Can't get her to hook - Mustang Evolution
Old 04-29-2014, 04:24 PM   #1
Blackpearl's Avatar
New member, not new to Mustangs. I have a new 14' GT I can't get to hook at all from a dig. Nothing new there I know. Engine mods are, Airaid CAI, 3" O/R X pipe, Flowmaster axle backs and Bama 93 performance tune. Suspension mods are, Roush springs, Boss 302 LCAs, Whiteline brackets and BMR adjustable panhard. Running a Nitto NT555 285 rear tire around 35 psi. 3.31 gears.
I am about to die to throw a Roush huffer on it. As bad as it spins in 1st and 2nd now, I can only imagine how bad it will be with another 175 hp.
So what do you do for better traction?
Blackpearl is offline   Reply With Quote
Old 04-29-2014, 04:57 PM   #2
1lowGT's Avatar
Get some drag radials. Upper and lower control arms, shock struts, and subframe connectors. The control arms really help a lot. Along with a stickier tire. look at the 555r or if its not a daily then some MTs
Old 04-29-2014, 05:30 PM   #3
Blackpearl's Avatar
I really noticed a big improvement with the Boss control arms and relocating brackets. And I realize with somewhere around 400 hp at the wheels, it is not easy to tame tire spin on a street tire. Just wondering what 600+ hp cars do different. Or is it just that much worse?
Old 04-29-2014, 07:58 PM   #4
LuisBlackGT's Avatar
Get some wider and better rubber out back
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 04-29-2014, 08:10 PM   #5
Rapinator126's Avatar
Ditch the boss crap
BMR LCA's.
BMR relocation brackets
JPC adjustable UCA
Also ditch the crappy 555's
NT05r's
Or ET street 2's
best bet is a full slick though. You will break **** more from a dig with drag radials
Takes some playing with the suspension and tires to get it but I can hook from a dig with a 200 and 4.10's
Rapinator126 is online now   Reply With Quote
Old 04-29-2014, 08:13 PM   #6
GE3G's Avatar
Can someone explain to me why a drag radial is more capable of breaking parts then a full slick.. I always thought slicks hook harder
GE3G is offline   Reply With Quote
Old 04-29-2014, 08:15 PM   #7
Because radial tires will hook then slip then hook again giving it more of a chance to break
---------- Post added at 10:15 PM ---------- Previous post was at 10:15 PM ----------
But a slick will just hook and go
Old 04-29-2014, 08:16 PM   #8
BC a slick is going to stick and stay planted.
While a drag radial will grip and slip and grip then slip.
Just weld your axle tubes and your good to go launching on a slick
Old 04-29-2014, 08:18 PM   #9
GE3G's Avatar
Thanks boys
Old 04-29-2014, 09:01 PM   #10
Blackpearl's Avatar
Why do you say the Boss LCAs are crap?
Old 04-29-2014, 09:03 PM   #11
BC they are. They were not built for launching. Also be careful launching on white line relocation brackets. They have been known to fail more than once under hard launches. You will have a bad night/day if one decides to let go.
Old 04-29-2014, 09:06 PM   #12
Best bet is go with BMR if your going to be launching hard. Also weld the relocation brackets and axle tubes
Old 04-29-2014, 09:10 PM   #13
Blackpearl's Avatar
Hmmm. Well, the Boss LCAs seemed like a nice upgrade over stock, and I did seem to gain some traction with them, although they may not be the best choice. I was actually quite impressed with the Whiteline bracket construction. And I own a machine shop. So I kinda know quality when it comes to metal parts. As far as tires go, this is just a street car. And I also do some autoxing with it. This is where I will need a second set of rear wheels/tires.
Old 04-30-2014, 07:17 AM   #14
Send a message via AIM to Borii
The problem you have are tires. Not specifically the 555, but rather the 14 GT in stock form has too much more for most street tires. My 06 GT was pulling 1.81 60' times on 275 Nitto 555 street tires up until I passed 350WHP. Then I added 305 555R2 in the back for traction and I was BOGGING them
If you stick with a street tire, you will need a 305+ to get a little traction most likely. Lowering the PSI to 32-33 will make a subtle but noticeable difference.
Rear suspension will help the current tire a ton.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 04-30-2014, 07:25 AM   #15
Region: West Virgina
To expand on what others have said, the sidewall of a slick will wrinkle and give causing less of a shock on the rear. A drag radial with a stiff sidewall will not give and will shock the drive line, especially a manual transmission car, much harder.
2014 Sterling gray GT 6M
Paxton Novi 2200, DW1000 injectors, JMS BAP, ATI damper
Lethal ORP, MGW shifter, BMR upper and lowers, Spicer 1 piece DS, Ram Single disk clutch with aluminum flywheel, Power leather seat conversion. Staggered wheels.
605 RWHP on a safe tune
scott9050 is offline   Reply With Quote
Old 04-30-2014, 07:38 AM   #16
The width really does not matter on the tire. The proper suspension setup and tire in general does.
Old 04-30-2014, 07:46 AM   #17
Tire width still plays an important factor if he is going to keep a street tire. Well, width for the wheel, if he has the factory 9" wide, then he won't gain any more surface area by going wider than his 285. More surface area, more traction. But going wider than his 285 will not give HIM more traction.
Sold - 2001 Audi S4
Old 04-30-2014, 08:11 AM   #18
Blackpearl's Avatar
I have a 10" rear wheel, so a 305 would fit the wheel great. They are +40mm offset though, so it will be right on the limit of sticking out past the fender. Where are you guys talking about welding the axle tubes?
Old 04-30-2014, 08:30 AM   #19
You can have a 275 and run 7's.
Its all tire choice and suspension. I will throw 285's on my 10" rears and drag a lot of ***.
Welding the actual axle tube where it connects to the pumpkin.
On slicks you can twist a axle tube
Old 04-30-2014, 08:35 AM   #20
Bottom line is if you want a street tire that hooks ( non drag radial) mickey street comps.
I usually rub around on drag radials. But when it comes to street tires I have tried a lot of them. Nothing compares to the street comps. BUT suspension has a bigger key then actual tires
Old 04-30-2014, 08:36 AM   #21
Like bori said though l, street tire is hard to hook with. The 285 street comps are plenty.
My aunt is breeding her Chihuahua and all of her dogs are named after mustang parts. Names??? dooley28 General Mustang Discussion 10 11-01-2016 01:05 AM
Where can i hook this up? Filth and Fury 2011-2014 Mustang GT 2 09-25-2013 07:18 AM
Just gave her her first bath out of storage GE3G 2011-2014 Mustang GT 22 03-23-2012 08:25 AM
The girlfriend got her GT!!! I'm so happy for her!! 93CobraGuy General Mustang Discussion 51 02-01-2011 02:18 PM
Diference between her mouth and her vag... MarkuzLS1 The Bar 27 10-17-2008 07:06 PM
06:00 PM
