Barton Short Throw Shifter Question - Mustang Evolution
Old 04-15-2014, 04:34 PM   #1
Hey! I have a 2012 GT and I'm considering buying a Barton short throw shifter. I currently have the stock shifter with the boss shift knob and boss shift boot. Will the Barton shifter work with the knob and boot or will I need to buy a whole new set up? Thanks for any help in advance! And if you guys have any pics of a similar set up with a short throw shifter, I'd love to see pics!
blackmustang12 is offline   Reply With Quote
Old 04-15-2014, 06:05 PM   #2
scott_0's Avatar
it's the same thread pitch, your setup will transfer right over
sent from my S4 using Tapatalk
Old 04-15-2014, 10:07 PM   #3
20bmr14's Avatar
Yeah I have the same set up and it is flawless. Did you get the bracket??? It is worth it.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 04-16-2014, 07:47 AM   #4
Sterlingbeast5.0's Avatar
you will not regret it. Love the shifter. +1 on getting the bracket though
Old 04-16-2014, 08:44 AM   #5
Thanks for the help so far! When I get the shifter, I will also buy the bracket, it sounds like a must! Haha
Old 04-16-2014, 03:41 PM   #6
20bmr14's Avatar
Yeah you will really enjoy it. Hope you have a lift to do the work
Sent from my SPH-L710 using Mustang Evolution mobile app
Old 04-16-2014, 03:59 PM   #7
Rapinator126's Avatar
You don't need a lift. Jack stands work perfect.
Also get wireline trans bushing
stainless clutch line
Remove the assist spring on the clutch peddle
Old 04-17-2014, 05:14 AM   #8
gtstyles2's Avatar
I recently got the sticky pedal issue for the 1st time this past weekend. I also just added the Whiteline bushing insert, and a McCloud SS clutchline. Does removing the helper spring make the clutch harder to push? I just got so used to how soft it is, just wondering how taking that spring off helps?
Old 04-17-2014, 06:19 AM   #9
The spring is what makes the the peddle, stick to the floor on high rpm pulls. Removing this eliminates this. A little more stiff, but not much
Old 04-17-2014, 05:32 PM   #10
2013 Green GT's Avatar
After a few runs this past summer at the track... I had the clutch stick and I freckled out... I could not get if to return for a few seconds. I took out the spring and is a DD, not a big difference, but noticeable in peddle play. I have not taken to the track, but hope it helps (not to the track until June). I have heard that the clutch line is also the problem. Good luck. Ohh, I do have the Barton shifter and bracket. Very crisp and deliberate shifts.
2013 Green GT is offline   Reply With Quote
Old 04-19-2014, 08:10 AM   #11
nando09's Avatar
Get the BARTON two post shifter bracket. Worth it. Reduces missed shifts and kick back from the shifter moving around. The factory one is weak!
nando09 is offline   Reply With Quote
Old 04-20-2014, 01:57 PM   #12
MGW ftw
2012 Kona Blue Metallic GT,6spd,3.73's,MGW Shifter,H&R lowering springs,BMR Panhard Bar,BMR Rear LCA,BMR relocaton brackets,Roush Axlebacks
BigBlue5.0 is offline   Reply With Quote
Old 04-20-2014, 02:02 PM   #13
The Barton has a shorter throw compared to the MGW. I prefer the Barton personaly
Old 04-20-2014, 02:11 PM   #14
To each his own
Old 04-22-2014, 11:32 AM   #15
I was ready to kill myself after I put the Barton 2 post and shifter into my car. It felt like I was driving a Cement mixer. That's all I could hear was drivetrain noise and vibration through the shifter.
Than I upgraded from stock exhaust to GT500 AB and Catless H-pipe. Now I don't hear anything but the sweet sounds of my Coyote singing. It really is a good improvement to the car over the stock junk shifter.
Justin81 is offline   Reply With Quote
Old 04-22-2014, 12:47 PM   #16
20bmr14's Avatar
How is that h pipe?
Old 02-19-2015, 02:56 PM   #17
Dans5oh's Avatar
Is it really that loud in the cabin?
