5.0 Coyote Fuel Trim Banks not balanced - Mustang Evolution
Old 04-11-2014, 08:38 PM   #1
ArtU's Avatar
Hi folks, I have been doing data watching and logging with Torque for about 2 years now on my past V6.
Just started today on my newer 2013 GT, I got it with about 5K miles on it traded the V6 in.
I know what short term fuel trims do. However I noticed my long term trims are not always balanced. Most times I would watch or spot check it on the smart phone bank 1 was 4 points added more fuel then bank 2. Ie 8.6 vs 4.6 or 10.5 ver 7.1 This was of course mostly at idle at stop lights as I don't look at phone and drive a manual.
With some help tonight it seems at about 2000 rpm the long term fuel trims are even about 7.7 each _+_-1 .1 like 7.7 vs 7.6
Then later at idle 8.6 bank 1 and 4.7 bank 2. This really sounds like a vacuum leak to me on bank 1, or are these Coyotes noted for this spread between banks? Car seems too new for a clogged cat, and since it clears up at sustained higher rpm that is almost classic leak is it not?
However I am guessing that I am worried about something normal with this engine that is new to me.
Art
Old 04-12-2014, 02:23 PM   #2
ArtU's Avatar
So any weekend tuners/wrenchers got an idea? How about any of you that have watched your Long Term Fuel Trims, are they balanced at idle or apart like 4 or so points?
Mine only balance at or above 2000 rpm.
Art
Old 04-12-2014, 08:01 PM   #3
G3ARH3AD's Avatar
Could be a slight mis fire on the 1 bank that is slightly more lean or just 1 plug that is ever so slightly off, had a guy with a 12 gt with 16k already showing slight mis fire counts on mode 6 data, but even at those # i wouldnt wry to much about the number difference at work usually let the trim levels go +-10 before there is something to wry about unless it staying close to the 10s all the time, trims will change due to temps, fuel, baro pressure, etc
G3ARH3AD is offline   Reply With Quote
Balanced motor Liebert91stang 1979-1995 Mustang GT 7 10-23-2013 08:17 PM
lean banks kickerofdoom Pre-2005 V6 Mustang 2 11-22-2012 03:26 AM
Tyra Banks :: 2003 Ford Mustang GT jbanks Member Garages 0 07-01-2011 10:58 AM
This is true. I hate banks and so do 96 yr old women Danger Dude The Bar 12 08-28-2005 01:03 AM
AKURETs? Matched my 275/40/17 Kuhmos up with 2 of these for 250 mounted and balanced Rick0636 Mustang Wheels & Tires 11 08-21-2004 07:08 PM
04:50 AM
