Lowering my GT - Mustang Evolution
Old 05-22-2014, 07:31 PM   #1
JM7225's Avatar
Lowering my GT
I apologize if this has been covered before or if the information is contained in multiple threads, but I just wanted to make sure before I bought the parts. Do I need to have adjustable lower control arms in order to lower the car? Are there any shops I should avoid when having this kind of work done? How important is an adjustable panhard bar? I'm kind of new to the prospect of lowering the car. It sure needs it though...
2015 Mustang GT Premium | MRT Catback
JM7225 is offline   Reply With Quote
Old 05-22-2014, 08:28 PM   #2
Clink's Avatar
Lower control arms don't need to be adjustable, just the upper one.
If you scroll down farther you will probably see 10-15 threads about suspension.
Old 05-22-2014, 09:52 PM   #3
JM7225's Avatar
Ok thanks I've read them. My main question is: I've got steeda lca's now, if I lower will I have to put a relocation bracket on? I'm still a little confused if I actually need a new panhard bar or not as well. Thanks again.
Old 05-22-2014, 10:25 PM   #4
LuisBlackGT's Avatar
Will you have to put reloc brackets on? Nope. Should you put them on? Yes
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 05-23-2014, 06:11 AM   #5
Clink's Avatar
You shouldn't need them unless you're lowered more than 1.5 in, but it wouldn't hurt. I'm no guru on suspension just what I've also read.
Old 05-23-2014, 06:31 AM   #6
JMoney's Avatar
Lowering my GT
I'm no expert on mustang suspensions, but I did talk to the god of the stang suspension, Sam Strano, and he said LCAs aren't necessary and to wait before getting them. He also said a quality set of shocks and struts, such as the Koni Yellows, along with lowering springs is all you need and they might eliminate wheel hop altogether without control arms. A pan hard bar is optional.
2012 Mustang V6 Performance White 6AT- Airaid CAI, Borla ATAKS, and Bama 93H Tune
JMoney is offline   Reply With Quote
Old 05-23-2014, 10:05 PM   #7
fivepointwut's Avatar
Region: New Mexico
I bought eibach sportlines and a bmr panhard bar and my **** is legit...
All kinds of places say you need this and need that and then this and then frikken that.....
Well... my car didn't need all that crap! Lol
fivepointwut is offline   Reply With Quote
Old 05-23-2014, 10:59 PM   #8
JM7225's Avatar
Hey thanks for the info. I ended up buying steeda springs, panhard bar, and front strut mounts (apparently the mounts help the camber degree which helps not wear the front tires so bad and I didn't know this). I'm trying to get the install done for around $600 with alignment. I'm very excited to see the results.
Old 05-23-2014, 11:18 PM   #9
Region: New Mexico
The eibach sportlines that I got were a 1.4inch drop in the front that didn't call for the need for any plates or ever those 35 dollar camber bolts that AM sells...
The shop I had do the alignment did everything just cherry...
Good luck with the drop!
Old 05-23-2014, 11:52 PM   #10
JM7225's Avatar
Yeah I'm not sure. I'm no expert which is why I'm asking here. I was told the strut mounts weren't absolutely necessary but they were needed to prevent unnecessary wear on the front tires. I went with his word and bought them. We will see how it turns out.
Old 05-24-2014, 12:15 AM   #11
Make sure to post some pics so that we can see that stance!! I'm interested in doing a similar setup with my stang
iMpact32 is offline   Reply With Quote
Old 05-24-2014, 01:49 AM   #12
Oh2freshstang's Avatar
What strut mounts did u get? If u got the gt500 ones I don't think they'll work with oem struts they're meant to be used with 05-10 struts on 11-14s.
Old 05-24-2014, 04:39 AM   #13
Grabber Blue5.0's Avatar
Correct. The GT500 strut mounts won't work with the stock struts.
Old 05-24-2014, 08:13 AM   #14
JM7225's Avatar
No they are not gt500 strut mounts. They are just for the good ol' GT. I'll post a pic of the stance of my car now and then when I get my parts I'll post one of after. Click image for larger version
Name:	ImageUploadedByMustang Evolution1400940758.041426.jpg
Old 05-24-2014, 02:06 PM   #15
What strut mounts are they? I didn't know they made some specifically for 11-14s. Where did u get them from?
Old 05-24-2014, 10:53 PM   #16
JM7225's Avatar
Steeda part 555-8135. It's a strut mount for 2011+ mustangs that also allow a slight camber adjustment, which is what is needed when lowering more than an inch I guess.
Old 05-25-2014, 12:56 AM   #17
Ahh ok forgot about those. For that price tho I would have just gone with CC plates! Looking forward to seeing ur finished product tho.
Old 05-25-2014, 07:26 AM   #18
JM7225's Avatar
What's the advantage to getting caster camber plates? I don't know a lot about that stuff so bare with me. Caster camber plates didn't show up on my search on the steeda site so maybe that's why he didn't recommend them. I got 20% off my order so it was about $70 off the strut mounts I got.
Old 05-25-2014, 07:40 AM   #19
Yea steeda doesn't have CC plates. CC plates allow more adjustability to the camber & caster of the suspension but since u aren't going with a large drop u will be more than fine! Plus u got them at a great discount!
Old 05-25-2014, 07:46 AM   #20
Deerslayer's Avatar
Sam may be a guru, but lowering without an adjustable panhard bar is pretty ridicules, unless you dont mind your ***-end all cattywampus. I guess it depends on how much attention you pay to detail.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 05-25-2014, 08:40 AM   #21
I wouldn't exactly call Sam Strano a guru by any stretch.
Old 05-25-2014, 10:23 PM   #22
Region: New Mexico
Mine definitely shifted to the driver side a good 1/4 to 1/2 an inch.... so thankful that I bought my adjustable panhard bar...
Old 05-26-2014, 01:10 AM   #23
JM7225's Avatar
I did buy an adjustable pan hard bar that will be installed...i think everything should turn out to be good. I'll post pics.
Old 06-03-2014, 10:11 AM   #24
JM7225's Avatar
Here is a picture of the car after lowered!
Name:	ImageUploadedByMustang Evolution1401811873.169585.jpg
Old 06-03-2014, 01:23 PM   #25
Paradone's Avatar
+1
Paradone is offline   Reply With Quote
Lowering my car? white99 Pre-2005 V6 Mustang 7 03-16-2004 10:20 AM
Hey guys that are good at lowering, need help for poster DUW Zim The Bar 2 10-13-2003 09:54 PM
Bushings for lowering springs Blue232 Pre-2005 V6 Mustang 10 10-09-2003 12:33 PM
Where can i get lowering springs (01' Vert) Stang01 Pre-2005 V6 Mustang 3 09-30-2003 10:44 AM
Lowering Springs -- How Much? Stang01 Pre-2005 V6 Mustang 7 09-20-2003 12:07 PM
11:14 PM
