dyno results? - Mustang Evolution
Old 04-18-2014, 06:02 PM   #1
dyno results?
I am new to this and wanted to know if this is normal I have a 2011 gt with l/t headers, h/f cat xpype, boss 302 I/m, 90mm throttly body, 373 gears, flownaster cat back ex, and steeda cai. My dyno results were 430 rwhp and 400rwt is that normal for j7st those bolt ons? Dyno was in 5th
bristolpete is offline   Reply With Quote
Old 04-18-2014, 07:33 PM   #2
Deerslayer's Avatar
You probably could get a little more out of those mods with a different tune, but those numbers arent bad with those mods
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 04-19-2014, 09:25 AM   #3
DallasStang77's Avatar
I thought 4th gear was the gear that nets the most accurate reading?
Old 04-19-2014, 09:43 AM   #4
dyno results?
In an automatic it is. Manual is 5th I believe. You want whichever gear is closest to a 1.00:1
Old 04-19-2014, 10:52 AM   #5
It's manual.
Old 04-19-2014, 03:59 PM   #6
Getn off's Avatar
5th for m6.
Decent numbers. Dyno numbers are pretty much just a reference number anyway. Too many variables between them to put much trust in them.
The curve is actually more important than the peak imo.
Troy
Getn off is offline   Reply With Quote
Dyno Results: X pipe over Y pipe Rygen Pre-2005 V6 Mustang 8 03-13-2006 05:54 PM
SCT Tune / Dyno #2 Results 2005RedGT 1996-2004 Mustang GT 9 02-21-2005 09:36 AM
99^ split port camming and tune dyno results... (NO PORTING!!!) RGR Pre-2005 V6 Mustang 6 04-09-2004 07:07 AM
Air Silencer Dyno results ? drichard Pre-2005 V6 Mustang 4 10-15-2003 05:10 PM
04:59 AM