Dans5oh is offline   Reply With Quote
Old 02-19-2015, 05:07 PM   #18
oxford5pointoh's Avatar
^ I have the FRPP short shifter (same as Barton) and I could barely hear it. Only when you rest your hand on it does it make noise. And even then, it's the noise of the car. I actually like it. Now that I have my exhaust I REALLY can't hear it. I can never understand when people say it's so loud. I dunno maybe I'm def. lol to many concerts.
Old 02-19-2015, 05:27 PM   #19
Dans5oh's Avatar
Hi Ox, thanks for your reply. I don't mind some noise but some people's comments made me think it was extremely loud. I have Roush axle backs so I probably wouldn't hear it anyway, except maybe feel the vibration lol. ..thanks again.
2014 GT Premium, Sterling Grey Metallic, 6sp, Brembo's, 3.73's, Comfort, Security, Spoiler Pkgs. Barton short shifter w/two post bracket, Redline hood struts, AM shifter ball, BMR lca, Roush axle backs.
Old 02-19-2015, 06:21 PM   #20
20bmr14's Avatar
What little noise you will hear is not enough to dislike it. If its that loud check your shifter boot. I thought the Whiteline bushing made more noise than the shifter but after a week or two you will think nothing of it.
Old 02-19-2015, 07:36 PM   #21
Dans5oh's Avatar
Thanks David, I'm leaning to the Barton because I like the short throw.
Old 02-19-2015, 10:17 PM   #22
Devil Strider's Avatar
Just installed my Barton shifter today. I don't hear anything.
Sent from my SM-N910P using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
Old 02-20-2015, 08:19 AM   #23
Dans5oh's Avatar
Which bracket did you install with it?
Old 02-20-2015, 06:55 PM   #24
20bmr14's Avatar
yeah man pull the trigger. You will not be sorry at all.
Old 02-20-2015, 07:23 PM   #25
Two post.
Old 02-22-2015, 11:21 PM   #26
Dans5oh's Avatar
yap, im going to pull the trigger..
Old 02-22-2015, 11:22 PM   #27
Dans5oh's Avatar
Two post.
thanks,,i will do the same,
Old 02-23-2015, 01:29 AM   #28
I have a Barton and a race spec blowfish and mine is quiet also
Old 02-23-2015, 06:45 PM   #29
Dans5oh's Avatar
I pulled the trigger today, I ordered the Barton and 2 post bracket.
Old 02-23-2015, 07:03 PM   #30
20bmr14's Avatar
Tell us what you think after you install and test drive it.
Old 02-23-2015, 08:17 PM   #31
Dans5oh's Avatar
I'm looking forward to it. I was debating on the MGW or the Barton. Even tho the MGW is NASA quality, I still wanted the short throw. Seems all the posters that have the Barton, swear by it. By the way, you owe me because you talked me into "Pulling the trigger" haha.
Old 02-24-2015, 07:12 PM   #32
20bmr14's Avatar
Do you have the whiteline trans bushing? If not get it. Its cheap and easy and helps stiffen things up.
Old 02-25-2015, 11:47 AM   #33
Dans5oh's Avatar
No I don't have it yet, I read some things about it and it sounds good, I will order that too. Does it add noise or vibration? I read where some people were talking about cutting a 2 inch hole in the middle of the bushing? Maybe I read that wrong.
Old 02-25-2015, 04:00 PM   #34
20bmr14's Avatar
Hey after removing the spring do you have to lift the pedal up with your foot the next day?
Old 02-25-2015, 04:04 PM   #35
20bmr14's Avatar
Yeah you can remove some material from the bushing to make it quieter but again after about 2-3 weeks things settle in and it wont be an issue. I am not a fan of added noises and it subsided or I got used to it after awhile. I did not cut a hole, just installed it as it came.
mgw ~vs~ barton short throw shifter nculp9 2011-2014 Mustang GT 16 06-29-2013 09:09 AM
Barton short throw shifter 2013mustang5.0 2011-2014 Mustang GT 78 05-27-2013 02:25 PM
For Sale: SR Short Throw Shifter W/ Barton Bracket SilverBullet12 Mustang Parts for Sale and Wanted 4 02-09-2013 01:16 PM
Barton Short Throw Shifter PBrown92 2011-2014 V6 Mustang 2 12-11-2012 03:10 PM
MGW vs Barton Short Throw Shifter Brock23 2011-2014 Mustang GT 26 10-26-2012 04:21 PM
07:09 PM
