Suspension Mod Overkill? - Mustang Evolution
Old 04-10-2014, 09:40 AM   #1
Sterlingbeast5.0's Avatar
OK, I read things on here a ton and I am now starting to question my next set of mods since they are hopefully less than 6 weeks away.
I have a daily driver, never go to the track and only drive on the highway about once every 2-3 weeks. Most all driving is in town between 40 and 60 but I would label it as very spirited!!
I have sort of settled on the list below but now wondering if I am spending more than needed. I do want a lower stance and good handling but it the pro plus kit overkill? Would spring set do just fine?
Eibach Pro System Plus (shocks, struts, springs and sway bars)
Steeda Adjustable Street UCA
J&M Extreme Joint LCA
J&M adjustable pan hard bar
J&M Adjustable Caster Camber Plates
Old 04-10-2014, 09:57 AM   #2
Deerslayer's Avatar
The pro system plus is a really good setup from our experience. Solid choices with your control arms & panhard bar as well. Only thing that I would say is not necessary is maybe the CC Plates. For the drop the EPSP gives you and you don't track it too much, save some $ and just use the CC bolts from Eibach for $35. We ran them with that exact system and it a solid setup.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 04-10-2014, 10:34 AM   #3
If you love to drive your car like it was built then you can never have too much suspension work.
Old 04-10-2014, 10:42 AM   #4
Thanks! I was thinking it might be overkill since I have never taken a car to the track yet. Maybe someday though.
BTW... Voted you for MOTM and you should win. Love what you have done.
Old 04-10-2014, 01:54 PM   #5
tj@steeda's Avatar
If you are looking at more parts than just the UCA ... we have our parts on sale for 10%.
Let me know if I can help assist ... you can reach me at tim@steeda.com.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 04-11-2014, 06:14 PM   #6
HPFury's Avatar
Have you considered BC coil overs? That would make a huge difference. Good luck with ur new setup; installing it is the fun part.
HPFury is offline   Reply With Quote
Old 04-11-2014, 09:27 PM   #7
Deerslayer's Avatar
Thanks NaplesStang! I honestly dont think you can overkill the suspension on a S197. Just degrees of improvement
Old 04-12-2014, 07:04 AM   #8
jayman33's Avatar
Theres parts of this list I would change. Eibach Dampers are pretty terrible at best, the tests ran on these but not only myself but other companies prove there are much better out there. J&M bushings will leave much to be desired as well, one of the reasons BMR is so popular.
A boss.....
jayman33 is offline   Reply With Quote
Would it be overkill MyMustangIsBlk The Bar 8 04-11-2014 04:23 AM
Best Mod and Worst Mod Rcary 2011-2014 V6 Mustang 30 06-04-2012 06:26 AM
What feature do you feel is overkill? SpectorV 2011-2014 Mustang GT 66 07-20-2009 09:43 AM
The true definition of overkill wiarumas The Bar 7 06-05-2007 07:19 AM
Project Overkill OVRKILL Pictures and Videos 5 07-19-2004 08:43 PM
04:45 AM
