Adjustable suspension parts - Mustang Evolution
Old 05-03-2014, 01:35 AM   #1
I'm looking at getting some suspension mods and was wondering if springing for some of the adjustable versions are worth it.What are the real pros to adjustable vs not as far as rear LCA's and panhard bars go.What will I really gain because both those parts the adjustable ones are considerably more expensive and I'm not sure if it's worth it for me.My car is my DD and I don't plan to hit the track but once in a blue moon.But I do need to maintain everyday drive ability so any info/opinions you guys got would be highly appreciated as I'm looking to make these purchases quickly.And whatever brands you guys recommend/good experience I would love to hear.
2012 Kona Blue Metallic GT,6spd,3.73's,MGW Shifter,H&R lowering springs,BMR Panhard Bar,BMR Rear LCA,BMR relocaton brackets,Roush Axlebacks
BigBlue5.0 is offline   Reply With Quote
Old 05-03-2014, 02:09 AM   #2
No need for adjustable LCAs, you will want an adjustable UCA as well as an adjustable Panhard Bar... Hell if you want to do it right then ditch the Panhard Bar and go with a Watts Link, much better.
Old 05-03-2014, 08:02 PM   #3
11socal50's Avatar
I love the adjustability of my koni yellows
Sent from my EVO using Tapatalk
11socal50 is offline   Reply With Quote
Old 05-04-2014, 04:40 AM   #4
But what benefit do the adjustable LCA's bring is my question.Will I regret not getting them shortly after install a set of non adjustable?
Old 05-04-2014, 05:01 AM   #5
Grabber Blue5.0's Avatar
Do NOT get adjustable lower control arms. Not necessary and if not installed correctly you'll really screw things up.
Old 05-04-2014, 09:03 AM   #6
I love people who suggest putting a Watts link on and leaving the crap factory setup out front, or not even suggesting the crap factory shocks would be a better place to start. You'd be best advised to buy something that can grow a bit but, from what you say, you need an adjustable upper, for pinion angle setting and the adj. panhard to centre the axle, because you may well wish to lower the car and it's not centred factory.
Old 05-04-2014, 11:05 AM   #7
I'm already lowered btw
Old 05-04-2014, 11:09 AM   #8
definitely need to do what I and others have suggested here, then.
Old 05-04-2014, 01:26 PM   #9
Rapinator126's Avatar
Perfect setup is. Lakewood 70/30 struts. 50/50 shocks. k springs or BMR. BMR LCA's and relo brackets. BMR pan hard bar. JPC adj UCA
Old 05-09-2014, 10:04 AM   #10
What would you recommend for a DD and not so great roads, the K springs or BMR's? Also do you have any opinions on Steeda's Ultra Lites?
Old 05-09-2014, 10:07 AM   #11
The K springs are going to drop you 1.5 all the way around. Honestly it lower than the 1.5 they claim. So I would go with the BMR's.
I have no experience with the steeda's bud.
Old 05-09-2014, 10:09 AM   #12
I love the K springs. They launch perfect. But they are lower than a 1.5 I promise.
Old 05-09-2014, 10:13 AM   #13
Ok, so the Lakewood's seem geared more toward drag use. You still recommend these for street applications?
Old 05-09-2014, 10:19 AM   #14
Yes and no they will be fine, Just a bumpy ride. Now if you want handling since you have bad roads I would go with the koni's
Old 05-10-2014, 11:01 AM   #15
I was planning on koni's. Do you recommend non adj or adjustable?
Old 05-10-2014, 11:03 AM   #16
Adjustable if you have the extra coin for it.
Old 05-10-2014, 11:18 AM   #17
2 Stangz's Avatar
Region: Nevada
When are adjustable LCA's and/or LCA relocation brackets necessary? In detail...
I plan on doing [the following] and main purpose is spirited DD:
springs
adj strut mounts
adj UCA
adj panhard rod
non-adj shocks/struts
non-adj LCA's
Should I look into adj LCA's and/or relo brackets?
Old 05-10-2014, 11:28 AM   #18
You do not want adj LCA's. If they are not adjusted right you will have problems.
Now the relocation brackets are meant for lowered cars. But are fine on non lowered also. Just use the top hole if your not lowered. Middle up to a 1.5. And bottom over a 1.5
You will need relocation brackets
But go with non agj LCA's
Old 05-10-2014, 11:32 AM   #19
2 Stangz's Avatar
Region: Nevada
Excellent info as always, thanks.
Say I had totally skipped the relo brackets with the previous setup I just mentioned, what kind of effects would that have on my car? Oh and I see relo brackets of quality are weld-in only, this is where I hesitate to get them bc I don't want to weld on my 20k mile new-ish pony.
Old 05-10-2014, 11:44 AM   #20
Just use the BMR Bolton ones. They will be fine. You will not need to weld them till you are pushing well over 700 and launching on the bumper.
You will notice a slight traction issue without them.
Old 05-10-2014, 11:51 AM   #21
2 Stangz's Avatar
Region: Nevada
Gotcha, will do.
Old 05-10-2014, 12:14 PM   #22
Thanks for all the info dude. Now I gotta debate between K's and BMR's. Ha.
Old 05-10-2014, 07:04 PM   #23
first.stang14's Avatar
I already have BMR LCA's. Do i still need an adjustable UCA's if i don't plan on lowing the car or can i just order a regular BMR UCA
first.stang14 is offline   Reply With Quote
Old 05-10-2014, 07:17 PM   #24
Redonblackpony's Avatar
If you don't plan on tracking your car go with the Koni Orange. They are a great shock over the stock ones. There is really no need to go to the yellows, as that is more of a track set up. It'll save you some coin that you can put towards something else.
Redonblackpony is offline   Reply With Quote
Adjustable Lower Control Arms matthews.stang Pre-2005 V6 Mustang 6 07-10-2007 05:17 PM
adjustable springs mitch Pre-2005 V6 Mustang 0 06-09-2007 03:06 PM
holley adjustable fuel pressure regulator trickflow5 1979-1995 Mustang GT 6 01-13-2007 01:51 PM
65-73 NOS Mustang Adjustable Rear Anti-Sway Roll Bar MyStylesTheBomb Mustang Parts for Sale and Wanted 0 08-01-2006 01:57 PM
Adjustable FPR's Zim 1979-1995 Mustang GT 6 05-06-2006 05:48 PM
02:44 AM
