Need help removing a emblem - Mustang Evolution
Old 04-17-2014, 10:01 AM   #1
Has anybody ever removed the emblem from a 13-14 decklid panel? I'm trying to put one on my 2012, but I wanted to swap out the rear emblems first. I just don't want to break the decklid!
Old 04-17-2014, 11:46 AM   #2
Deerslayer's Avatar
You need to remove the entire deck lid panel to have access to the back of the faux gas cap emblem. Are you removing the entire gas cap or just the center?
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 04-17-2014, 02:01 PM   #3
I have the whole panel off and I'm only looking to remove the emblem/center part. Click image for larger version
Name:	ImageUploadedByMustang Evolution1397764896.251913.jpg
Old 04-17-2014, 03:51 PM   #4
Deerslayer's Avatar
You need to grind down the melted tabs and then there are a few holes that let you can get a small nut driver head through. Once you get it through, you hold the outside edges of the faux cap and push like hell.. The chrome emblem is all part of the cap. The black piece will push away. If you are going to put an Emblem Pro custom center piece, or anything you will have to grind down the emblem before you stick the new design on.
Old 04-17-2014, 07:08 PM   #5
That's exactly what I am wanting to do! Thanks for the tips! I need to knock it out.
Old 04-17-2014, 08:51 PM   #6
Deerslayer's Avatar
one more tip; when you go to stick the new piece, heat it up with a blow drier so you can get it to slightly dome shaped like the one you take off was
Old 04-18-2014, 12:09 PM   #7
I appreciate that! So you're saying that the little silver pieces sticking in from behind the emblem are what I need to get behind and push on? I was messing with it some last night but I tell you what that emblem wants to stay on there
Old 04-18-2014, 01:13 PM   #8
Deerslayer's Avatar
Here is one I did.
Push below the four areas on the black piece to remove it
Once you push the black piece off, you will need to cut out or grind down the chrome part of the emblem. I cut out the GT and glued it back on the black panel I pulled out.
Finished with the one from emblem pros in place
Old 04-18-2014, 05:26 PM   #9
So I found out my emblem is nothing like yours. My emblem has the running horse and the tribar logo and the horse is actually part of the chrome surround and can't be separated from the actual surround without cutting it out and ruining the chrome part. Soo essentially, I'm going to have to try to scavenge one or something from another car
Old 04-18-2014, 07:30 PM   #10
Deerslayer's Avatar
LOL....the GT IS THE SAME......I cut the chrome GT out with a dremel tool. You can grind down the tribar pony or cut it out like I cut out the GT. You just push the black part away so you can see what to cut or grind.
Removing ford emblem comporange Pre-2005 V6 Mustang 3 01-16-2014 10:47 PM
Need help removing stock shift knob... Gtzzoom 2011-2014 V6 Mustang 24 05-05-2012 09:05 PM
need help n info on removing t5 trans sick5point0 1979-1995 Mustang GT 9 03-16-2012 09:44 PM
need help removing my oil pan! jkaminski24 1996-2004 Mustang GT 7 08-23-2010 04:54 PM
removing factory radio from 84 lx need help Doken Mustang Audio & Video 2 04-26-2008 05:32 AM
03:49 PM
