I just don't like the fact that the halo connections is on the bottom and it doesn't light up completely. They should have connected the halo on the top.
There is no way you can flip the lights so the break is at the top and behind the grill more making it less visible? I have mine as well as raxiom smoked halo headlights and plan to install them next week. Im excited!
They look sick, as mentioned before they will certainly help you stand out from the crowd. Thank you for sharing this. What else do you have planned for this beauty?
I planned on flipping mine too when I installed them but there's only one way they go on. I'm still really happy with them. I just wish the halo was on all the time. Has anyone wired them into the led bar "signature" lights on their 2013-14 instead of the parking lights?
Okay so I finally got the lights all installed! I love the new look. Don't have any nighttime photos just yet but will post those once I get some as well. As for now here is one with no lights
And then one with the just the halos running
As you can see I was able to flip the foglights so the break is up inside the grill no problem!
Haven't done it but see no reason you wouldn't be able to. Just splice the halo wires into whatever daytime running wires are used for the led bars. Same idea with what I did on the fog lights. Wires weren't quite long enough to get to the parking lights so we added more wire then spliced into the headlight halo wires which were already wired to the parking lights.
Hey everyone I just installed my halo fog lights. I had them done by a dealer as I could not find time to do them myself. Turns out that was more of a hassle hahah. Quick question can anyone explain what the final result of the halo's are. When I turn on the parking lights or the main lights the halo's light up. When I turn on the automatic lights it all turns off. Including the daytime running lights. Is that normal with this setup? Does anyone else have this issue?
Do you have a 13-14? the 10-12 don't have daytime running lights so I don't know about them in particular. But as far as the normal setup for the halos is that they are wired into the parking lights so that when you turn on the parking lights they are on in whatever setting as long as the parking lights would be engaged. That includes every light setting normally (on my car at least). If you wanted them to work with daytime running lights you would just have to wire the halos to those wires instead of the parking wires. The automatic lights would leave the halos turned off until the lights kick on when it becomes dark enough. They would turn on with the rest of the headlights based on when the sensor sees fit.
I have the 2014. I thought when I used to turn on the automatic lights the daytime led lights would come on. I wanted those and the halos to come on together and they only do that when the parking lights are on now. And they were pre assembled fog lights so silicone should already be on I hope.
Gotcha. So for you to get them to run with the daytime LEDs you would have to mess with the wires a little bit to figure out which ones work the daytime running LEDs. unfortunately I have a 12 and no experience with the 13-14 to help in that matter. Apologies, but maybe somebody else could chime in on which wires work the daytime LEDs.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
