Spare tire - Mustang Evolution
Old 04-25-2014, 05:20 PM   #1
rsb
rsb's Avatar
Spare tire
Hi everyone, this is my first post on the board, but I've been lurking for a while now.
Anyways, I just took delivery of my 2014 GT yesterday, and this morning I noticed that there was no spare tire. Is this typical?
I have the brembo package that includes 19" wheels.
rsb is offline   Reply With Quote
Old 04-25-2014, 07:13 PM   #2
LuisBlackGT's Avatar
They did not include a spare tire because the spare tire will not fit over the brembos I believe
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 04-25-2014, 07:28 PM   #3
Clink's Avatar
Correct, you have a "tire mobility kit" or some thing like that. I have same thing.
Old 04-26-2014, 07:07 AM   #4
jeanmorissette's Avatar
Yes same think here up in Canada, a "tire mobility kit"! If anyone find another option let us know. I am assuming we could get a full size spare but I never took the measurements so I don't know if it would fit all the way in.
jeanmorissette is offline   Reply With Quote
Old 04-26-2014, 02:31 PM   #5
Rynarok's Avatar
We do not have spares. We do have an air pump complete with fix-a-flat goo. More importantly, the dealer should have mentioned to you about ford roadside. Keep these numbers in your phone or glovebox, because this is how you get unstuck:
Ford Roadside: 1-866-330-0760
Producer code: 20809 (yours might be different, check the car paperwork)
Member Number: *(check your car paperwork, it should be listed. mine is 5 numbers long)
"Plan U"
Call up this number and give them this information, and they'll send a wrecker out to fetch you. There might be as long as an hour wait depending on where you are. There shouldn't be any charges for you to cover.
----edit----
A brembo rim w/ tire will not fit in the spare wheel well. I've tried.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 04-26-2014, 10:57 PM   #6
Bear376's Avatar
Some cars do have spares, but it depends on the tires that come with the car, and the package. The spare has to match the diameter of the stock tires, or it will damage the differential. With the reliability of tires today, it can be a benefit not to have a spare. It adds storage space and reduces weight.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 04-27-2014, 12:03 AM   #7
I agree it saves weight, but its like the only think holding the trunk mat up if you have an actual spare
JayblesStang is offline   Reply With Quote
Old 04-27-2014, 04:52 AM   #8
Grabber Blue5.0's Avatar
My car came with a spare and it's the first thing I removed. Significant weight savings.
Old 04-29-2014, 08:55 AM   #9
Sakol's Avatar
I originally had stock 17s and the trunk had a spare. When I changed my rims to 20s because of Brembos, I tried putting the 20" rim in the trunk. It fits but it does stick above the base of the trunk floor and there'd be a bulge I think.Click image for larger version
Name:	ImageUploadedByMustang Evolution1398782881.500991.jpg
ID:	155422Click image for larger version
Name:	ImageUploadedByMustang Evolution1398782990.863287.jpg
ID:	155424Click image for larger version
Name:	ImageUploadedByMustang Evolution1398783048.387106.jpg
ID:	155425Click image for larger version
Name:	ImageUploadedByMustang Evolution1398783111.040535.jpg
ID:	155426Click image for larger version
Name:	ImageUploadedByMustang Evolution1398783196.326219.jpg
ID:	155427Click image for larger version
Name:	ImageUploadedByMustang Evolution1398783228.973057.jpg
ID:	155428Click image for larger version
Name:	ImageUploadedByMustang Evolution1398783270.940824.jpg
ID:	155431Click image for larger version
Name:	ImageUploadedByMustang Evolution1398783326.141714.jpg
Sakol is offline   Reply With Quote
Old 04-29-2014, 10:52 AM   #10
Rynarok's Avatar
"Plan U"
----edit----
Lemme clarify - Brembo and Trackpack cars do not have spares that I am aware of.
Still, I'd keep that ford roadside information handy just in case.
AXLEBACKS THREADS =
Old 04-29-2014, 11:08 AM   #11
bucko's Avatar
My 2011 is not a Brembo or Trackpack Mustang, and it also did not come with a spare, but rather the air pump complete with fix-a-flat goo.
I had a flat on the highway one morning, and used the supplied goo and air pump to limp me over to the nearest Ford shop (closest repair on my way to work). Took advantage of the road side assistance, which in this case, got me a free ride to work, and a pickup back to the dealer when it was repaired.
This dealer called and said the Mustang was ready; they were reluctant to patch the tire, as they claimed the hole was from a large metalic object. I gladly paid for a new tire, but refused to pay for a charge they added, stating "hazard charge for removing tire with tire inflation chemical....". I told them I used the "Ford supplied" goo that was in the trunk, and followed the directions in the owners manual.
They promptly removed that charge.
Old 04-29-2014, 11:15 AM   #12
Sakol's Avatar
To clarify, I didn't originally have Brembos. That was a later mod. My car is 2011 v6 coupe with premium package. When the big brakes were installed, that's when the adventure began.
Old 04-29-2014, 11:20 AM   #13
Sakol's Avatar
The rim I dropped in the trunk was 20x8.5" with 255/35/20. It may not apply to all, as tire brands come in all shapes and sizes. Mine just happen to fit.
Help me put a spare tire in a '72 Fastback. jworkm72 Classic Mustangs 5 04-03-2011 04:30 PM
Spare Size Tire Question Crispy Mustang Wheels & Tires 1 02-05-2004 05:59 PM
08:45 AM
