2014 mustang switching between fuel octanes? - Mustang Evolution
Old 05-03-2014, 04:56 PM   #1
What is the correct procedure to switch between regular and prenium fuel on the 5.0l? Can you switch as you wish or you got to let the tank empty and then make the switch?
Sent from my SGH-I747M using Mustang Evolution mobile app
johnny_h55 is offline   Reply With Quote
Old 05-03-2014, 05:00 PM   #2
GrabberMeBlue's Avatar
If the car only requires 87 and you are not tuned for higher, switch and mix however you please. It really doesn't matter what percentage of anything you have in your tank. You just don't want to put less than the minimum octane required in your tank.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 05-03-2014, 05:02 PM   #3
Ok i didn't know since it changes the horsepower rating, i gues the ecu adjust the timing accordingly
Old 05-03-2014, 05:04 PM   #4
The Coyote can naturally adjust for the change in octane, it bumps and retards the timing as necessary. So the 420 claimed horsepower is on premium fuel (93) octane, so you lose a tiny bit of power going 87, but its perfectly fine... And since it can tell what the overall octane level of the tank is you can switch as needed.
Old 05-17-2014, 08:03 AM   #5
Low_50's Avatar
So it's not absolutely necessary to run the tank empty of 87 before using 93 octane?
Low_50 is offline   Reply With Quote
Old 05-17-2014, 08:20 AM   #6
fivepointwut's Avatar
Region: New Mexico
No. Not at all..
Waste of time and effort...
fivepointwut is offline   Reply With Quote
Old 05-17-2014, 08:22 AM   #7
Region: New Mexico
Here in my town the lowest octane at the pumps is 86 -____-
So since the owners manual says minimum is 87, I usually throw the midrange 88 into it just to keep her happy...
Another ****ty thing is that we only go to 91... not 93
2014 mustang
switching fuel from 89 to 93 Clean98 Gt 1996-2004 Mustang GT 8 04-05-2014 10:47 PM
When Switching between different brand tunes s1975OH 2011-2014 Mustang GT 7 10-07-2013 08:07 PM
switching top and frames at the same time flysure1 1979-1995 Mustang GT 1 01-14-2008 12:04 PM
switching to 5 speed stovalini69 1996-2004 Mustang GT 7 11-30-2006 12:19 AM
Switching to 4.10.....questions Ghostbuster Pre-2005 V6 Mustang 6 08-19-2004 01:00 AM
12:38 PM
