12
How do you not drive it hard? Lol
Old 04-09-2014, 10:34 AM   #13
If you have ever had a tune on it, as you just stated, your most likely going to have the warranty voided. They can tell if it has had a tune, even if you flash it back to the stock tune.
Old 04-09-2014, 10:34 AM   #14
How do they tell?
Old 04-09-2014, 10:42 AM   #15
Originally Posted by PISTONS8904 View Post
How do they tell?
If it's any "major" type of repair on the powertrain, they send the ECM to Ford, and Ford has stated that a tune will void powertrain warranty. I'm fairly certain the dealer can tell if the ECM has been flashed when they run through the diagnostics... Ford has issued a TSB on aftermarket tunes.
Old 04-09-2014, 10:44 AM   #16
I just noticed you were from Norfolk, I've probably seen you in the area before, I'm in Suffolk.
Old 04-09-2014, 10:54 AM   #17
MyMustangIsBlk's Avatar
Inside the Ecu there is another log that accumulates all Ecu changes and shows them what you've done if you had a tune on there and they found it even after you took it off back to normal ( it tells them) they have to prove that the tune that was the cause of failure and beings you took it off you can't not prove that it wasn't.. Do ya see ?
MyMustangIsBlk is offline   Reply With Quote
Old 04-09-2014, 11:02 AM   #18
I understand thank you. I'll load stock and there now and actually I'm not in vs anymore in in tn moved stations
Old 04-09-2014, 02:44 PM   #19
powerpony347's Avatar
Defiantly take advantage of the factory warranty before it's out of your pocket.
Sent from my HTC6435LVW using Mustang Evolution mobile app
powerpony347 is offline   Reply With Quote
Old 04-09-2014, 02:49 PM   #20
Oh this baby is going in tomorrow. What's you guys advice on leaving the vehicle overnight?
Old 04-09-2014, 02:55 PM   #21
Clink's Avatar
Tell them you want it stored inside unless you need it to be colder so the problem can be heard.
Old 04-09-2014, 03:18 PM   #22
Well they have me a rental on them they paid for it no deposit Nissan Altima for turning mine in for transmission swap to the new one they sent real peach of a deal if u ask me leave it let them work on it no pressure and ask about the warranty covering u a rental unit you should be a ok on it as I was covered as well. Cheers
Old 04-09-2014, 03:29 PM   #23
Okay sounds good I go to New Orleans for a week that. So Saturday I can turn it in to them and they should be able to take it and work that whole week and when I get back it should be ready.
Old 04-15-2014, 07:24 PM   #24
Name:	ImageUploadedByMustang Evolution1397611482.339362.jpg
Old 04-15-2014, 07:25 PM   #25
Just picked her up from the dealer and got home 2hr drive there and 2 hr drive back I'm exhausted :X
Old 04-16-2014, 01:36 PM   #26
ArtU's Avatar
Originally Posted by MyMustangIsBlk View Post
I looked at this and looks like its the slip for the replaced MT-82 manual trans in the they replace my transmission thread. Is this the slip for your 6auto they replaced? Preheats the forum is sending me the pic of the other receipt I just looked at cached by mistake.
Old 04-16-2014, 09:22 PM   #27
That's for the 6 spd manual tranny they replaced
Shifting up to 2nd KARgt13 2011-2014 Mustang GT 24 09-22-2013 07:21 PM
Weird sound from 2nd to 3rd gear coming from trans maybe? stealthrz 1996-2004 Mustang GT 0 10-04-2012 07:35 AM
2nd and 3rd whine jwhayne0001 1979-1995 Mustang GT 7 10-28-2011 06:11 PM
Belt slips when shifting from 1st-2nd??? mohrnormal 1996-2004 Mustang GT 5 04-12-2006 02:45 PM
April 2nd & 3rd Car Show/ Mountain Run bones90gt Regional Mustang Discussion 1 01-23-2005 07:20 PM
02:35 PM
