Fog light went out - Mustang Evolution
Old 05-01-2014, 10:19 PM   #1
Subtle stang14's Avatar
Fog light went out
As you already can see i have a problem with my fog lights coming on, when i try to turn on the fog lights it says on my dashboard the brights are on. I have also checked my fuse box but the fuse seems to be in good shape. Before i go to the dealership, any suggestions?
Subtle stang14 is offline   Reply With Quote
Old 05-02-2014, 05:07 AM   #2
Doe_Rae_mi's Avatar
If your brights are on the foglights will be turned off. Just something ford does
Old 05-02-2014, 08:37 AM   #3
I installed a workaround to power the fogs w. brights. Ford switches power on these cars to turn off the fogs if the brights are on. I installed a small switch under the dash and a separate power source off a 30 amp hot point in the underhood fuse panel. Now I can run full ******* with HID fogs and factory HID heads on bright, if I want
If you have an issue with the IPC thinking brights are on all the time, when they are not on, that's likely a communication problem between the SJB in the passenger footwell and the IPC in front of your face. Disconnect the battery for 30 minutes and see if anything changes. Hold the brake pedal down for a bit after disconnecting the battery to deal with any residual energy.
parking light / fog light mod 1994-2000 FullyAutomatic 1996-2004 Mustang GT 3 04-09-2014 10:29 AM
Can i have both grill fog lights and lower fog lights working at the same time? servs 2011-2014 V6 Mustang 3 03-31-2014 05:35 AM
Driver side Fog Light keeps going Out! jjsg09 1996-2004 Mustang GT 5 03-07-2011 11:44 AM
Swap my Cobra fog lights for your GT fog lights TheDad Mustang Parts for Sale and Wanted 1 01-19-2006 01:01 PM
OK the Calendar winners email went out Danger Dude The Bar 7 11-27-2003 05:04 PM
05:37 PM
