Brake Squeaking - Mustang Evolution
Old 04-14-2014, 09:20 AM   #1
JM7225's Avatar
Brake Squeaking
I've got a 2011 GT with Brembos on it. Lately I've noticed that the brakes squeak at a certain pressure of force on the brake pedal. For instance if I put fairly light pressure on the pedal (during a normal stop at a stop sign or traffic light) there is a constant high pitched metal on metal squeaking. If i have to put a lot of pressure on the brakes, there is no squeaking. There is only 11k miles on the car and it has never been tracked or raced. Any ideas or thoughts would be appreciated!
2015 Mustang GT Premium | MRT Catback
JM7225 is offline   Reply With Quote
Old 04-14-2014, 10:01 AM   #2
nhcowboy's Avatar
Brake Squeaking
Go a perform a break in cycle of the pads. (On a stretch where no other cars or people are around).
3 sets of the following... With like 15 minute cooling between sets
Speed up to 40. Slam the brakes (hard but not enough to engage abs). Quickly repeat... 4-5 times. Might smell burning or see blue smoke. Normal. When finished, let brakes cool. Do not come to complete stop while engaging the brakes (do not let the hot pads sit stationary against the rotors). No parking brake either. Basically find a spot to rest where you can coast to a stop on level ground.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 04-14-2014, 11:13 AM   #3
KARgt13's Avatar
No kiddin? Damn my brakes have been doing the same for the last few thousand miles and it drives me nuts. I thought I already needed to replace the pads but I'll have to try this.
KARgt13 is offline   Reply With Quote
Old 04-14-2014, 11:52 AM   #4
JM7225's Avatar
Speaking of getting new pads...if it is the case I need new pads (which I hope it's not) should I get new rotors as well? Again, not many miles on the car.
Old 04-14-2014, 12:38 PM   #5
11stangGT's Avatar
Region: Arkansas
I think it's a fairly common thing with the factory pads for them to squeak some bc they are a harder compound than the base GT. Once they warm up they shouldn't squeak. I never did the break in cycle and mine eventually went away. I'm at 38k now and need new pads
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 04-14-2014, 12:40 PM   #6
11stangGT's Avatar
Region: Arkansas
The pads are meant to run hotter bc it's somewhat of a "track pad" rears are same as base GT though
Old 04-14-2014, 01:34 PM   #7
JM7225's Avatar
I've noticed it's not as bad when they get warm, but they seem to need to be very warm in order to stay quiet. I can do standard driving around town for 20 minutes and they will squeak the whole time at certain pressure points.
Old 04-14-2014, 02:35 PM   #8
11stangGT's Avatar
Region: Arkansas
Mine were the same.. Gotta really use em to get me warm enough.. I'll prolly do a softer pad this go around. I haven't researched much yet though as to which I will go with
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 01:03 AM
To get rid of squeaking... crazeflier07 Pre-2005 V6 Mustang 0 08-08-2007 08:14 PM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 09:38 AM
Car Squeaking Over Bumps/Hills/Rolling Roads Shahrum Pre-2005 V6 Mustang 12 03-03-2004 08:47 PM
can't stop doors from squeaking stangracer Mustang Audio & Video 11 11-11-2003 11:08 AM
» Members Mustangs
Stacy
BayyGT
Pig
gtcpa
Add your Mustang
07:33 AM
