Camber question - Mustang Evolution
Old 04-15-2014, 09:06 AM   #1
LuisBlackGT's Avatar
Camber question
I have a 2014 mustang gt, I lowered the car with sr performance lowering springs which is 1.5" drop all the way around I also purchased an adj panhard bar and eibach camber bolts. After an alignment my front camber is -2.0 degrees. My question is does this seem right?
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 04-15-2014, 11:20 AM   #2
Anyone?
Old 04-15-2014, 11:42 AM   #3
scott_0's Avatar
yes, it's normal for the negative camber to be more extreme once lowered, you need camber plates to get within spec (-1.5 deg) or (and I don't recommend them) camber bolts. but the negative camber is better for handling, you just need to make sure the toe is correct as toe being off is what wears tires
sent from my S4 using Tapatalk
Old 04-15-2014, 11:43 AM   #4
I understand negative camber comes when lowering, but the alignment shop said its -2.0 with the camber bolts maxed out
Old 04-15-2014, 12:57 PM   #5
scott_0's Avatar
did they install them in the top strut mount bolt hole? it's odd because camber bolts generally offer 1.75 degrees of adjustment. I believe either A. the shop installed the bolts wrong, B. they didn't adjust them properly or, C. they simply didn't try adjusting them
Old 04-15-2014, 02:10 PM   #6
Site Sponsor
Sponsor
AMWill's Avatar
LuisBlackGT,
I think scott_0's last comment is on to something here. It's strange you still have slightly too much negative camber with the cambers bolts and SR springs. We have a bunch of customers running the SR springs on 11+ Mustangs with no camber bolts and their alignment is within spec. I typically only recommend camber bolts for 05-10 S197 Mustangs, since they usually need a little tweak with a 1.5" drop, but never the 11+ S197's.
This is why I think scott_0 might be on the right path. How well do you know the shop that did the install?
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 04-15-2014, 02:28 PM   #7
The bolts are installed in the top hole, the only thing that i think is wierd is that on both sides the flange on the washer is pointing towards the engine bay. I brought it back to the alignment shop today and I told them that the flange needs to be pointed outwards for more positive camber and they then told me " that's not what my machine is telling me"
---------- Post added at 04:28 PM ---------- Previous post was at 04:27 PM ----------
I know the bolts are in correctly I just feel as though the alignment shop isn't using the bolts correctly
Old 04-15-2014, 02:31 PM   #8
Camber question
Some pictures of the bolts Click image for larger version
Name:	ImageUploadedByMustang Evolution1397593842.612408.jpg
ID:	154075Click image for larger version
Name:	ImageUploadedByMustang Evolution1397593869.792639.jpg
Old 04-15-2014, 05:22 PM   #9
Are they suppose too face in or out?
Old 04-15-2014, 05:25 PM   #10
scott_0's Avatar
the tab faces in to decrease the negative camber, but the bolt cam still needs to be adjusted
Old 04-17-2014, 10:42 AM   #11
Correct me if I'm wrong but I thought if the tab is facing in it adjusts for more negative camber and if it is facing out it adjusts for more positive camber?
Old 04-18-2014, 09:35 AM   #12
Figured it out! The tab needs to be facing the wheel to get more positive camber
Old 04-18-2014, 01:14 PM   #13
I lowered 1.5" and needed nothing...my alignment guy set everything within factory specs and I never had a problem...
2011mustanggt is offline   Reply With Quote
Old 04-18-2014, 01:58 PM   #14
scott_0's Avatar
damn man, I'm sorry for the bad info I gave, I swore it was the tab facing in. glad you got it figured out
Camber plate question Staytru06 General Mustang Discussion 0 01-27-2014 03:41 AM
Camber Bolt Question KARgt13 2011-2014 Mustang GT 9 04-30-2013 08:22 PM
Camber Bolt Question. Mustang 4pt0 2005-2010 V6 Mustang 0 04-21-2013 12:59 PM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Camber plates question Venomouz831 Pre-2005 V6 Mustang 17 12-18-2011 03:03 AM
02:42 PM
